Old 11-10-2013, 03:11 AM   #1
drftvlvo240
drftvlvo240's Avatar
Default Finished my fuel cell
Aeromotive 15gal Stealth 340 fuel cell in my 90 240. I'm quite satisfied with the finished product.
90 244 b230ft = hawtness
06 sentra SER spec-v=Sold :(
2010 jeep grand cherokee w/ hemi powa!!!!=Daily
drftvlvo240 is offline   Reply With Quote
Old 11-10-2013, 11:08 AM   #2
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
That looks really clean. Nice choice in hose, I use that myself.
962j 815/692@27psi
THIS IS FORSALE V
Old 11-10-2013, 12:27 PM   #3
Mogly
250HP Regina Hub Dyno
Mogly's Avatar
NICE
El Es Juna Swap people be like "I get 19mpg !"
Mogly is offline   Reply With Quote
Old 11-10-2013, 01:05 PM   #4
Hodginsa
Always
Hodginsa's Avatar
Thats nice, how far under the car does it go?
http://idlehandsproject.com - Keep me busy.
Hodginsa is offline   Reply With Quote
Old 11-10-2013, 01:57 PM   #5
mafoose
Boost Addict
mafoose's Avatar
Nice!
Why not plumb a filler to behind the gas cap?
Does it have a breather with a rollover valve?
- 84 242 - 92 740 - 72 240z - 78 280z -
mafoose is offline   Reply With Quote
Old 11-10-2013, 02:39 PM   #6
drftvlvo240
basically the same as the stock tank.
Originally Posted by mafoose View Post
Nice!
Im eventually going to change the filler location...just not now.
It has 2 breathers w/ rollover valves. they are the 2 AN lines in the corners toward the front of the car
Old 11-10-2013, 03:08 PM   #7
towerymt
the real Towery
towerymt's Avatar
Looks good. How is it attached, did you add some structure under the flange, or is it bolted to sheet metal? We probably overbuilt the cage, but ours is not moving in a crash! One of the guys on our team just put this in our 24hr lemons car: http://www.pbase.com/towerymt/inbox&page=43 It's all 1/8" steel angle and box tube. 24gal cell.
Old 11-10-2013, 04:24 PM   #8
Alex Buchka
8 cylinders
Alex Buchka's Avatar
Is that actually a fuel cell or just an aluminum box?
Old 11-10-2013, 05:31 PM   #9
centason
Wine enemas for all
centason's Avatar
Its a fuel cell. Aeromotive sells them in 15 or 20 gallon flavors with an A1000 or Eliminator pump included. Might have other choices of fuel pumps, not too sure.
Member: TBCCS
Death to all who stand in the way of obtaining the freedom of working people!
Just remember this guys. Im related to cocaine.
they were pushing sloppy poo up a steep hill with a pointy stick.
Any forums history.
Old 11-10-2013, 06:56 PM   #10
Alex Buchka
8 cylinders
So there's a bladder in there? Nothing on Aeromotive's website suggests it to be more than an aluminum box.
Old 11-10-2013, 07:23 PM   #11
Old Iron
I Roll
Old Iron's Avatar
Looks good Pat, still never gotten a ride in this beast! How is the new engine coming!
Turbobricked
Old 11-10-2013, 07:50 PM   #12
centason
Wine enemas for all
centason's Avatar
Good question. The Aeromotive I had in my Supra had a bladder, but that was 6 years ago. I guess the OP will have to answer that for us.
Old 11-11-2013, 01:26 AM   #13
drftvlvo240
Its just on the sheet metal no extra supports.
No there is no bladder. If i was running in a class where the car needed a bladder I would have gotten an ATL or similar brand cell with a bladder but that simply is not the case. The way it is set up now allows me to go that route very simply without much modification.
Old 11-11-2013, 02:12 AM   #14
megulon-7
What class are you running?
megulon-7 is offline   Reply With Quote
Old 11-11-2013, 02:27 AM   #15
drftvlvo240
Just HPDE, open track days....Hopefully ill be TT by end of the upcoming season.
Old 11-11-2013, 07:51 AM   #16
Matt
ICY HOT STUNTA
Matt's Avatar
so a "fuel cell" just for the hell of it.
SHOtime - '90 744 Turbo
The LowCar - '93 945 Turbo
Ghetto Superstar/SkidCar - '88 740
Brown - '85 740 Turbo
Matt is offline   Reply With Quote
Old 11-11-2013, 09:55 AM   #17
Lord_Athlon
Sf1k Kryptonite
Lord_Athlon's Avatar
Stock tank not good enough?
Originally Posted by rvolvor
Old 11-11-2013, 10:13 AM   #18
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
Looks cool.
Hello My Glorious!
Old 11-11-2013, 11:44 AM   #19
drftvlvo240
Stock tank had a leak and needed replacement...Also the stock level sender was working intermittently.
Pump set will flow more than walbro the I had ....but then i can just turn the boost up more.
Old 11-11-2013, 12:04 PM   #20
post upskirt pics
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 11-11-2013, 03:35 PM   #21
towerymt
the real Towery
towerymt's Avatar
Does it have foam inside? What sort of pickup(s) are you using inside the tank? We used some screen pickups plumbed to hardline all feeding a single hose to the pump. Seems to work well after our first race last month.
I'd be concerned about that tank in a hard rear impact. You should close off the rear seat x-brace and the rear speaker shelf with metal.
I'd also question mounting ~100lbs+ to only sheet metal. Anything more than those 20 or so socket head cap screws?
Old 11-11-2013, 05:31 PM   #22
Matt
ICY HOT STUNTA
Matt's Avatar
He said no foam.
Old 11-11-2013, 11:28 PM   #23
towerymt
the real Towery
towerymt's Avatar
He said no foam.
Where? Search "foam" and only comes up in my post and yours.
Old 11-11-2013, 11:34 PM   #24
Lord_Athlon
Sf1k Kryptonite
The internet says no foam.
Old 11-11-2013, 11:44 PM   #25
drftvlvo240
Originally Posted by blkaplan View Post
post upskirt pics
Simmer down you.
pics of the pickup.
No foam. there are a bunch of baffles instead.
I plan on closing off the front from the back. I have alot of work to do to the interior.
Basically the screws go all the way around. I wanna see what it does when there is weight in it. If i need to add supports then so be it. I'm not against adding supports.
