Old 02-16-2009, 07:15 AM   #101
testhest
For a user on another forum, I took some pictures of a flywheel from a 740, with a 940tdi clucth and pressure plate, and release bearing.
Perhaps this could be of interest to others in this thread.
The pictures can be found here http://s233.photobucket.com/albums/e...thest/Kobling/
The parts I have ordered, have been ordered through Skandix.de. The clutch kit is SACHS make, and the numbers are:
Clutch: 1862 468 031
Pressure plate: 3082 204 033
Release bearing: 3151 189 232
Above parts are all included in the clutch kit: 3000 696 001
All numbers are SACHS refence numbers.
Kind regards - Bjarne Warming
Red 945 Classic '96, B230FK + M90, w. 3" dp and cat + 2,5" catback.
testhest is offline   Reply With Quote
Old 02-16-2009, 07:24 AM   #102
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
awesome work! this is the info you really need when converting to the 700 series.
Also you want to share how much you where set back on that set?
Old 02-16-2009, 08:17 AM   #103
testhest
Hi,
Well, the conversion is not just for the 700 series. The conversion is when going from dual-mass flywheel to dog-dish/single-mass, and using an M90 gearbox. I just found a flywheel from a 700 series.
The clutch kit was around 175 EUR + shipping (around 17 EUR).
/edit: the price is plus VAT, which is 19%, and thus the price is close to 208 EUR
Last edited by testhest; 02-16-2009 at 11:18 AM.. Reason: price quoted without VAT
Old 02-16-2009, 08:21 AM   #104
Mr.Borrie
Mr.Borrie's Avatar
That's a good price, thanks (ordered mine already on ebay for 100+ euro's but not sure on the partnr's .. so i might need another set, why i asked :P)
Old 02-16-2009, 08:57 AM   #105
frpe82
Guest
Originally Posted by MrSteve View Post
I recall Fred found that pivot ball spacing was necessary in his M90 install as otherwise the clutch would not work.
There is a risk of hitting the rear part of the transmission housing when the ball is not spaced out a little, yes.
3 washers or so is about right. But that also depends on your flywheel.
Old 02-16-2009, 10:53 AM   #106
JW240
All idiot, no savant
JW240's Avatar
thats the exact same set i bought! Mine was a bit more expensive but the release bearing was in the set. Mine came from Scandix too.
240 | 1991 | 326 KKm | B230F+T | Cossie T3 60/63 | M90 | TrueTrack
Husaberg FE450 '12
Old 02-16-2009, 11:14 AM   #107
testhest
Well, the release bearing was in mine too. Upon reviewing the price again, it seems that the price I quoted was without VAT. My kit also included the release bearing in the price. VAT is 19% in Germany, and thus the price is close to 208 EUR.
Old 02-21-2009, 07:43 PM   #108
Mr.Borrie
Mr.Borrie's Avatar
I got the wrong kit maybe..
Sachs kitnr:4000 874 001
Clutch: 186 246 8031
Release bearing: 3151 189 031
Am i totally doomed with this kit, it was a but of a guess on ebay but the pressure plate seems to be correct at least
Old 02-21-2009, 08:06 PM   #109
Fivehundred
Fivehundred's Avatar
That should be fine, 4000 874 001 is the M90 turbo intercooler clutch kit. All you now need is a Motronic dog dish flywheel, which I can't remember whether or not it exists.
Fivehundred is offline   Reply With Quote
Old 02-22-2009, 04:55 AM   #110
BB-Q
BB-Q's Avatar
Isn't it the same as the LH2.4 one? I'm sure my B230ET had the same flywheel as a 940.
Originally Posted by foggyjames View Post
The man is a pimp, and a fast one at that...
Originally Posted by frpe82 View Post
He's got that "crazy Mark" look in his eyes...........
1992 245 SE B200F, M47, Low and painfully slow.......
BB-Q is offline   Reply With Quote
Old 02-22-2009, 06:19 AM   #111
CHESH740R
lacking enthusiam
CHESH740R's Avatar
Location: England, that little island that everyone fled except me.
All M46'd Motoronic cars had the dog dish flywheel as standard. Its not the same as the LH2.4 due to the differing crank sensors.
87 745 Turbo & 88 744 Turbo & 96 945 Sport Turbo
1 RIP, 1 750R and 1 Sold Many moons ago!!!!
05 Jeep Grand Cherokee for DD Duties these days.
CHESH740R is offline   Reply With Quote
Old 02-22-2009, 07:59 AM   #112
Fivehundred
Excellent, couldn't remember if it was flat or not. Looks like he's good to go.
Old 02-23-2009, 10:12 PM   #113
foggyjames
Ryan's spanner monkey
foggyjames's Avatar
Anyone got any ideas what an M90 with part number 1208650 (definitely xxxx650...I'm pretty sure it started 1208...and I'm too lazy to go and look again ) would be?
It supposedly came from a 1997 940 with a B230FK, but that part number doesn't match anything I can find, including in Vadis.
cheers
James
'05 V70 D5
'88 360 Turbo Intercooler
'84 360 GLT
'81 343 GLS R-Sport
'80 343 DL
'69 164
PM me if you're looking for Euro parts!
foggyjames is offline   Reply With Quote
Old 02-24-2009, 10:43 AM   #114
frpe82
Guest
cheers
James
And I guess you are sure that it is a redblock M90?
Old 03-01-2009, 08:15 PM   #115
foggyjames
foggyjames's Avatar
Sorry about the slow reply...
I can't be entirely sure until I try it, but 99% certain. I think I'll try counting shaft rotations in 5th...
cheers
James
Old 03-05-2009, 05:55 PM   #116
RobSmith
RobSmith's Avatar
Hi James
I have my 940 dangling around up on blocks of wood at the moment so I can fix the rear brakes. I can get underneith easily enough to look what the part numbers are. That is an M90L2 and I have another M90 in the shed. I will look at that too.
I will also be changing the clutch and binning the dual mass flywheel soon.
Rob
1981 / 245 DL / dung brown / B21A / M47 / 3.3:1 axle from auto (5th not used much) / Scrapped.
1982ish /240GLT Estate/silver/Scrapped
1994 / 940s Turbo Auto Estate / B230FT /metalic green / Scrapped
1993 / 940s Estate / B230FB / Blue / Scrapped
1992 / 940s Estate / B200? / White / Gone.probably scrapped.
1967 Amazon Estate (Sold)
Current Cars...
1998 940 Celebration /B230FK /M90L2/Galaxies (Blue)
1998 940 Celebration Standard (Red)
1998 940 Celebration Standard (Purple)
RobSmith is offline   Reply With Quote
Old 03-05-2009, 08:53 PM   #117
foggyjames
foggyjames's Avatar
That's be great Rob, thanks!
cheers
James
Old 03-06-2009, 06:26 PM   #118
RobSmith
RobSmith's Avatar
My M90L has a number 1208837 or 1208337. The 8 or three is where the sticker is damaged so cant tell if it is a 3 or 8
That came from a 1997ish car
My M90L2 has the number P 1208947 and is in my 1998 Celebration 940.
Neither match yours though..... oh well
On a similar M90 note: I ordered a Valeo 826450 clutch kit as our local company does not do Sachs parts.
Anyway I opened the box and inside is a Sachs clutch. So that is good
Rob
Old 03-06-2009, 07:51 PM   #119
Steve940Estate
Steve940Estate's Avatar
I have been looking for numbers on my M90, no sticker but there is a cleaner rectangle where a sticker probably was. Is that where it should be ?
I've got a clutch and flywheel coming in the post. Hopefully it will turn up on Monday.
What are you planning to do about spacing the clutch pivot ? I haven't had a chance to study it yet. Putting a few washers behind it is suggested, would a proper spacer be better ?
Steve940Estate is offline   Reply With Quote
Old 03-06-2009, 10:29 PM   #120
foggyjames
foggyjames's Avatar
Rob...I think it's probably a 9...i.e. 1208937...an M90L. Vadis says...
1208937 - "B230FK 4DRS Chassis 238058- B230FT"
1208947 - "B230FK 5DRS Chassis 198077-"
I just checked this against one of Fred's posts at the beginning of this thread, and it's true - there is a different box for saloons and estates, and those two part numbers are the 'final' versions of each box. In other words, the L2s are estate only.
Why would Volvo put the "ultimate" box in an estate only? Is it not possible that the L2 is different to the late "937" M90L only in that it has a taller 5th gear ratio, and that "937" M90Ls (i.e. from late saloons) have all the strength upgrades? It doesn't seem to make sense that estates would have stronger boxes than saloons of the same age.
Rob...are you able to check the part number of the output shaft casing (of the loose box will do...don't want you crawling in the dirt!) when you get a moment, please? I'm talking about the number cast into the rear of the box, on the opposite side to the reversing light switch. If yours is the same as mine, I think it's safe to say that the part number I quoted earlier (1208650...will confirm that I got that right tomorrow) is for that section of gearbox casing only.
I'll try counting output shaft rotations in 5th tomorrow, too.
cheers
James
Old 03-07-2009, 08:43 AM   #121
frpe82
Guest
Not really. Generally just assumptions.
All the "Classic" 940's got the L2 box unless you specified it to be equipped otherwise. It is just that the saloons are much more rare.
The L2 also came in a big chunk of 940's in 1997, but most of them were estates since those usually had a different engine (B230FK vs. FT) and different rear end ratio. Probably due to the cargo capabilities, the roof rails and the tow hitch.
Old 03-07-2009, 05:36 PM   #122
foggyjames
foggyjames's Avatar
So is there more than one part number for the L2...one other than 1208947? We know the "937" is a plain M90L, and Vadis says that box went right through to the end of production for saloons. "937" (saloon) and "947" (estate) are the only two redblock M90s at the end of production, so either Vadis is wrong about 947 being 5-door only, or L2s only came in estates. It just doesn't tally, otherwise...check out your own list on the first page - it only lists the L2 against 5 doors. Sadly Vadis doesn't say what version of the M90 is associated with which part number...that would make this a lot easier.
After 1995, here in the UK, FTs were never common....the vast majority of cars in all years and both body styles were then FKs.
Rob - is your Celebration a saloon or estate. If it's a saloon, that would prove Vadis wrong...unless it had a box-swap at some point
cheers
James
Old 03-07-2009, 06:08 PM   #123
Steve940Estate
I looked at the part numbers I have on my box, the only one I can read is 1023650, which is the part number for the end cover casting I think. This is out of a 1996, M reg car 230fk. I'm not sure what the numbers are on the one in tha car but was interested to see if they are the same.
I guess the actual version number is on a sticker like the rear axle.
Old 03-07-2009, 08:11 PM   #124
foggyjames
foggyjames's Avatar
Yeah, the sticker is very much like the one on the axle...when it's present
It looks like the '650' number is indeed just for that piece of the casing...
cheers
James
Old 03-08-2009, 03:17 AM   #125
frpe82
Guest
cheers
James
The FK cars were the ones normally associated with the L2 box actually, even though they came in cars with both FK and FT engines.
And they exist in saloons as well. It is just that it might be...
1: Regional.
2: The "Classic" saloons are much more rare.
3: The saloons never came with the L2 unless it had a package/configuration that required it.
And the "Classic" saloons I have seen in real life can be counted on one hand, where as only one of them had the L2 as far as I know. Most of the "Classic" estates had the L2, and most of them had the FK engine.
So that leads me to beleive that the Classic saloons never normally got the L2 box. Only if it was specifically requested as part of a package when the order was made.
