Old 07-10-2017, 07:35 PM   #1
S4gasm2.7T
Default Catless mid pipe for 240?
Hey guys, ive been searching my a** off trying to find a catless midpipe for a volvo 240. Any idea if anyone makes ready to buy? Or do i have to buy a cat pipe and cut the cat put and weld in a pipe? I would just rather not pay for a cat if i dont have to.
S4gasm2.7T is offline   Reply With Quote
Old 07-10-2017, 07:55 PM   #2
vwblue1967
vwblue1967's Avatar
Give a little more info.
Looking for performance or replacement of a stock part but trying to save money?
Although you may not have to have emission testing I think it's illegal to not have a cat. So I doubt you would ever find a cat eliminator pipe. As far as aftermarket performance exhaust, the diameter will be bigger than factory piping so it wouldn't match up anyway.
If your existing exhaust is in ok shape, you can gut the cat you have. If you need a new one I believe magnaflow has a fairly priced cat that fits. I wouldn't recommend gutting it. I did and now wish I wouldn't have. Minimal performance gains and now I know the fumes I smell are toxic.
85 245 - ipd sport springs and sway bars yoshifab torque rods, kaplhenke bne strut mounts and TAB's. Poly bushings Bilstein tourings. B cam +4. 2.25 exhaust.
93 244 stockish.
vwblue1967 is offline   Reply With Quote
Old 07-10-2017, 07:58 PM   #3
Cwazywazy
Cwazywazy's Avatar
Take yours off, stand it up with one end inside a bag or a box or something, then start beating out the material with a pipe or something. Or cut it out and weld in a pipe. Or just leave it as is, because a cat won't noticeably affect your performance.
Cwazywazy is online now   Reply With Quote
Old 07-10-2017, 08:02 PM   #4
240 Turbos don't have a cat in the mid pipe, and the usual suspects have the Walker pipes cheap.
how psi a stock can support?
Old 07-11-2017, 06:00 AM   #5
classicswede
Volvo upgrades
In the UK non cat is the norm for 240's
Old 07-11-2017, 11:27 AM   #6
S4gasm2.7T
Looking for performance or replacement of a stock part but trying to save money?.
Kind of both. The exhaust piping on my car is pretty much toast. I need a catback and figured i'd prety much replace everything after the mani. I know going catless isnt gonna give me oodles of power. But im trying to free up any and all potential hp the car has to offer. Just figured it'd be nice to get a pipe without cat but if i have to get one then cut it out ill do that. I will eventually be going turbo but i need to get the car to stage 0 before i start trying to add hp like that.
Old 07-11-2017, 12:02 PM   #7
Might as well get the 240 Turbo stuff then, and you'll be set when you do the + Tee.
Old 07-11-2017, 12:11 PM   #8
vwblue1967
vwblue1967's Avatar
If keeping it NA, there's not really a lot of power to be made without a lot of work. If staying na, I'd get the magnaflow cat and the ipd sport exhaust is hard to beat. If you can weld there's a lot of options, if not, the ipd is a easy bolt on that I believe sounds nice. After that, swap cams.
I have a B cam, 2.25 exhaust, K&N filter and it's better but not in any way fast. For power adding a turbo is probably the best option. Sometimes trying to squeeze every bit of power you can is not worth the trouble when the end result is not going to be that impressive.
I
Old 07-11-2017, 07:30 PM   #9
James10952001
Unless it clogs up, and then it very noticeably affects your performance. Never seen it on a NA car but clogged cats are somewhat common with turbos, often the turbo fails or oil separator clogs and blows oil into the exhaust clogging the cat.
James10952001 is offline   Reply With Quote
