Old 06-17-2016, 05:38 PM   #101
MrBrown
You like popsicles?
MrBrown's Avatar
Where's the updates. Nothing is holding you back.
GhettoFab build thrizzie
Old 06-18-2016, 03:47 PM   #102
VeroDubs
The Big Swede
VeroDubs's Avatar
Originally Posted by dailywagon View Post
Are you thinking about selling that extra set of adjustable torque rods?
I would consider selling them. Sure
Alright, alright... I have been slacking with the updates. Been working on it every night!
So I installed my pressure plate on the trans and just like you said, I needed to shim it. I went and found some flat washers and needed 1 washer in order to make the teeth sit where they were supposed to.
We went ahead and test fit the trans and found two issues right off the bat.
First, I did't have enough travel in the clutch fork to disengage the clutch properly.
Second, the Yoshifab crossmember and Prothane Mount didn't line up at all!
I solved the clutch for issues by shimming the pivot ball for the clutch fork .5" and the grinding down the bell housing may .25" just to get some extra clearance.
Then I took a nibbler and worked the holes in the crossmember to open them up to allow for some adjustability once installed. Worked out nicely.
Next we had to clearance the tunnel to make room for the 3" drive shaft. After a lot of hammering and beating, we came to the conclusion that I am still going to have to switch to a stock steel fox drive shaft. No matter how much room we make, it still hits on a good bump.
This picture doesn't show the amount of clearancing we actually wound up doing.
After all the modification we made though, everything is in and working. Still need to finalize the shift boot to keep the hot air from coming up through there!
This morning I washed, cut, clay bared, and waxed her. The took it out for a ride. It rides nice though there are a few things I need to address.
-I am getting some decent clutch chatter that shakes through the whole rear end, especially in reverse, or on take off without enough gas. I am thinking I will need to change the rear control arm bushings out for something new or better. I have the adjustable pan hard, and torque arms with urethane. Also with the Konis in the back. The only bushings left are the control arms.
-I need to sound deaden under the carpet as the T5 is a mildly noisy trans. Not in a bad way, just makes different noises than maybe I am used to.
-Work out how to make the shifter hole sealed up so I don't get a blast of hot air while driving.
-Fix my exhaust! It sounds terrible haha
Here is a pic I got from my cruise this morning over to the river.
My '89 Brick -"The Big Swede"
VeroDubs is offline   Reply With Quote
Old 06-18-2016, 04:49 PM   #103
MrBrown
You like popsicles?
MrBrown's Avatar
If I had a lift, life would be so much easier. Good work.
For the shifter hole, grab a VW beetle rubber shifter isolator that's under their shift boot. It deals really nice and quiets down quite a bit. You can also add additional foam from a spray can to seal more. Grab one from a yard and your golden.
Old 07-02-2016, 09:25 PM   #104
VeroDubs
The Big Swede
VeroDubs's Avatar
Well, I been working out vibrations and other little things related to the swap. I went by the storage unit to put on the stock steel wheels today to eliminate any vibration from the wheels. While I was there I decided that I would test fit the 17's that I had in there.
I really like the way they look. I think I am going to need to find myself another set of the VOXX MG's so that I can have a complete set of 4 instead of 2 MG's and 2 MG3's. I am still gonna get the tires mounted and fit them to the car. They will look so much better than the 15's that I have on there now with the little tires!
I also loaded some weight into the back to see if I had eliminated the rubbing that I was getting from the driveshaft hitting the tunnel anytime I had some weight in the car. So far no rubbing. Last time I had the drive shaft out I beat the tunnel quite a bit to gain some more clearance!
Old 07-08-2016, 10:46 AM   #105
VeroDubs
The Big Swede
VeroDubs's Avatar
UPDATE on the wagon. Been having fun with it!
Wound up snagging a set of 850R seats that don't have any tears but need a little conditioning. Just need to figure out what I can do for the rears to make them match.
While I had the seats out to measure the bases to figure out what I will need to make for mounts, I ghetto rigged a shift boot. Only temporary as I don't really like how it fits the T5 shifter!
Then we cruised and watched the 4th of July parade... nice having a wagon to chill in the back.
Then yesterday, I decided to address the drivetrain vibration. I started by replacing the rear yoke because I was getting a very mild binding in. I was hesitant to buy one because they are kind of expensive for a little piece. But it did wind up working, so it was money well spent.
Then I got her up in the air and centered the real wheels side to side and front to back and swapped on my VOXX wheels. I kind of like how it looks, but it raised the car up quite a bit.
Heres a short video of it slow rolling in the parking lot.
http://vid47.photobucket.com/albums/...psimo3bbdt.mp4
Next on the list I have some of Ben's Spherical TAB's coming, new front rubber TAB's, and possibly an a/c compressor.
I am not too sure how I feel about this clutch yet either. It seems to chatter through the drive train a bit. I am hoping new trailing arm bushings help out a little.
I also need to trim/roll the rear fenders so I can get the 25mm spacers back on and put the wheels where they were in the test fit picture!
Old 07-08-2016, 10:49 AM   #106
MrBrown
You like popsicles?
MrBrown's Avatar
Sweet homie. You coming to cars and coffee this Saturday in jax? It's my first debut! Then we are doing s dyno day right after its all volvos!!
Old 07-08-2016, 10:53 AM   #107
amerbritcan
Hnnnnnng
amerbritcan's Avatar
Uhhh...the wheels in one pic are different from the other. You have one style of voxx on one side, and another style on the other side?
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 07-08-2016, 10:56 AM   #108
VeroDubs
The Big Swede
VeroDubs's Avatar
Yep... $250 from the junk yard with almost new tires... couldn't pass it up haha.
Old 07-08-2016, 10:59 AM   #109
MrBrown
You like popsicles?
MrBrown's Avatar
TwoMG and two MG3
Old 07-08-2016, 11:03 AM   #110
VeroDubs
The Big Swede
VeroDubs's Avatar
I doubt I can make it up there. I just finished my break in on the clutch and need to get some more miles on it.
Old 07-08-2016, 11:06 AM   #111
amerbritcan
Hnnnnnng
Yeah I wouldn't pass that up either lol. Threw me for a loop though lol.
EDIT: If I would bother to go back and look, I'd have read it in your previous post. My bad haha.
Old 07-08-2016, 11:17 AM   #112
VeroDubs
The Big Swede
VeroDubs's Avatar
I figure you can only see the car from one side at a time... sooooo
And no worries on reading the thread, I post more photos than words I think!
Old 07-08-2016, 10:04 PM   #113
LC4CARL
Aero challenged
LC4CARL's Avatar
Looking good.
Life begins at 10PSI.
Old 07-23-2016, 06:47 AM   #114
VeroDubs
The Big Swede
VeroDubs's Avatar
Alright so a little update-
Ordered a set of lights from a Volvo nut over in Amsterdam. They show up mostly intact.
After disassembly, I had to run to Volvo for a few clips and bust out the super glue for a few things, but otherwise they were in nice shape.
Decided that I would black out the housing and insides of the corner lights-
Overall I light the look. Definitely a nice change from keeping the housing the stock grey.
Install went relatively smooth. Was to order the relay kit that I was reading about, but can't remember the website. So for now I made my own wiring adapter to make it work. Light output with the glass clear lenses is sooooo much nicer!
Old 07-23-2016, 01:34 PM   #115
amerbritcan
Hnnnnnng
Rewire your light switch to be relayed instead of having all the juice running through the switch. I can't count how many headlight switches have melted on me over the years, and it gets you better/more reliable power to the lights, much needed if you're planning on getting higher output bulbs or HIDs or something.
I really like the black housings, I'd like to do that to mine.
Old 07-24-2016, 04:35 AM   #116
Sharingan 19
Sharingan 19's Avatar
Looking good!, we seem to go about things the complete opposite way, +T was the first thing I did, and I've got a Flathood grill coming but no E-codes yet,
Sharingan 19 is offline   Reply With Quote
Old 07-31-2016, 02:12 PM   #117
VeroDubs
The Big Swede
VeroDubs's Avatar
Good idea, I will keep that in mind. And yeah, the black housings really changed the looks of the lights, and makes them appear a bit smaller, which I like.
I am piecing together the +T, but the trans letting go forced my hand to put it on the back burner for a bit.
Old 07-31-2016, 02:13 PM   #118
VeroDubs
The Big Swede
VeroDubs's Avatar
Playing with a vinyl cutter... and I got out the fancy camera haha
Old 07-31-2016, 09:12 PM   #119
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Nice! Those blacked out buckets looks great!
1980 242 Turbo
2004 V70R
Old 08-01-2016, 01:34 PM   #120
LC4CARL
Aero challenged
LC4CARL's Avatar
So, with some run time, from a shifting stand point is the T5 swap worth while. My M47 seems to do everything wrong.
Old 08-01-2016, 02:22 PM   #121
MrBrown
You like popsicles?
MrBrown's Avatar
I'll answer for him... yes!
Old 08-01-2016, 02:45 PM   #122
VeroDubs
The Big Swede
VeroDubs's Avatar
In short the answer is yes. At first it's very unusual because the gearing was SOOOO different that my M47. Mainly the fact that 1st is usable and you downshift to 2nd a bit more.
Another thing I am getting used to is the new noises I have. It overall is just a noisy trans. I don't think it helps that I went ceramic clutch and solid driveshaft.
I am also finding that my lack of low end power is very much noticeable with the T5, almost to the point that I want to put the timing back to 0 and see if it helps. Its a dog off the line.
But is it worthwhile? The answer is yes. The gears are long and the car pulls great in the top end. If I can get the power to come down a little in the RPM's it will be even better. I would like to drive one with a more normal clutch though and see what it feels like. I am seriously contemplating changing my clutch disk!
Haha... ^^ This man knows!
Old 08-01-2016, 04:16 PM   #123
MrBrown
You like popsicles?
MrBrown's Avatar
It's strange I hear everyone state the T5 is noisy. Mine is just as silent as my M46... No strange vibrations or loudness coming from the Tranny or the driveshaft. I also went two peice though. I wonder if it could be mount related as well??
Old 08-01-2016, 04:32 PM   #124
VeroDubs
The Big Swede
VeroDubs's Avatar
Possibly. I am running the prothane mount. It is probably a combination of all of it!
Old 08-01-2016, 04:33 PM   #125
VeroDubs
The Big Swede
VeroDubs's Avatar
What do you think about the cam timing being pulled back? Think that would help my low end power?
