MadDog_945
Våga Vägra 8V
- Apr 25, 2006
- Lower Saxony
i used a PU roller for wallpapers, it is not spongy
Just a bone stock 3516093 booster...also the adapter I believe is stock, it was all like this from the very beginning.What brake booster and adapter is that?
INA hydros and ford 4.6l springs
INA hydros is what I have used too. What is the benefit of the ford springs? Somehow I have missed this upgrade but I could still easily do it as the head is apart...INA hydros and ford 4.6l springs
As far as I understood the head is quite good for the power levels I am aiming (300-350hp) so there were no real upgrades, just cleaned everything and replaced what was worn (lifters, seals, valve stems).Did you do some upgrades to the head (valves or lifters), im not sure if i should upgrade someting there now im at it.
I bought mine from Germany too, it was only 65e shipping includedThanks for the INA hydraulic lifter tip, they are quite cheap @ daparto.de.
Awesome; just to be 100% sure I've sent a question to the manufacturer to confirm the VS1268 and VS1632 are exactly the same and there is no advantage of using one over the other one. I am ordering it right after the confirmationI used the VS1268 springs in my 16v head. Runs fine.
