hmm, why would it roar on startup, when it is cold(ambient) and supposed to slip easily?
Wouldn't startup be the quietest time, and the clutch would be at it's loosest?
Your explanation makes little sense to me, as the temp of the clutch on a parked car will never go down once the engine starts.
What's not clear?
On startup, the silicon fluid has not been sheared and is arranged throughout the clutch hub. This results in a mostly locked up condition. As soon as the thermostatic bi-metallic spring stays in the "cold" position on the front of the hub (cold outside, cold engine for example), the internal pump in the fan clutch pulls the fluid and directs the path of it such that there is little fluid being sheared against itself and the fan freewheels. For the first 30seconds to minute or whatever or as you first take off though, the fan is locked. Thereafter, as you drive throughout the winter, particularly with the heater on, the fan stays pretty much completely unlocked.
A small (or large..whether unlocked or locked) amount of air that is pulled through the radiator is always wafting over the bi-metallic t-stat spring on the front of the clutch hub. This spring is attached to a valve that directs the fluid flow in the hub. Over sheared fluid or a leaking or damaged hub will result in improper operation. On ones with over-sheared fluid or that would freewheel too much for the temperature, I would simply wind the t-stat spring a little tighter and smash it back in place to keep the car on the road without replacing the clutch. Works for quite a number of years, but isn't particularly efficient for fuel economy or a correct repair compared to replacing the fluid or clutch if leaking, worn or damaged. Many do not leak, but the fluid needs to be replaced.
By this mechanical means, it is doing as "Captain Bondo" describes a cold side switch or ECU control would do more or less;
bringing the water at the outlet of the radiator to an acceptable temperature (whatever that may be for your given engine) that the t-stat can regulate the engine temp. It works pretty well when it's working right. Seems good for ~100K-200K depending on use/duty etc before fluid change or replacement is required, or uh..reliable old hooptie car/clutch operation spring mod in CA LOL.
It can't be *that* terrible for fuel economy. 21-23mpg city in 740 turbo M46 pretty stock in excellent mechanical condition driving pretty normally, 28-32mpg highway 60-75mph cruise on, no real heavy load, A/C and hot or not. Savage beating on the car...probably bad fuel economy no matter what?
Nothing is perfect and lasts forever over time. Whether you use an appropriate electric cooling fan setup for the duty/use or a mechanical t-static clutch, or mechanical hydraulic fluid drive, some service and/or inspection will be required. If using the former, larger radiator, alternator, and appropriate control would be wise comparatively, generally.
A TIC car pulling a trailer at high elevation over time with the A/C blasting cold on a very hot day with water cooled turbo and perhaps oil/water heat exchanger/cold oil warmer is going to require a massive cooling system, especially if longevity is the primary concern.
The electric fan has it's advantages:
-Low mount sensor possible (if more than half the coolant is missing with any fan under stress, this will probably be problematic)
-Blade optimized for fixed speed (or two)...though many are variable speed/many many speeds now for noise and start-up current draw more than overall capacity (usually second fan or "hi" seed is used for that regardless).
-Less water pump wear (volvo specific?...not driven off the water pump on the Toyota always)...outta balance fan blade or shot clutch, belts and accessory bushings it will be more affected by I will definitely admit. I have almost 200K on a clutch fan water pump at the same time...CAKED in rust.
-Packaging flexibility (lol on the stockish volvo)
-High revving engine flexibility (it has a turbo on it, eh?)
-Theoretically more airflow at idle than a good clutch fan for A/C idling. (haven't really observed that significantly)
-Quieter...I guess? *shrug* Amazing any of you would point that out over your stereos and exhausts.
(all I care about is that first, second, and third reason more or less on the stockish volvo turbo driven everywhere)
In a light car, lots of airflow and frontal area, no A/C, N/A, with the heater on, not used for towing, fine. Barely need a fan/might not need one.
Hydraulic drive is kind of best of both if properly controlled, but can have costly wear parts, relatively, and install is pretty tailored to the car.
