VolvoPrince
- Feb 10, 2016
- Phoenix
Having issues with my new to me 93 245. Coolant temp gauge doesn?t work, car is throwing ECU 1-2-3, and EZK 2-2-4, both coolant temperature sensor related. I have replaced the 2 prong sensor with two separate new sensors (bench tested confirmed working), and a new single prong temp gauge sensor. Both codes persist after clearing through OBD1. (2-2-4) is new, it was only doing (1-2-3) before I replaced the 2 prong sensor again.
Wiring has been checked for continuity, and I?ve checked the pins at the boxes. The pigtail to the 2 prong looks clean also.
Pin 13 and 5 at the ECU deliver a result around 2000 ohms, which is correct based on temperature values. This means the wire to the ECU box is good, it?s making connection, and the sensor itself is good.
I tried to simulate an intermittent connection issues by starting the car on a cold start, turning it off, and repeating those steps dozens of times. It never failed to start, it never ran weird either. Runs like a top other than obviously running a bit rich.
Though, I did unplug the sensor on purpose to see how it would cold start.... it didn?t start. Plugged it back in, started right up.
Really confused at this point... the car does have an Ipd Cam gear, as well as a bunch of OEM style vdo gauges in the dash added by the PO. Overall the car is extremely clean and well taken care of, M46 w/OD swapped...even the underside is dry as a bone.
