Old 03-06-2009, 07:06 PM   #1
qwkswede
faster than you think
Default twin disk clutch setup, look here if you want one.
Hey guys.
I'm working with McLeod on a custom made flywheel for one of the local cars right now. If you are interested in a streetable twin disk setup for your volvo redblock drop me a note. I'm still going back and forth with the design, but here is what I know so far.
This will be a "street-twin" setup from Mcleod, complete with a billet steel flywheel. It will have a stock or lighter pedal feel and hold 800ft-lbs torque. The pricing is going to be somewhere around $1000 for everything. Thats my one off price. McLeod says the price can come down if they make more than one. I don't know how much discount and don't really care. I'm not trying to get these "produced'.
I'm doing this soon, and a single custom unit is fine with me. If you want to jump in on this and have a really nice clutch that can take some serious torque, weigh alot less than stock, and have a light pedal too, then send me a message. I'll try to inclue you on the deal. I assume there will be some designs on file at McLeod when I am done. I'll try to make contact info available if someone wants one later.
I have been through 2.5 clutches that cost about $400-$500. So this isn't a bad deal considering you get a new SFI approved billet steel or aluminum flywheel.
-Ken
1967 Volvo 122S
1992 Volvo 244 driver
qwkswede is offline   Reply With Quote
Old 03-06-2009, 07:27 PM   #2
MrBill
fige=500Dollar Mistake
MrBill's Avatar
interest peaked.
when you say everything, can you elaborate slightly?
We will be able to use stock fork/throwout or what? I like the simplicity of my cable clutch but if this is simply a solution for what's going on inside the bellhousing, sounds like something I'd fork some $ out for.
Also, is it my discretion what kind of clutch splines I get? I mean...you have getrag, I have t5.
Originally Posted by grnmachine02 View Post
Someone say crazy rays?
93 245 - Kaplhenke Shortened coilovers with adjustable Koni Reds, adjustable rear spring perches with revalved bilstein S-10 shocks. Turbo 2.5 motor in the works.
10 v50 - Unobtainium T5 R-Design AWD M66
Old 03-06-2009, 09:03 PM   #3
Volvorules
Has a Built Trans!
Volvorules's Avatar
Yeah I'd be interested too, seriously...cable clutch? T5? Same questions as Mr. Bill
Rob
Volvoless
how psi a stock can support?
Originally Posted by MrBill View Post
not even thieves like 7/9 series.
Volvorules is offline   Reply With Quote
Old 03-06-2009, 09:04 PM   #4
qwkswede
The stock pressure plate height is in the design for now. And McLeod knows about the cable actuated fork. They are working on a design that will use an off the shelf pp and disk pack, and the volvo clutch release bearings. I have no idea if it is possible or not right now. But they are working on it.
interest peaked.
Old 03-06-2009, 09:06 PM   #5
qwkswede
and yes, the disk spline is an easy thing to build to order.
Old 03-06-2009, 10:13 PM   #6
MrBill
MrBill's Avatar
well when you get news, I have $$$$$ burning a hole in my pocket.
Old 03-07-2009, 12:28 AM   #7
Poik
Backwards Turbo
Poik's Avatar
Mcleod makes an awesome twin disc. It will help you find the weak parts in your drivetrain
Eric Olsson's 242 Turbo | 245 DL | 744 Turbo
Poik is offline   Reply With Quote
Old 03-07-2009, 01:30 AM   #8
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
800ft lb and stock pedal effort sounds evil.
is this a 7.25"? any idea if they use the "standard" 6 bolt pcd?
-Kenny
(I crushed a 240 with some stuff done to it. Honest.)
Originally Posted by Jordan View Post
Turbobricks isn't a car forum any more. Its a forum for lame kids.
Captain Bondo is offline   Reply With Quote
Old 03-07-2009, 01:40 AM   #9
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
yeah. the 1000ft/lb i'm looking at for the evo is allegedly "slightly" stiffer than stock. Twin disc is the way to go if you're making power.
Megasquirt Tuning!
Old 03-07-2009, 02:06 AM   #10
RvolvoR
Master Troublestarter
fo sho, i was staring at the triple plate from a stockcar at work today...i wanted to walk out with it under my shirt...
Old 03-07-2009, 03:52 AM   #11
BB-Q
BB-Q's Avatar
You know 3.5kg multi disc ready billet flywheels are available already, don't you?
http://www.ttvracing.com/
And the UK/USA exchange rate is in your favour at the moment.
Originally Posted by foggyjames View Post
The man is a pimp, and a fast one at that...
Originally Posted by frpe82 View Post
He's got that "crazy Mark" look in his eyes...........
1992 245 SE B200F, M47, Low and painfully slow.......
v8volvo240.com
BB-Q is offline   Reply With Quote
Old 03-07-2009, 05:02 AM   #12
Poik
Backwards Turbo
Poik's Avatar
Happen to know what they charge?
Old 03-07-2009, 05:45 AM   #13
Alex Buchka
8 cylinders
Alex Buchka's Avatar
The AP/Quartermaster/Tilton multi plate clutches will not have stock pedal feel like the McLeod. If they are the sintered metallic type especially it's about a 2 steps away from being an on-off switch. A clutch that bites hard with no slip is great at completely wrecking a drivetrain from shock load.
Alex Buchka is offline   Reply With Quote
Old 03-07-2009, 06:41 AM   #14
BB-Q
BB-Q's Avatar
About £200, I think. You'd need to check the bolt circle of the clutch matched to what they have. I understand that they can drill to any PCD, no problem.
Old 03-07-2009, 06:50 AM   #15
BB-Q
BB-Q's Avatar
Looking at the option for Tilton, aren't the cerametallic plates a lot more forgiving (& importantly- cheaper)?
Old 03-07-2009, 09:24 AM   #16
Volvorules
Has a Built Trans!
Volvorules's Avatar
That's fine, but it sounds like Ken is coming up with a "kit" to get it done in one shot. That's what I'd be interested in. I'm tired of waiting and waiting for specialty parts Group buys and the like, you know?
Old 03-07-2009, 10:56 AM   #17
MrBill
MrBill's Avatar
amen
and I emailed the guy a while back back a stock-size redblock flywheel (8.5 or 9.0) and got nothing back. Still have the money burning a hole..
Old 03-07-2009, 07:33 PM   #18
qwkswede
Working with Red McLeod has been a pretty good experience. He admits to being one of the very few US clutch shops that will even take on custom work any more. I can pretty much confirm that. I have called a ton of places. I'm sure they can get this done one way or another. I don't think they will offer it for sale as a mass produced part. But hes not charging a big premium for a custom part.
I should talk to him again on Monday or Tuesday. I left him with alot of measurements from my flywheel and pressure plate. I will have to drop off a sample soon so that he can confirm the final dimensions.
On the phone, Red was looking at 8 or 8.5" disks. I'm not sure where he will end up. It all depends on what he has that can fit the flywheel and keep the release bearing and fork alignment the same. The bigger size is more desirable for street drive ability.
I'll let him know that there are potentially another 2 or 3 others that might want a copy of the setup.
Old 03-08-2009, 08:30 AM   #19
volvomad
Sure. Depends on pricing as I'm in Australia and have to include shipping.
volvomad is offline   Reply With Quote
Old 03-08-2009, 10:01 AM   #20
dirtbike
cutting, welding, bashing
Ken indicated that it would be around $1000, I can't believe that this setup would weigh more than the iron flywheel and stock clutch(infact I would expect it to be significantly lighter) so work out shipping based on that you'll have a pretty good ball park figure to work out if it's within your budget.
Laters
Nick
Volvord Project Thread :http://forums.turbobricks.com/showthread.php?t=184497
1972 Mk1 Escort, B230, 16v, T5/4L60E, 8" Axle, KMS MD35, AIM EVO Datalogger
"Volvord MK1 Escort Project" : http://www.jwbr29544.pwp.blueyonder.co.uk/escort
dirtbike is offline   Reply With Quote
Old 03-08-2009, 02:36 PM   #21
BB-Q
BB-Q's Avatar
Absolutely.
Just putting the info out there in case Ken wasn't aware of it.
Old 03-08-2009, 02:59 PM   #22
reeferman
broad member
reeferman's Avatar
heel toe or blow...
[IMG][/IMG]
reeferman is offline   Reply With Quote
Old 03-08-2009, 03:57 PM   #23
The Aspirator
It's a girl!
The Aspirator's Avatar
Wow they make some cool stuff, thanks for the inspiration!
'83 242
'95 T5R
'98 S70
The Aspirator is offline   Reply With Quote
Old 03-08-2009, 05:39 PM   #24
dbh86
What's a 16V?
dbh86's Avatar
I assume these are going to be complete flywheels and not just button PPs.
'07 MS6 - DD/DSP of doom
'92 245 - Eternal Project
Incidentally, if we're going to follow this other train of thought, you should install your spare tire while the vehicle is cruising at 55mph, since that's about where it'll be used most often.
dbh86 is offline   Reply With Quote
Old 03-09-2009, 06:48 PM   #25
qwkswede
Red spent some time working on the problem over the weekend.
I need a favor. I have finger height measurements from the 740 flywheel and pressure plate.
I could use some measurements from a 240 clutch setup to confirm that they are close.
Can someone measure something for me?
Assemble a 240 flywheel/disk/pressure plate and then measure the distance from the crankshaft mounting flange to the pressure plate release fingers where the release bearing would touch. The clutch neeeds to be assembled so that the pp is compressed.
