Old 07-17-2017, 04:14 PM   #1
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Default T5 output shaft seal
T5 decided to rustproof the bottom of my car this weekend on 120 mile roadtrip.
Started to weep from the output shaft area
Seems like the rear seal is just a dust boot, and there is a bushing inside that should seal as well? Anybody have any experience changing out the bushing? Does the trans need to come out?
Also, I did notice there is some "wobble" at the output shaft when I grab the driveshaft and vigorously shake it, That's probably not normal for one of these right? LOL
1980 242 Turbo
Old 07-17-2017, 04:27 PM   #2
culberro
culberro's Avatar
The seal just pops off. Easy peasy.
The bushing is a pain and needs to be honed to fit the driveshaft slip yoke... so you have to pull the tailshaft housing off.
Old 07-17-2017, 04:32 PM   #3
cwdodson88
If the input shaft bearing has too much play (which it really shouldn't when engine and transmission are together) the tail shaft can have a little wiggle. Do you remember how it felt when putting it in?
The Build Thread
SVEA - PUSHROD TURBO!
Old 07-17-2017, 04:53 PM   #4
Uncleknucklez
bruspeed
Hmmm, not really, is it normal for the driveshaft to have a little wiggle at the input of the trans?
I mean, I suppose I could just pound in a new seal, and see if that takes care of the issue.
If not, I would know my next course is to pull the trans and take a look at all the bushings. This unit of course was supposed to have been freshly rebuilt (per the CL seller).
Old 07-17-2017, 05:12 PM   #5
Stiggy Pop
Stiggy Pop's Avatar
The seal is really just a dust seal, I don't think it's going to affect a real leak
'79 242
943 pickup
Old 07-17-2017, 07:23 PM   #6
t8fanning
8v are still cool, right?
t8fanning's Avatar
I had an output shaft leak. Replacing the seal worked for a while, but my slip yoke had been worn down by the seal. Once I replaced my yoke, I haven't had a leak since.
1982 242 Turbo.
Old 07-17-2017, 08:34 PM   #7
Pro Sneaker Peddler
First time I hear about that. All of the Mustang forums mention that the bushing can be popped on and off in situ with a special tool.
That mentioned, my output shaft has developed a small amount of radial play and I think I should probably fix it before I destroy something...
Old 07-17-2017, 10:13 PM   #8
oldschoolvolvo
oldschoolvolvo's Avatar
Interesting discussion...I have a minor leak from my T5 output shaft as well. I needed to replace the tailhousing due to damage on the original one and the leak only showed up after I installed tailhousing #2. I thought I may have overfilled the trans and some fluid was being pushed out when it's running...total guess, but I wasn't (am not) too concerned at this point b/c it's so minor. The tailhousing I purchased had a new seal installed by the guy I bought it from.
-Mike
1998 V70 T5
Old 07-18-2017, 03:21 AM   #9
culberro
culberro's Avatar
You can try and be lucky and do it in situ, but the last 2 I did needed to be honed. Slip yokes also come in a few different diameters as welll, only a few thousands difference.
Old 07-19-2017, 10:15 AM   #10
Uncleknucklez
bruspeed
Interesting, I will try and find some specs for the slip yokes and throw some calipers on it and see if I can find a deviation.
I feel like my drive train vibration may have had something to do with the early demise of the seal, and now I am wondering if it didn't create wear in the yoke as well.
Old 07-19-2017, 11:29 AM   #11
gsellstr
gsellstr's Avatar
Mine also had to be honed to fit. ID on the new bushing was about .015" smaller once pressed into place than the OD of the new yoke going into it or the used one I had floating around in the garage. I wouldn't want to try doing it in car, and I'm a bit curious how they get the bushing to fit the yoke when they do it in car...
RIP
74 144 B20
90 745Ti
Old 07-19-2017, 11:33 AM   #12
Uncleknucklez
bruspeed
Are there any trans shops in town you recommend to do this for me?
Old 07-19-2017, 11:44 AM   #13
Chewy
Chewy's Avatar
I bet the slip joke is part of the issue. I remember with the yoshifab adapter plate and one piece driveshaft, the slip yoke wasnt super deeply engaged into the trans. It was also used so it had some wear from the bushing.
You might be onto something with a driveline vibration wearing out the bushing.
Originally Posted by alreadyupsidedown View Post
Just think of K-jet as an extremely complicated mechanical Rube-Goldberg carburetor.
Originally Posted by volvo240skunk37 View Post
Good God son, you're just a pile of fail.
A-A-Ron
Now: 69 142 "Inga" Build Thread
Had: 80 242 "Elsa" Build Thread
Chewy is offline   Reply With Quote
Old 07-19-2017, 12:33 PM   #14
gsellstr
gsellstr's Avatar
I had the Celica box rebuilt by Manual Transmission Warehouse years back, seemed like a legit shop. They moved from C street in Sac out to West Sac it looks like.
Otherwise it's not a bad job to do on your own. A brake hone works nicely, took me about an hour to do mine once the trans was out of the car.
Driveline vibration can definitely cause some wear as well.
Old 07-19-2017, 12:50 PM   #15
Uncleknucklez
bruspeed
I would love to DIY this, but I don't have a press. I'm assuming it needs a press?
Old 07-19-2017, 01:05 PM   #16
holtzboy
Back at it again
holtzboy's Avatar
Good info to know, will do this if I ever actually do the swap.
1. 86 244DL- 1st car & Owned for 15 years, 25mm sways, iPd springs/fronts cut 1 coil, HDs, 2.25" exhaust, b-cam, EZK 117K, M47 swap, 100a intake side alt, No PS/AC
2. 93 945 Turbo - IPD sways, 3" turboback exhaust, intake, accumulator mod
My feedback thread
holtzboy is offline   Reply With Quote
Old 07-19-2017, 03:20 PM   #17
M.H. Yount
M.H. Yount's Avatar
The last seal replacement I did on mine - the dust boot and slip yoke seal were combined into one unit. The dust boot extends past the tail of the tranny - and does what the name implies, keeps debris out. The yoke seal is inside of the dust boot and fits firmly around the input yoke to keep tranny fluid inside where it belongs. That unit should be replaceable from under the car without too much fuss.
The bushing is INSIDE the tailshaft housing and doesn't do much in the way of sealing. There is a special tool that is supposed to work removing the bushing with the tranny in place - no experience with that. Most find it easier to remove the tailshaft housing and then replace the bushing. If the bushing is bad - it will beat up the yoke pretty good and often lead to vibration and other more serious issues if you drive on it long enough.
Old 07-19-2017, 03:52 PM   #18
gsellstr
gsellstr's Avatar
Don't need a press if you're careful with a punch to remove the old one and CAREFUL with a socket or driver to install the new one. I have access to a press at my parents, did this job in my garage though.
And yes, the seal is both a dust shield and oil seal, the bushing does nothing for oil control.
