Old 04-21-2018, 02:59 PM   #1
pathfinder
Default B230fk
Hi. Good day
It's year 1997, 940 FK/B230FK. This is low pressure turbo model. 13C turbocharger
Factory spec is 0.35 boost, 135bhp, 230nm
The car now is 330,000 km..still running fine
At such mileage, is it safe to gain some more power? Preferably just to make it on par with 940FT ...165bhp. 940 FT if not mistaken boost is 0.55 bar.
I need extra power just for stronger pull during overtaking and on hills ascending roads.
Enough with MBC , or need to upgrade injectors and fuel pressure regulator?
Thanks
pathfinder is offline   Reply With Quote
Old 04-21-2018, 04:21 PM   #2
classicswede
Volvo upgrades
Just MBC and set the boost to 10PSI, consider it job done
Old 04-21-2018, 08:12 PM   #3
lummert
lummert's Avatar
1 mm thick washers between the compressor housing and the wastegate gave me 7 psi on my 88 765 B230FT with 92 940 manifold and turbo.
Old 04-21-2018, 09:07 PM   #4
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
Dammit lummert!
B5.5 passat wagon, low af sexier than most wagons here.
Old 04-22-2018, 07:13 AM   #5
InTheWhite
InTheWhite's Avatar
Just set the boost at 0,55 bar and your done.
Old 04-23-2018, 08:11 AM   #6
pathfinder
Thanks
Do i need to increase fuel pressure by using adjustable fuel pressure regulator?
Old 04-23-2018, 08:44 AM   #7
JanP
JanP's Avatar
No.
-92 240 Wagon
JanP is offline   Reply With Quote
Old 04-23-2018, 01:52 PM   #8
pathfinder
Ok
So upping the boost to around 8psi/0.6bar no need to upgrade to high flow fuel pump and adjustable fuel pressure regulator right?
Old 04-23-2018, 03:12 PM   #9
JW240
All idiot, no savant
JW240's Avatar
Nope. Stock fuel pumps, regulators filters whatever support plenty, even at high mileages, provided they didn't pump mud fuel all their life.
I've upped the boost on some high mile cars and after a while they'd blow out an exhaust gasket and a completely dried out intake gasket can give up too.
To be sure of things, a good allround checkup can never harm. Intake gasket, crankcase ventilation, fuel filter, valve lash etc.
There is some info floating around on the differences between FK and FT airbox. On the FK some extra openings aren't punched out and stuff.
Old 04-24-2018, 06:50 AM   #10
pathfinder
Thanks
Should i do engine compression test to know if the engine in good condition before upping the boost ?
Old 04-24-2018, 09:11 AM   #11
Wilford Brimley
LOCAL ONLY
Naw
Old 04-25-2018, 04:22 AM   #12
Janspeed
Originally Posted by pathfinder View Post
Thanks
It's a good idea to get a general idea about the condition of your engine but if the engine is running OK right now there is no immediate need for that.
Just go for it.
