Not exactly sure on all those points, but would like to learn. Most have told me the only way to test the mixture setting is with a tailpipe device. Feel free to to elaborate on any details, again thanks !!
I see where cleanflametrap lost you guys. He is saying to use a voltmeter to read the MAF output voltage.
One could graph the 02 sensor voltage but I am still refining my techniques and learning how to interpret the data. It's not simple. You can't just look at it and say it's rich or lean very easily. Modern cars do calculations over a prolonged periods of time and look for a rich or lean bias on the forward o2 sensor in order to trigger a CEL.
On a 1985 there is no CEL. YOU are the computer that gets to do the diag.
I'm still trying to Pass the ASE advanced engine specialist test and this kinda stuff is on that test; the were more than a few questions on interpreting 5 gas analysis.
I wish I had access to an exhaust gas analyzer. I watched my last shop neighbor use his old one and it was pretty impressive.
Anyways, back to your car. Post up the 5 gas chart. Snap a pic would be best. I'm curious and take every chance I can to train.
My experience is getting a 2.2 car to pass is much harder than a 2.4 car. This is because 2.4 adjusts the mixture. It doesn't take much for 2.2 to get thrown off. An air leak, fuel pressure being off, may even an injector leaking; or yes a tampered MAF screw. But just because you THINK it's the problem doesn't mean it is.
I just started playing with our shops Pico labscope. I hope to practice graphing o2 sensor voltages and get better at interpreting it. I haven't learned the software yet. I was trying to use an amp clamp to do a parasitic battery drain test on a Prius today but didn't have the time to devote to getting it dialed in.
On these old cars with no OBD you can't hook up a scan tool and read data. On modern cars I could graph the o2 sensor data, look at short and long term fuel trim, fuel injector pulse width, etc.
OK so sorry if that was too many tangents! High CO is usually too rich. But we also want to look at HC and NOX. It's not a simple relationship between the 5 gasses. They are interconnected but it's not cut and dry. I'm trying to figure it all out myself!
