Old 07-10-2017, 04:32 PM   #1
VolvoEmpire
Default Pulled b230f ( skinny rods ) Conn rod swap?
What does it swap the rods?
Is there an easy button way?
I noticed forged rods are pretty cheap online, just those guys and bearings maybe?
This motor has great compression still I have not decided whether or not I want to pull the head off of it yet. I was just thinking of cleaning, resealing and adding the beefier rods with maybe a new cam.
VolvoEmpire is offline   Reply With Quote
Old 07-10-2017, 04:59 PM   #2
KeizerBrickGuy
KeizerBrickGuy's Avatar
Unless you're planning on making "monster" power, the "skinny" rods aren't going to break on you....save your money on something more pressing issues like fixing leaks. If it isn't broke don't **** with it.
-Stephen
#mclovethesenuts
-Wife's car: White 1990 244DL, T cam, 190k miles.B230F LH2.4, AW70 w/aux cooler, Duracool AC, purple refinished Virgos, tow hitch, ipd wagon overload springs.
Old 07-11-2017, 07:34 PM   #3
James10952001
Agreed 100%. I had 318k on my "skinny rod" B230FT when the car was rear ended, motor held up just fine. If you're going to bother replacing the rods, do a full rebuild, I guarantee once you tear apart the motor you'll find all sorts of stuff that is in less than pristine condition.
James10952001 is offline   Reply With Quote
Old 07-11-2017, 08:16 PM   #4
classicswede
Volvo upgrades
I would swap rods asap. The 9mm rods can let go at any time or they might hold up, you just never know
Old 07-11-2017, 08:24 PM   #5
James10952001
That depends on what you're doing. On a stock motor, or even with a little extra boost the 9mm rods don't break. The thing that breaks them is going nuts on boost, constantly revving the hell out of the thing or running it out of oil. The rods are not the only deficiency in the early B230s either when it comes to big power, the crank bearing layout is different and more prone to crank flex which breaks rods.
Like I said, either rebuild or swap the whole motor, don't waste time swapping rods. You're more likely to screw something up than to make it better.
Old 07-11-2017, 08:42 PM   #6
Pro Sneaker Peddler
I have a set of 13mm rods if you want them. PM me.
Old 07-11-2017, 09:23 PM   #7
Ursan
الله الفول السوداني شطائر
Ursan's Avatar
how psi a stock can support?
Originally Posted by mr brick driver View Post
Do you realize this is a rare car. From what i can see you ruined the eblems, the door lock cylenders, and casued about an additional 1000 in work for someone who wants to actally paint this car...ruined, RUINED, RUINED
Ursan is online now   Reply With Quote
Old 07-11-2017, 09:36 PM   #8
James10952001
Yeah, it can happen, but was that a stock motor running stock boost levels?
I've seen holes in naturally aspirated motors that were run out of oil or over-revved, thicker rods are not going to solve that. Also as I mentioned above the rods are only part of the equation when pushing more power out of earlier B230s. Crankshaft flex is a major contributor, reduced by design changes in the later blocks.
Old 07-11-2017, 09:44 PM   #9
gross polluter
They see me trollin'
gross polluter's Avatar
We had no issue passing 400whp on earlier B230's. Stock crank and block still intact 7 years later. Transmissions are a different story on that car......
Old 07-12-2017, 04:57 AM   #10
classicswede
Volvo upgrades
Had that happen all too many times.
You dont even need any boost for that to happen. Had at least 3 NA engines let go and 4 or 5 turbos do it. The amount of boost has little to do with when they let go
Old 07-12-2017, 09:56 AM   #11
Janspeed
True, seen this on a NA B230FB rallycar. That engine used an H-cam, was relatively fresh but it had to rev hard during rally stages.
Kaboomski. Same side, possibly even the same conrod #3?
Old 07-12-2017, 04:15 PM   #12
classicswede
Volvo upgrades
seems to be 2 or 3 that lets go
Old 07-12-2017, 04:22 PM   #13
JohnMc
JohnMc's Avatar
#2 is what let go on my 13mm rod engine.
'63 PV Rat Rod
'93 245 16VT Classic #1141
