Old 07-14-2017, 12:56 AM   #1
SlowRide
Cold War Crumple Zones
SlowRide's Avatar
Default ATP Ultimate Wastegate pics
Since photobucket bogarted all of our links, I figured I'd post some pics of the most recent ATP ultimate wastegate. I purchased the mild steel variant, $168, and I think I'll be happy with it once I'm making boost. Also purchased the 8mm 1.25 studs ATP sells because I'm lazy.
Here we go:
Compared to volvo 48 flapper,
Clumsy trace of the flapper footprint, looks like porting is also gonna happen.
Post casting clean up so flapper doesn't catch, could have done more at the top of excursion, doubt it will catch though.
And now, my favorite:
WTF ATP? Even with a shorter stud, what sort of nut will fit there? Forget flanged copper lock nuts on two other studs, but unflanged nuts fit fine in those places.
Les sighs...
1980 242 DL, B230f LH 2.4 AW71, B cam ipd adj gear adv 2*, ipd 25/25 sways, B&G springs (+T and M46 swap in waiting)
1982 244 GLT, partial part out, fate unknown
1989 244 DL, in a few boxes
Valhalla for Countless Others
Slowest Project Ever
240 parts, +T, and More For Sale
Feedback
SlowRide is offline   Reply With Quote
Old 07-14-2017, 03:50 AM   #2
JerryJS8
der Junge
JerryJS8's Avatar
Nice! Talk about product fail... Did the old one have that problem, or was that there the big updated ultimate change?
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) Turbo 16v (restauration project)
Originally Posted by gashog View Post
Unique for sure.
I don't think anyone is going to tell you it looks bad.
Kinda can't go wrong under the hood.
Old 07-14-2017, 06:24 AM   #3
SlowRide
SlowRide's Avatar
Not sure. I'm wondering if the all stainless version has this same issue.
Old 07-14-2017, 06:41 AM   #4
VolvoGuy123
VolvoGuy123's Avatar
Raise the flange, angle it, fit the nut, tighten as you lower it back down? lol. If all else fails, Grinder time? Wtf ATP? ;p
VolvoGuy123 is offline   Reply With Quote
Old 07-14-2017, 06:57 AM   #5
reed
reed's Avatar
I used a titanium nut, it is a 10mm hex.
reed is offline   Reply With Quote
Old 07-14-2017, 07:56 AM   #6
SlowRide
SlowRide's Avatar
Yeah, I tried raising the flange and nutting that one first. It would work, just an annoying pita...
Looking at it again, I need to trim that stud to see if its making more contact than I thought and pulling the whole shebang over, then maybe dremel time. The side wall isn't very beefy.
Old 07-14-2017, 10:47 AM   #7
Ursan
الله الفول السوداني شطائر
Ursan's Avatar
What I did, but with a slightly longer stud.
how psi a stock can support?
Originally Posted by mr brick driver View Post
Do you realize this is a rare car. From what i can see you ruined the eblems, the door lock cylenders, and casued about an additional 1000 in work for someone who wants to actally paint this car...ruined, RUINED, RUINED
Old 07-14-2017, 11:36 AM   #8
SlowRide
SlowRide's Avatar
Anyone got a recent stainless version?
Old 07-14-2017, 12:00 PM   #9
just be thankful you can preinstall the wastegate housing on a bench and not on the car and once its installed you should hopefully never have to uninstall it again.. custom length stud seems like the right answer and a slim lock nut carefully lowered into place.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 07-14-2017, 12:16 PM   #10
SlowRide
SlowRide's Avatar
Tell me you've done this with it all still on the motor
I'm just bothered that this cost 168 bacons, for a cast piece, and THIS is the issue.
Old 07-14-2017, 01:19 PM   #11
well they could have included a bump out for extra clearance which would be right in the flow path which would be less than ideal every single time you use it or you can just deal with a ****ty install once and have a cleaner line. I know what I would pick.
Old 07-14-2017, 01:31 PM   #12
Tfrasca
Tfrasca's Avatar
What about using a bolt?
Tfrasca is online now   Reply With Quote
Old 07-14-2017, 01:46 PM   #13
SlowRide
SlowRide's Avatar
If it was smooth there wouldn't be much difference, at least not for the vast majority of people buying in. That's why I want to see the stainless one because it's only $10 more and might be different.
Flange too tall and no clearance due to the transition. Maybe if the flange was notched, but I'd sooner return it and find a cosworth housing.
Old 07-14-2017, 04:20 PM   #14
gsellstr
gsellstr's Avatar
So...guys...just so happens that I know a guy in the right places with ATP. I sent him a link to this thread, already got a response.
First, he wanted to apologize for the issue. He hasn't heard of fitment issues other than having to lower the wastegate housing down while you run the nut down. That's more due to getting flow thru it, but it is a known thing. I had to do the same on mine.
The flapper clearance is something he'll look into, but it realistically won't be an issue since you will never have the flapper open THAT far under normal use.
Last, these issues aren't going to be an issue going forward as the iron version is slated to be run out when the stainless version rolls in.
Thanks for bringing this up guys! There's no way to get things improved unless the right people hear about it. Thankfully ATP actually cares about their parts, customers, and their name. Sure wish some other companies did the same...
RIP
74 144 B20
90 745Ti
Old 07-14-2017, 05:08 PM   #15
SlowRide
SlowRide's Avatar
Did he offer any hints on when the new stainless will be available? And is it different than the stainless option they currently seem to have available? This won't be going onto the 242 for a while, just hoarding and staging things as time and money allows. I'll probably end up returning this one before I hack it up.
Old 07-14-2017, 05:27 PM   #16
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
I just used a slim locknut and short stud exactly as BNE says.
No fuss.
Another one I did I just filed down where the bolt sits to a lower height and filed/ground it very slightly so the closed end stubby slim wrench can slip in there. Wasn't too bad to get it all flat enough and neat.
You could use a socket cap screw and appropriate locking washer with a ball end tool to tighten I suppose...
Stud/nut is stronger, however.
The swing arm on the waste gate flapper isn't the same as OE. I spot welded the OE to the ATP one in two spots. No more travel/actuation issues.
How PSI a stock can support?
Old 07-14-2017, 05:57 PM   #17
SlowRide
SlowRide's Avatar
Thought about doing this. Probably will.
Old 07-14-2017, 06:19 PM   #18
noz-e8tr
noz-e8tr's Avatar
Ran into a similar issue with my header. But because I modified it, not a design flaw. I just modified the bolt. It locks it in place too which is nice when tightening.
Berserker 242 Build Thread
This subculture is not conducive to meeting women let alone inspiring them to drive 30 year old, rectilinear, underpowered shit boxes.
Originally Posted by Walt Disney
"All our dreams can come true, if we have the courage to pursue them."
noz-e8tr is offline   Reply With Quote
Old 07-14-2017, 10:21 PM   #19
gsellstr
gsellstr's Avatar
Nope, he didn't give an eta.
Old 07-14-2017, 10:22 PM   #20
gsellstr
gsellstr's Avatar
Nope, no eta or details if it is different.
Old 07-18-2017, 03:41 AM   #21
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Pfff.. everyone knows that ATP designed that flange only for use with DIN 876..
retards...
here you go, thank me later...
Old 07-18-2017, 03:58 AM   #22
JerryJS8
der Junge
JerryJS8's Avatar
That table just makes me cringe
Old 07-18-2017, 04:03 AM   #23
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
want some more.. ? :D
I like the self boring and tapering screw the most.. you just need one drillingmachine for 3 steps.. in the middlepart you sometimes havo to go in reverse to split the chip, but thats OK
Old 07-18-2017, 09:13 PM   #24
tryingbe
Boosting along.
tryingbe's Avatar
No problem here with these nuts. I also used locking washers under the nuts.
http://www.ebay.com/itm/25-SUZUKI-10...gUxF_w&vxp=mtr
You're welcome.
85 GLH 350whp
00 Insight 72 mpg
94 855 in hibernation
Old 07-18-2017, 09:54 PM   #25
SlowRide
SlowRide's Avatar
Das so shiny
I did this, but those nuts will be icing on the cake.
