Old 03-13-2008, 07:44 PM   #26
HansW
HansW's Avatar
dear members
Had a 740 estate with the B230K engine -- died from a crack between the valves.
the carb was a poor enough design all these vacum hoses etc. It pinged on acceleration , no matter how far I retarded the ignition. My neighbour who had a 740 with the B230F engine with roughly about the same power was running much more economic, -- speed and acceleration were pretty much the same, the B230K was pulling a bit better at low refs. --
940 classic Cd 1997
B230FT / M90L
530 head planed, KG 2T cam
Head gasket: Elring standard (Mls 0.35 was too tight, -- piston- head contact),
1041 axle 3.74, M90
15G at 0,85 bar
3" turbo back JT-superflow
3" Amm. + 42lbs injectors
STONI chips in 984 ecu and 167 EZK
Bosch WR5 DC+ (+15)
HansW is offline   Reply With Quote
Old 03-13-2008, 08:21 PM   #27
die trying
oops
die trying is offline   Reply With Quote
Old 03-13-2008, 08:31 PM   #28
die trying
hans, thank you for contributing something useful. i will take your experiances into consideration
Old 03-13-2008, 09:23 PM   #29
the poi
Has been
the poi's Avatar
anecdotal evidence is the best evidence. Russian roulette is safe, because there's probably one guy he didn't blow his head off!
Old 03-13-2008, 10:49 PM   #30
cuaz64
cuaz64's Avatar
What is a Heron Head? I a ignorant about heads.
cuaz64 is offline   Reply With Quote
Old 03-13-2008, 11:03 PM   #31
Lucky the Smiling Pirate
roadkill
Lucky the Smiling Pirate's Avatar
631 cast head. combustion chamber in pistons. search is good. reading the thread is good
Lucky the Smiling Pirate is offline   Reply With Quote
Old 03-13-2008, 11:08 PM   #32
cuaz64
cuaz64's Avatar
OH! making research now
Old 03-13-2008, 11:14 PM   #33
roadkill
i vaguely remember something about stats for turning one into a diesel application would yield like 300ftlbs or some silliness
Old 03-13-2008, 11:34 PM   #34
volvo944ti
ok something is bothering me. what is a heron head. yea ya ya i know its a 8v head with no combustion chamber...... ok. but what head is it similiar to. teh 530, 531, 160, 405? or is it exactely one of those heads with out the combustion chamber.
given enough money wouldn't a heron head if infact , oh lets say and 531 head with out teh chanbers. would it not be a good candidate for different combustion chamber designs. is there enough to cut them into it??
don't start flaming but somethign i've been thinking about. no i won't buy one but hey someone with enough cash might try something new.
volvo944ti is offline   Reply With Quote
Old 03-14-2008, 01:25 AM   #35
die trying
Yeah someone posted about using these to make a new combustion chamber shape or something and also wanted to see the valves. As I recall some monkey told him whatever he was thinking it wouldn't work. Hmm, sound familiar?
Old 03-14-2008, 08:55 AM   #36
JohnMc
JohnMc's Avatar
I doubt the heron head would use the same internal cores as a 530 or 531 head. The water jacket is probably moved downward and there is a relatively normal amount of metal on the head around the chamber.
Volvo undoubtably did spend a lot of money developing the concept. But then scarcely used it. CC-pistons came, went, and they continued on making the more conventional heads and pistons. You'd just have to imagine there was some reason behind that.
But by all means, do what you want. Don't expect everyone to agree with you on the likely outcome.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 03-14-2008, 09:32 AM   #37
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
here is the head we are talking about here:
-Matt
1989 Volvo 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1998 Volvo S70 T5m- Stock, 229k
1998 Jeep Cherokee XJ- Stock, 154k
1983 Ford F150- '89 5.0 H.O, C6/4x4, F+R LSD 4.10, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, HR-Titan 19p.
500dollar744ti is offline   Reply With Quote
Old 03-14-2008, 11:18 AM   #38
JohnMc
JohnMc's Avatar
Well, you could stick big valves on it and not worry about shrouding!
Old 03-14-2008, 11:22 AM   #39
badvlvo
Bad for Babies
badvlvo's Avatar
One could probably put sone diesel injectors in the plug holes and make a little power with that design.[/benchrace] But that's with diesel fuel. Unless there is something special in those pistons I would suspect they ran on **** gas because of the incomplete burn. Dirty emissions out the pipes but could run on anything? Good reason that it never came to the US. Some of our domestic designs from years ago would run on just about anything that would burn. They changed designs to suit modern fuel and control emissions. Not to mention increase reliability. Probably the same thing going on here, there became no market for the engine.
Anyone got pics of the pistons? Preferably out of the engine where they can be compared to B230F pistons?
Died at age 35
Old 03-14-2008, 12:16 PM   #40
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
If you plan on using it all as stock there's no point. Get a dual stage boost controller and run lower boost when you can't get good gas. Cheap and effective and you get to actually drive your car.
Do a google search for "endyn" and "rollerwave pistons".
The heron could make an interesting "science project" for someone who really wanted to experiment with combustion chamber design.
The idea being that you would have a lot of design flexibility, because you can completely change the chamber shape by changing the pistons. The other bonus is that it is probably STIFF, but the value of this might be debatable vs. a small coolant passage casting.
You will need to more-or-less predetermine what combustion chamber shape you want, and have a set of pistons made.
Then be prepared to tweak things and buy a couple more sets of pistons.
I like engine theory as much as the next guy, but such a project would be way more "academic" than I have patience for personally.
-Kenny
Old 03-14-2008, 01:49 PM   #41
John V, outside agitator
Do a google search for "endyn" and "rollerwave pistons" and "snake oil".
Yep seems hardly proper to have something like this, which is really pointless , on Performance forum when it is the epitome of off topic.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 03-14-2008, 02:20 PM   #42
500dollar744ti
+1, well said.
Old 03-14-2008, 03:02 PM   #43
tjts1
tjts1's Avatar
Greed is good.
tits for president
tjts1 is offline   Reply With Quote
Old 03-14-2008, 03:08 PM   #44
MrBill
fige=500Dollar Mistake
MrBill's Avatar
Thats still higher octane than american 89.
I thought it was for ****ty gas?
Someone say crazy rays?
Old 03-14-2008, 03:18 PM   #45
die trying
i know there are different means of obtaining octane rating, anyone know what method was used in this case? if this is true that 95 must be used than i would have to conced my point and agree that a worked over 531 and would be much better for my needs
Old 03-14-2008, 03:18 PM   #46
MrBill
MrBill's Avatar
its a euro-design, I figured it would be RON
Old 03-14-2008, 03:21 PM   #47
Wagner
Tbricks MIG Welding Champion
Wagner's Avatar
So... I wonder how the exhaust port looks in that cylinder head. If the manifolds are at the same position as in other heads that does give a possibility to have a nicer radius for both intake and exhaust, as they are lower in relation to the manifold flange.
Maybe.
Weren't the ancient Ford Kent engines similar?
Cops pulled me over. Papers, they said. Scissors, i replied. Still i did not win. Go figure.
Wagner is offline   Reply With Quote
Old 03-14-2008, 03:24 PM   #48
JohnMc
JohnMc's Avatar
I dunno. Look at pistons 2 and especially 3 in that scanned article. They seem to have suffered some bad DETONATION!!!!
har har har
Old 03-14-2008, 03:54 PM   #49
Maybe.
Yeah Kent in EU was also Heron and it had an huge tall piston. Pin to top of piston was 44.1mm
There are some Renault engines with the Heron head as well.
Pointless excercise here.
And boys, 98 Okt RON = 94 by USA's method of RON+MON / 2
Old 03-14-2008, 04:02 PM   #50
tjts1
tjts1's Avatar
It was a carburated engine running on leaded gas without a cat or O2 sensor.
