Old 07-12-2017, 02:30 PM   #1
shagyy
Default B5204t vs b5234t pistons
Does anybody know if there are any differences between the pistons from a 2.0t and 2.3 t5 engine? if so, what if the differences? (97-00 Engines)
I am currently building a T6 engine with 2.5 block and 3.0 crankshaft, and I know people usually use T5 pistons, but I already have 10 2.0t pistons, so it would be great if I could use them instead.
shagyy is offline   Reply With Quote
Old 07-12-2017, 04:48 PM   #2
Mogly
280WHP Regina
Mogly's Avatar
They both are 81mm bore. Id check the piston pin to deck height on both pistons. As the 2.0 has a 77mm stroke and the 2.5 had a 90mm stroke.
Mogly is offline   Reply With Quote
Old 07-13-2017, 04:27 AM   #3
GMS
GMS's Avatar
The are the same Bore 81mm but iirc the are 6mm higher or something
-Volvo V70 D3 Auto -13
-Volvo 242 B230FK -75
GMS is offline   Reply With Quote
Old 07-13-2017, 05:31 AM   #4
shagyy
I know the bore are the same. Is there anybody that can measure the distance on a t5 piston from top and down to the piston pin so i can compare it with a piston from 2.0t?
Old 07-14-2017, 02:37 PM   #5
Fisherman
Fisherman's Avatar
B5204T has a shorter stroke but has the same rods as a B5234 so compression height is different. You can use these pistons if you decide to use the original 6254 crank. I did my "T6" this way because I was too lazy (=poor) to get the 3l crank.
B5204T piston is flat and the B5234T piston has a bowl.
244 Turbo 1981
244 Turbo 1984
760 Jurbo 1984, 286hp & 302ft-lbs with LH2.1
945 TDIC 1995
Fisherman is offline   Reply With Quote
Old 07-16-2017, 03:58 PM   #6
shagyy
ah, i see. I guess i'll have to buy some t5 pistons then, because I already have the 3l crank
