Old 07-17-2017, 04:59 PM   #1
Ilvmetal
Ilvmetal's Avatar
Default 96.5mm pistons no can find not even Yoshifab
Josh from Yoshifab is currently out of stock of the 2.3 96.5mm 16v pistons.
Anyone have a spare they want to sell or know where to find them? Wisecos?
My eyes are bleeding from searching for 4 hours on the WWW.
Need forged pistons over stock bore for a B230ft 16v build even as a kit with rods.
Its a slow painful process this 16V build......
1973 142 Turbo 16V build
1986 FJ60 V8 conversion "lerch"
1989 740 bunch of stuff done
2004 V70R Wife's DD
2017 S60T5 Pole star ecu flash (still slow)
At any given time I have to many projects but not enough Volvos...
Ilvmetal is offline   Reply With Quote
Old 07-17-2017, 05:09 PM   #2
https://www.acm.se/en/category/turbo-5
Old 07-17-2017, 05:10 PM   #3
culberro
culberro's Avatar
Top End Performance is a dealer for JE. When I was sourcing custom Volvo 16v pistons from JE, they recommended me to them. Steve knew EXACTLY what I wanted, we just confirmed measurements and options. You can definitely get 96.5mm ones, just specify
$850 for a set with rings, but I went with the fancy x-forge and a slipper piston design. Cheaper if you go with a standard forging.
https://www.racetep.com/manufacturer...d-pistons.html
Old 07-17-2017, 05:11 PM   #4
ryanfay
more bounce to the ounce
ryanfay's Avatar
Theres tons of wisecos in that size on ebay.
ryanfay is offline   Reply With Quote
Old 07-17-2017, 05:13 PM   #5
Ilvmetal
Ilvmetal's Avatar
Really guys thank you for the quick reply, I wasn't even planing to use forged stuff but I am so committed at this point and its my only weak link.
Old 07-17-2017, 05:18 PM   #6
Ilvmetal
Ilvmetal's Avatar
I was looking at these but just eBay scares me.
http://www.ebay.com/itm/Wiseco-14cc-...ZZSshB&vxp=mtr
Old 07-17-2017, 05:22 PM   #7
ryanfay
ryanfay's Avatar
I'm sure they're legitimate.
Old 07-17-2017, 05:57 PM   #8
culberro
culberro's Avatar
They require washers to center the rod in the piston, FYI.
Old 07-17-2017, 05:58 PM   #9
culberro
culberro's Avatar
Have you actually called Wiseco?
Old 07-17-2017, 07:29 PM   #10
poulrais
poulrais's Avatar
CP don't make these forged 96,5 mm pistons anymore???
1990, Volvo 740 16v +T
poulrais is online now   Reply With Quote
Old 07-17-2017, 08:51 PM   #11
Grr baby, grr
Call John V
Old 07-17-2017, 09:26 PM   #12
Ilvmetal
Ilvmetal's Avatar
Going to ring John tomorrow and hope for the best.
Old 07-18-2017, 04:32 AM   #13
John V, outside agitator
Of course they do,, any compression, valve pockets done off a 16v head so they are correct. Choice of compression height depending on which rod c-c, pin diameter according to which rod...like early JVAB Chevy .927" or Volvo 23mm or later JVAB 22mm
The only thing you have to watch out for on ALL aftermarket rods is the piston float between bosses and that's only a problem with stock rod...And who in their right mind would be taking a chance with the stock rods when rods cost so little?
(Volvo with their piston steer rods and narrow big end means the sides of the pin bosses must be straight and 25mm (assuming a small end width of 24.75mm) Virtually everybodys raw forgings have a larger "gap" in the region of 28-29mm so to get the right float, you must use spacers.. That, unless somebody works TB cheap might cost half what a set of rods cost..See? Crazy not to go rods at that point.
I'm putting in an order to CP for 2 sets of B230 long rod n.a motors later today.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 07-18-2017, 04:33 AM   #14
call maybe a bit after noon your time..I'm up late reading.
