Old 07-10-2017, 03:26 PM   #1
VolvoEmpire
Default Intermediate shaft has no gear : (
I was about to put my freshly resealed and cleaned b230ft into my 87 244 when I popped out the freeze plug to reveal that the intermediate shaft has no gearing in it.
Has anyone had any experience swapping these guys out? Is it a lot of trouble. I was going to try to finished with this swap by Thursday evening
Also is there a diagram that I will help me to get the proper dizzy direction at tdc?
VolvoEmpire is offline   Reply With Quote
Old 07-10-2017, 03:46 PM   #2
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
Here's how to get it all in time, once you get the intermediate shaft installed. https://www.volvoclub.org.uk/faq/B23...tAlignment.htm
-Stephen
#mclovethesenuts
Old 07-10-2017, 04:27 PM   #3
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
I just did one on mine. You'll need one from a 240 obviously. It requires pulling the oil pump drive under pcv breather box. Also the distributor has a hard time going in on a block that never had one. I cleaned it up with some emery cloth and it went in. Set all your timing gears to TDC like when your putting on the timing belt and point the distributor just after where the #1 post on the cap would be. When you slide it in it will turn counter clockwise on the bevel gear to #1.
Hello My Glorious!
CAPT_BLOTTO is offline   Reply With Quote
Old 07-13-2017, 12:15 PM   #4
VolvoEmpire
You got it, just help me get this engine into the car.
Old 07-10-2017, 06:27 PM   #5
Thor
Thor's Avatar
you wanna come over and rebuild my B230FT when you're done. it's been sitting on my stand for almost 18 months now looking pitiful.
1991 240 M-47 daily driver
Build thread: 91 240
Feed back: Here
Thor is offline   Reply With Quote
Old 07-10-2017, 06:35 PM   #6
iHateVolvoPeople
I have a 240 aux shaft for $65 $55 shipped if you want it.
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245T m47
92' 940 turbo AW71
94' 945T AW71(L?)
Old 07-10-2017, 08:41 PM   #7
Stiggy Pop
Stiggy Pop's Avatar
problem solved
'79 242
943 pickup
Old 07-11-2017, 11:18 AM   #8
Thor
Thor's Avatar
Originally Posted by Stiggy Pop View Post
problem solved
He'll probably just pull the one in his current motor and slip it into the other. Problem Solved
Old 07-11-2017, 12:58 PM   #9
A tough rowing ho
Make sure you use a gasket on the cover that holds the shaft in. Rtv won't work as the gasket gives the shaft thrust bearing enough clearance.
Old 07-11-2017, 01:05 PM   #10
Dude, you just completely blew his budget.
Old 07-11-2017, 01:10 PM   #11
KeizerBrickGuy
Sh*t pot stirrer
Old 07-11-2017, 05:53 PM   #12
James10952001
RTV shouldn't be allowed anywhere near a Volvo motor. I've spent at least a couple hours so far scraping and peeling RTV out of various parts of my B230FT. Last week I found it slathered all over and inside the fittings to the oil cooler thermostat housing so the hose was about 80% clogged up, best part is it wasn't even the fittings that were leaking.
James10952001 is offline   Reply With Quote
Old 07-12-2017, 10:36 AM   #13
Wren
Porkchop Sandwiches
Wren's Avatar
Used properly, there's nothing wrong with RTV. If you apply it like you're icing a cake, that's another story.
Old 07-12-2017, 02:07 PM   #14
RTV is likely why my Volvo engines don't leak after I have worked on them. As Wren said, it is great stuff when properly used.
Old 07-12-2017, 02:46 PM   #15
KeizerBrickGuy
Sh*t pot stirrer
Truth be told here. I use RTV and anaerobic sealant sparingly, as a sort of "seasoning" for gaskets or joints that look questionable. It's supposed to be applied as a THIN film.
Old 07-13-2017, 01:00 PM   #16
James10952001
I use some stuff called Hylomar Blue, and use it very sparingly in a few specific places. Most people use way too much sealant and use it in places that don't need or want it. There *are* a few places on these motors that need sealant, but only a few.
