Old 05-19-2017, 08:22 PM   #1
driedle
driedle's Avatar
Default Not really very Turbobricks like...
Hey everybody...
Found some really good oil.
It's Royal Purple synthetic oil, but on top of that, it is diesel oil and has the same detergent package as Rotella, etc. It's $36 for the 4-quaart container, so it's only $8.00 a quart.
Not really Turbobricks kind of stuff, but it IS mighty fine oil.
It does get expensive on the 164, however, since it uses 6 quarts of oil....
Dave Riedle
driedle is offline   Reply With Quote
Old 05-19-2017, 08:43 PM   #2
Cwazywazy
Cwazywazy's Avatar
Just gonna say I've never had any issues with Rotella. T6 synthetic is sometihng like $20-25 for a gallon.
Old 05-19-2017, 09:09 PM   #3
TestPoint
TestPoint's Avatar
Never had any oil related problems at all . . . ever. Caught Mobile 1 5 qt at Walmart for less than $22. $4.50 / qt.
Ford V8 Conversion Manual -
Old 05-21-2017, 01:21 AM   #4
Slimssousa
Slimssousa's Avatar
I'm running 20-50 on my NA 740 lol. Car has 300k miles
Slimssousa is offline   Reply With Quote
Old 05-21-2017, 06:16 PM   #5
driedle
driedle's Avatar
I hope everybody does not think I was saying "use this oil or else..."
I have had outstanding results with Royal Purple, and have used their oil in all of my street cars and race cars for years. I'm using it in the 164, as well as the Royal Purple gear oil in my gearbox and rear end. I have never had an issue, and testing seems to indicate that it has a superior metal wear package based on standard bearing tests. Of course it also has a diesel-spec detergent package as well.
The 15W-40 diesel oil is not advertised much, and I think it might be the best of all worlds in an older Volvo.
I ran Amzoil engine flush first, and then added the oil. Synthetics clean the engine much, much better than Dino oils, and I am hoping I will be able to eat off the inside of the engine when I replace the rocker cover later this year. I will let everybody know what the results are.
Also, I think with the limited miles I run every year with the 164, I may be able to get two years out of the oil.
Dave Riedle
Old 05-21-2017, 07:01 PM   #6
sisu_slay
this stuff is good for the older cars, but it has a bit too much molybdenum to be using in the b27/b28, clogs those followers up.
i also run the amsoil for marine diesels for cleanliness, of course, you could always do the dyno oil with a quart of diesel fuel trick for 20 minutes
sisu_slay is offline   Reply With Quote
