Old 07-07-2017, 08:59 AM   #26
Stiggy Pop
Stiggy Pop's Avatar
The stage 2 felt no better than the K cam I took out for it. The stage 3 is more worthwhile.
'79 242
943 pickup
Stiggy Pop is online now   Reply With Quote
Old 07-07-2017, 09:00 AM   #27
EivlEvo
Originally Posted by gross polluter View Post
That statement alone makes absolutely no sense.
Eh screw you guys... they did the valve seats too with new hushers. Either way checking clearance needed thinnest shims. wth u want from me?
Old 07-07-2017, 09:17 AM   #28
J_Jones
J_Jones's Avatar
Well that makes more sense then
Old 07-07-2017, 09:33 AM   #29
EivlEvo
Old 07-07-2017, 11:26 AM   #30
gross polluter
They see me trollin'
gross polluter's Avatar
wth u want from me?
A hint of intelligence. Or, just don't post at all.
Old 07-07-2017, 11:30 AM   #31
EivlEvo
Eh...
Old 07-08-2017, 05:06 AM   #32
Sparkles
I'm pretty convinced whoever designed the stgII cam either had no idea what they were doing, or they knew it was a crap profile and banked on the "two stroke" characteristics of the exhaust profile to make people's cars "feel" fast to justify the purchase.
Originally Posted by cosbySweater View Post
[...] I think they must have ****ed up the lobe phasing going with a split duration cam because the stage 3 seems to be the only one worth a damn
I worked so hard to get my stage I cam in that last group buy, you're making me sad. Are there no justifiably satisfied customers?
Sparkles is offline   Reply With Quote
Old 07-08-2017, 11:25 AM   #33
gross polluter
Satisfaction is a relative term. In the redblock world, most people are satisfied with having an aftermarket part, regardless if that part operates ideally or not. For such a limited market, most people can't absorb the cost of development to make things better because people aren't willing to pay for it.
The RSI stage II cam has potential in a very narrow range of builds, likely developed around one of their specific engine builds. Unfortunately, it doesn't suit the common upgrade path very well. That's my beef with it. And since they're willing to reveal very little about even the basic criteria of properly utiliing this cam for fear of "releasing manufacturing information" there's no way to actually use the part for what it was designed for.
To that extent, the redblock I'm working with now left a customer very unsatisfied because the operating characteristics of a cam advertised as seemingly mild had a powerband that was only usable in the last 500 rpm of the rev range.
Old 07-08-2017, 02:38 PM   #34
snailpoweredbrick
snailpoweredbrick's Avatar
Isn't the stage 2 similar to th KG2T? Seems like a lot of people have had success with the KG2T.
RWD Parts for Sale (240,740,940)
http://forums.turbobricks.com/showthread.php?t=243774
snailpoweredbrick is offline   Reply With Quote
Old 07-08-2017, 02:44 PM   #35
gross polluter
Post up specs of both. Valve opening / closing events, intake centerline, lobe separation. You know, stuff that matters when specifying a cam.
Oh wait......
Old 07-08-2017, 03:18 PM   #36
fortbrick
fortbrick's Avatar
From RSI's site before things went under
RSI Stage II Camshaft
The RSI Stage II turbo camshaft was designed with broad power in mind, it works great with stock valvetrain and will rev reliably to 6800RPM.
The Stage II cam works great with moderate to wild mods and works well in the 270whp-420whp range. Our Stage II camshaft is a dual pattern cam with a larger lobe on the exhaust side as a means to help counterbalance the disproportionately small exhaust valve/flow in our 8v heads.
This is a cam for 2.3L or more. Needs to really breath. We highly recommend a header and larger turbo to really take advantage of this cam. This cam is not suitable for daily driven automatics as this cam really turns on at 3000+ RPM. This cam works great with stock valvetrain to 6800RPM.
Intake Lift: 11.38mm
Intake Duration: 238 degrees at .020"
Exhaust Lift: 11.96mm
Exhaust Duration: 270 degrees at .020"
Lobe separation: 116 degrees
Old 07-08-2017, 03:54 PM   #37
snailpoweredbrick
This means: "KG2T - TURBO cam for turbo use.
Increases torque at low rpm´s - clearly noticable in
city/heavy traffic situations. Also an increase in torque at
mid to high rpm. Revs more freely."
Cam data: Intake lift 10.5mm (0.413")
Exhaust lift 11.9mm (0.469")
Nock angle 114 degrees
Duration 300 degrees
Old 07-08-2017, 04:14 PM   #38
gross polluter
So no. Got it.
Old 07-08-2017, 04:21 PM   #39
snailpoweredbrick
Yup, that's all we have to work with. No real spec sheet for each cam I guess.
Old 07-08-2017, 04:23 PM   #40
gross polluter
Then how can you claim they're similar?
Old 07-08-2017, 04:49 PM   #41
wennstroma
Heres the sheet that comes with a kg2t. I didn't even receive it when I got one from a group buy, but got this image from another user. It gives an installation angle at least.
To get mine to the position they specify on a block/head that was cut ~.010" and a stock headgasket, I had to advance the cam ~13° (over one full tooth).
wennstroma is offline   Reply With Quote
Old 07-08-2017, 04:53 PM   #42
gsellstr
gsellstr's Avatar
Wait, so there's a spec for how to set the cam and make sure it's actually at TDC? Damn. lol
Spent a lot of time trying to find any kind of specs for the IPD cam since I didn't get any form of cam card with it, finally found something on the Enem site, buried. RSI is not alone with not providing info on their cams.
RIP
74 144 B20
90 745Ti
Old 07-08-2017, 06:06 PM   #43
gross polluter
Seriously.
Old 07-08-2017, 06:14 PM   #44
Texas240
Prius Owner
Texas240's Avatar
Harlards car is the perfect example of trash can comment
Hahahaha.... Day made
93 245 LS Engine Swap Project
Old 07-08-2017, 07:30 PM   #45
Pro Sneaker Peddler
O hello everyone. Yes, the RSI 2 is on its way out.
Looks like trying to sell it here will be pointless now...
Old 07-08-2017, 08:16 PM   #46
gsellstr
gsellstr's Avatar
Go ebay, people might pay for it there anyway. lol
Old 07-08-2017, 08:21 PM   #47
cosbySweater
cosbySweater's Avatar
Nah I'm sure alot of people think this thread is dumb and wrong. I'm sure it will sell on here
Old 07-09-2017, 04:58 AM   #48
K9 240
K9 240's Avatar
Hey Sparkles
I also got the stage I cam in the gb and I like it over the standard cam that was in there before. Decided to be sensible for once & not get the stage II to keep a more usable rev range.
Wagon is a dd, with other mods, I'm running the cam 4 degrees advanced.
Tim
K9 240 is offline   Reply With Quote
Old 07-09-2017, 02:47 PM   #49
gsellstr
gsellstr's Avatar
Just an FYI for those reading this thread.
The IPD Turbo cam, same as the Enem V15 Turbo cam, is set at TDC with #1 intake 1.0mm open at TDC. Took some digging to get all the needed info, figured I'd save some people some research time.
Set mine to 1* advanced over that, really does run quite nice, might bump it 1 more and leave it at that, we'll see.
Old 07-09-2017, 03:06 PM   #50
gross polluter
Harlardrdrd, take note.
