Sjeng
- Sep 3, 2017
I am running wasted spark ignition on my 940.
Using the miata (mitsu j702t) power stage which also has a tach output.
The tach output of the power stage is low voltage, and my instrument cluster requires a high voltage. So I used this circuit to generate a high voltage signal, as suggested in the wasted spark thread:
I used a simple relay as a coil, and wired the power stage tach output to the 1K resistor.
It works okay, I have a tach signal. However, when the rpms increase to over 5000 then the tacho starts to bounce and it will not show the increasing engine speeds, but keeps oscillating around 5000.
Any ideas what could be the problem here?
Love to hear any suggestions.
