saltflatsracing
- Sep 15, 2006
- honolulu,hawaii
WILL'S AUTOMOTIVE 1984 242T LSR Project (Update)
Living in Hawaii, you can probably imagine what it's like trying to build the fast Volvo 242T. No access to parts, shipping costs and finding reliable workmanship, etc.
All of the work so far has been done in house by me and a fabricator friend except for the engine machining, cylinder headwork, and engine assembly.eventhough i have assembled lots of volvo motors together.but for this engine tolerances were critical and i had to go outside of the state to racing engine machine shops in order to insure that kind of precision. Engine cost ---$$$ --- 2.4 Ltr, Carrilo rods, Je custom pistons coated, dry sump system, R-sport 16v head fully ported, custom made Web cams modified timng belt drive system, custom intake,EFI Technologies X3 ENGINE CONTROL UNIT. FEATURES. Sequential injection with 8 injector outputs (2) injectors per cyl.$10k. stainless exhaust for Innovative TO-4 ??? ball bearing turbo. HP so far (lots) will let you know after final dyno pull. Rear end is Track 9" custom built by Currie. Lower and upper control arms were special ordered. Driveshaft custom built Carbon fiber $1200, Richmond 6 speed custom built to our specs $4000, Tilton Nascar bell housing custom bulit at $3000 a piece with custom built flywheel and triple disc setup $$$, rear shocks Koni coil over $750 each, front struts custom built by Truechoice $1000 each.
Well, it's been a project and goal of mine and I'm finally almost there. Here's some pics.
