alschnertz
Enough already!
- Oct 4, 2009
- CT
1995 854T; 258,000 miles
Can an exhaust leak downstream of the catalytic converter cause a 4-4-3 (catalytic efficiency) code?
There is a small leak at the front pipe /rear pipe junction and also a hole on the top of the muffler. Front O2 sensor was changed at 216K and the rear sensor at 250K.
I was told that an exhaust leak downstream of the converter could cause the 4-4-3 due to a "lack of vacuum" in the exhaust system after the cat. That just sounds unlikely to me.
