Bohr
- Jan 2, 2021
- Lethbridge, AB
Currently starting my build from a B21FT out of an 84 GLT.
As a bit of context, I am doing an MS conversion with this motor, running some decent flow Holset turbo likely. Completely rigging new fuel, electrical, probably gonna even end up doing MSnS, already aware that I will need a ton of stuff from an EFI system (intake manifold, TPS and pigtail, pos sensors, etc)
Additionally I will be taking the A cam out of a B21A from the 82 DL that I'm building my project up in.
What I'm curious however, is what issues I'm gonna run into with the actual strength of the components I'm working with.
So I have the following questions:
1. What's the weakest link in the B21FT's block?
2. If I'm talking about raw reliable boostability with proper engine management, which will withstand more power, a stock B21FT block or a stock B230FT block.
3. I've heard the flow through the B21FT head is incredibly restrictive. Is the B230FT head vastly improved? If not, which head should I look for to improve flow OR should I just be looking to open up the head myself, and home-rig some better flow with bigger valves
4. What are the weakest links in the heads to reliably take boost, and which head would be my best bet?
For reference to the amount of boost I'm talking, I figured with clean flow, and good engine management, I could reliably make about 300HP off around 20-22PSI.
I'd love to be able to increase that as the future comes, but I'd like to take the process slow.
While I'd rather conserve money while rebuilding the engine, if there's some clear and priority improvements that need to be made (Let's say hypothetically weak piston heads, or shotty connecting rods) to reliably take the boost as a daily driver, then I'm not worried about rebuilding with something stronger.
Essentially trying to build the dream 8V on a medium budget (considering how much MSnS and all new fuel and ignition systems will cost me, I'm not necessarily scared off by price. Just trying to keep it tight).
Thanks,
Thanks,
