Old 05-19-2017, 08:16 PM   #1
Slimssousa
Slimssousa's Avatar
Question Junkyard Run!!!!
Going on a junkyard run for my Volvo 740. Has 318k miles on it. It's pretty beat down but runs semi smooth. Anyone wanna tell me what some parts I should scrap off of salvage volvos? My junkyard has an ass load of 240s and 740s. So far I will get new seatbelt hooks, maybe newer fuel injectors that are healthy. I'm kinda deciding if I should just get BG44k (hardcore injector cleaner)
Slimssousa is offline   Reply With Quote
Old 05-19-2017, 08:18 PM   #2
Buy all the 700 parts and flip them in Turbobricks for sale, you'll be rich beyond your wildest dreams!
how psi a stock can support?
Old 05-19-2017, 08:29 PM   #3
Khrrck
Professional Amateur
Any pieces of trim or lights which might be broken on your car. #1 thing I wish I went for last time I was in the yard.
'87 240 budget wagon.
Old 05-19-2017, 08:58 PM   #4
Slimssousa
Slimssousa's Avatar
Will do.
Old 05-19-2017, 11:53 PM   #5
Mr. V
Mr. V's Avatar
fuel pump relay
Rear tail light assemblies
AMM
fuel pressure regulator
battery tray (they rot)
Instrument cluster (remove entirely from dash)
Old 05-20-2017, 12:09 AM   #6
Slimssousa
Slimssousa's Avatar
Where is the Fuel pressure regulator located at, and where is the fuel pump relay at? Sorry I'm a noob. Still learning my car I got about 3 weeks ago
Old 05-20-2017, 12:12 AM   #7
Shifted
C&M '17 Survivor
Shifted's Avatar
Power stage
Originally Posted by ME II View Post
Without mistakes there is no learning.
"I think that man was put here on earth to live, not just to exist" -- Robert 'Evel' Knievel
Shifted is offline   Reply With Quote
Old 05-20-2017, 01:25 AM   #8
Mr. V
Mr. V's Avatar
FPR is in front of intake manifold, on top.
Fuel pump relay is behind the fuses, which are behind the removable ashtray.
Old 05-20-2017, 02:20 AM   #9
Slimssousa
Slimssousa's Avatar
Thanks. Already got FPR out, the relay is gonna be hard to get out
Old 05-20-2017, 02:37 AM   #10
Shifted
C&M '17 Survivor
Shifted's Avatar
Originally Posted by Slimssousa View Post
...the relay is gonna be hard to get out
Not unless you're going in through exhaust pipe... pull up on the thingie under the ashtray, haul it outta there and it's an easy reach-around.
Grab 'em all, spares ftw.
Old 05-20-2017, 02:38 AM   #11
Otto Mattik
Otto Mattik's Avatar
On later models the FPR (fuel pump relay) can be found under dash behind glove box connected to a wiring harness. It is a lager size relay typically white in color, like this:
https://www.fcpeuro.com/products/vol...80-940-3523608
IIRC the K-Jet version is green:
https://www.ipdusa.com/products/6934...ith-k-jetronic
Originally posted by Jack
"You talk about parts cannon but you throw the Obamacare diagnostic tool orgy onto this like it's a cloned embryo of baby Jesus"
_______________________
Future need of elf assistant for interior work - cash/beer option
Old 05-20-2017, 02:57 AM   #12
Slimssousa
Slimssousa's Avatar
Might as well haha. Nothing wrong with some spares. Do you know by chance if FPRs on turbo and NAs are the same?
Old 05-20-2017, 04:02 AM   #13
Shifted
C&M '17 Survivor
Shifted's Avatar
Yeah OP... what year is your stuff?
Does make a difference, occasionally.
Overalls with big pockets ftw.
Old 05-20-2017, 07:14 AM   #14
dytha99
Fuel door spring...$25 part most places online.... usually free at my yard.
Idle air control valve
The tool set torx bits and screwdrivers... and 10mm wrench to keep under your hood for quick battery disconnects.
Front corner lights if they match
Check the fuel pumps... If they look new buy them. Got a damn near new fuel assembly from the tank of a junker for $20
Side mirror glass
Posted via Mobile Device
dytha99 is offline   Reply With Quote
Old 05-20-2017, 01:07 PM   #15
Slimssousa
Slimssousa's Avatar
91 740 na
Old 05-20-2017, 01:36 PM   #16
Mr. V
Mr. V's Avatar
Assuming the FPR is behind the ashtray:
Pull out ashtray and then remove the plastic cover behind it that holds it in place: you'll be able to see part of the fuse array, but there is still stuff above that needs to be removed.
Look at the area of the cigarette lighter: there are two screws to remove, and one is weirdly angled.
With the screws removed the top piece can be removed, and inside you'll see the assembly holding all the relays.
The FPR is second row in, toward the left.
Old 05-20-2017, 02:49 PM   #17
nitroboie
Grab a bulb failure sensor relay while you're at it. It's a red cylinder. It can fail leading to none functioning brake/tail lights and cruise control not working.
'90 244
'94 945T ipd springs, sways, brace, 11psi, TLAO fuel, wasted spark
nitroboie is offline   Reply With Quote
Old 05-20-2017, 02:51 PM   #18
BUY ALL THE 700 PARTS!!!!
