Old 04-10-2018, 12:22 PM   #1
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
Default Kg extreme t3 header
Anyone using one? My header was stolen and I'm looking for something for my holset
Old 04-10-2018, 12:26 PM   #2
Pro Sneaker Peddler
Jens Gustavsson developed it. Should be solid.
Old 04-10-2018, 01:57 PM   #3
cosbySweater
cosbySweater's Avatar
Work on getting some head work first before you worry about manifolds, imo
Old 04-10-2018, 05:57 PM   #4
LeedomtoFreedom
LeedomtoFreedom's Avatar
Originally Posted by thelostartof
I ran a hy35cw for a few years without many issues. Going to a custom manifold picked me up around 30whp over the 90+ on the same turbo tho.
Aren't you running the same turbo Wilford ?
81 264 - Driveway ornament
90 245 - becoming 16v
Old 04-10-2018, 05:57 PM   #5
Wilford Brimley
LOCAL ONLY
Ok....I'm all setup for topmount....my top mount was stolen..don't feel like rerouting everything and doing a new dp to put a 90+ back on, so I wanted to replace the ssautocrap with something better
Old 04-10-2018, 06:17 PM   #6
soclosenotnear
Who in their right mind would even steal such a thing?!?
Old 04-10-2018, 07:16 PM   #7
Wilford Brimley
LOCAL ONLY
Stole my turbo too
Old 04-10-2018, 07:37 PM   #8
centason
Knipex=welfare queen
centason's Avatar
Stole my turbo too
Ahh the ol steal the turbo and manifold trick. Dump the manifold in the garbage just to spite you. That sux dude.
Member: TBCCS
"The kind of man who wants the government to adopt and enforce his ideas is always the kind of man whose ideas are idiotic." -H. L. Mencken
You sons of bitches are the biggest thread de-railers in forum history. Any forums history.
Old 04-10-2018, 08:28 PM   #9
Wilford Brimley
LOCAL ONLY
Sadly I had it off and in the trunk while fixing it...trunk lock is all messed and they stole my aeromotive fpr, turbo and header:(
Old 04-10-2018, 08:29 PM   #10
Mbeas96
Mbeas96's Avatar
That is crazy...must've had balls to literally sit there and unbolt everything to remove it
Old 04-10-2018, 08:33 PM   #11
Wilford Brimley
LOCAL ONLY
...it was in the trunk whIle I was fixing the car, they messed up the lock
Old 04-10-2018, 08:37 PM   #12
Mbeas96
Mbeas96's Avatar
Dang, you posyed right before I hit submit..that sucks man, sorry to hear that
Old 04-10-2018, 09:02 PM   #13
LeedomtoFreedom
I think we need a minute moment of silence for the lost boost.
Just get a new top mount header. I just made the downpipe for my hx35 today and although it wasn't bad, I don't want to do it again.
Old 04-10-2018, 09:10 PM   #14
Wilford Brimley
LOCAL ONLY
Ill need to make a new dp since it's 4" but my feed drain ic piping all that **** are arranged for topmount, I like the look of the extreme t3 header as they call it, I assume it would hold to the weight of a holset
Old 04-11-2018, 12:31 PM   #15
LeedomtoFreedom
I'd assume they thought about holding weight when designing it. I don't know if I would worry
Old 04-11-2018, 12:37 PM   #16
Dirty Rick
Dirty Rick's Avatar
Sounds like an inside job, someone knew the parts were in the trunk...
The night time recycling crew grabs stuff that is out and visible, they don't pop a trunk just to see what is in it...
Old 04-11-2018, 06:59 PM   #17
classicswede
Volvo upgrades
Now lost boost is something worth having a minute of silence for
I have been stocking them for a whiles. Jens did a good job on teh design. The are very sturdy not like the Chinabay ****e
Old 04-11-2018, 07:09 PM   #18
white855T
The 8v extreme header has a flange for 40 mm waste gate. So on top of building a new down pipe, you would have to buy the appropriate waste gate for header.
Buyer/Seller Feedback
Old 04-11-2018, 07:13 PM   #19
sbabbs
sbabbs's Avatar
I got this one. Beefy as sheet. Real thick. I think I paid $525 for it. I got it from Lord Athlon. It's new still, never been on a car and run. No waste gate hole to plug. You don't have to run a external waste gate, you can just plug the hole with a block off plate or v-band plate if you buy one that has external gate hole.
Simon
Old 04-12-2018, 02:12 PM   #20
TurboDenny
Why am I here?
Doesn't the "extreme t3" require the alternator to be moved?
Instagram: @itstotesdenny
Old 04-12-2018, 03:53 PM   #21
Pro Sneaker Peddler
On a 240 yeah. In a 740 it's the PS pump that needs to be relocated. Knowing Ryan, it likely has no PS to speak of.
Old 04-12-2018, 07:41 PM   #22
Wilford Brimley
LOCAL ONLY
.... soo?!?!
Old 04-16-2018, 02:24 PM   #23
anyone got a link to this?
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 04-16-2018, 02:34 PM   #24
tdi
tdi's Avatar
https://www.classicswede.co.uk/Volvo..._17011158.aspx
The only extreme t3 I could find..
1980 242 DL, B230FT, big turbo.
2005 Chevrolet Duramax, LLY, CC, even bigger turbo.
tdi is offline   Reply With Quote
Old 04-16-2018, 03:48 PM   #25
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Same one KL sells, just his site is in English proper. Ha.
