Old 06-21-2022, 09:08 AM   #1
kittysgreyvolvo
kittysgreyvolvo's Avatar
Question EGR Intake Port Blocking / Blanking Plate
For LH-Jet / EZK116 1991.
I have yet to find a ruler and measure the intake port EGR union.
I have the exhaust manifold EGR plug machine bolt and a copper washer.
Yes, I've searched the forums here and afar about EGR delete.
Else, some 14 gauge steel and washer with a gasket section making seal on the intake port manifold.
Thank you!
Volvo "Buttermilk" MacDuff
I've owned only Volvo 240s since 1985.
RIP, yet beloved:
1975 244 DL (B20, M40)
1976 242 DL (B21, M46, Moonroof - an SRO?)
1979 245 DL (B21, M46)
1979 242 GT (B21, M46, Moonroof - an SRO? Grey Market from Holland)
Currently owned, beloved, operating, driven, if occasionally:
1990 240 (245) DL (B230, M47 II)
1991 240 (244) (B230, M47 II, Moonroof. Grey Market from Germany)
1992 240 (244) GL (B230, M47 II, L-jet 3.1, Moonroof)
kittysgreyvolvo is offline   Reply With Quote
Old 06-21-2022, 03:44 PM   #2
TheMenaceSD
I made one on my 3d printer out of ABS and used it and the gasket to seal to the intake manifold.
TheMenaceSD is offline   Reply With Quote
Old 06-23-2022, 10:33 AM   #3
kittysgreyvolvo
Thumbs up
Hi and thank you,
Would you have a cad file or drawing you used to create your 3D print of a EGR blocking / blanking plate, please?
The dimensions, bolts hole on center, and so forth.
Could you attach you CAD / drawing file here or send or link, please? I don't own a 3D printer yet maybe have the plate fabricated.
Else, a soup or frozen juice lid, maybe two stacked, and Permatex Red RTV with washers to secure the lid metal and secure it under the EGR flange bolts on the intake. As a temp fix.
Several responses have said cutting the EGR pipe intake manifold end, and welding it closed.
I'd like a blocking / blanking plate.
Thank you,
Bruce
Old 06-23-2022, 11:54 AM   #4
TheMenaceSD
Let me see about getting the file. I know people have cut the pipe and used a nickel to cover the hole and bolt it down.
Old 06-23-2022, 12:07 PM   #5
The Librarian
Volvo sells a block off plate kit for the EGR port on the intake but it ain't cheap.
https://www.tascaparts.com/oem-parts...IFJlc3VsdHM%3D
It comes with #53, 54 & 55.
Old 06-23-2022, 12:11 PM   #6
Acke
Acke's Avatar
I used the EGR stuff as model and cut a matching gasket and cover plate from 1,2mm steel. Thicker would probably have been better, but it has been working good so far.
Acke is offline   Reply With Quote
Old 06-23-2022, 05:07 PM   #7
kittysgreyvolvo
Default Volvo LH-Jet US EGR Blanking / Blocking Port
Thank you. Art B. posted on a service kit yet is listed as NLA. On the Genuine Class Parts sales part manual, something like "shall not return" or something
Different diagram.
How do you know the kit comes with #53, 54 & 55. Did you buy this kit?
So I'll verify if whether the LH-Jet EGR blanking or the cold start injector flange.
Your diagram:
Old 06-23-2022, 05:20 PM   #8
kittysgreyvolvo
Default Cold Start Injector Blanking Plate?
If you look on this page:
https://parts.volvofw.com/p/Volvo_19...62/271658.html
I'll ring the dealership ....
There is a diagram of the kit, and the parts look like a plate for the cold start injector port.
[QUOTE=hiperfauto;6272236]Volvo sells a block off plate kit for the EGR port on the intake but it ain't cheap.
Old 06-23-2022, 05:35 PM   #9
The Librarian
I didn't buy the kit but the parts catalog shows what parts come in the kit. I verified that the gasket in the kit is the same one used for the EGR pipe.
The kit appears to be available. Check with your local dealer to see if they can order it.
Old 06-24-2022, 01:05 PM   #10
kittysgreyvolvo
Default Volvo part# 271658 prolly NLA allslow ...
I rang up the dealership in Lynnwood, WA.
The parts guy indicates he cannot find the kit available as far as his Volvo Cars part network can see.
I don't want to destroy the components like to cut up the second EGR pipe to make a sealed flange for the EGR intake port. If I had my parts collection here, I'd be able to preserve EGR with not so rusty EGR pipes and a newer or unused EGR valve.
I'll call a few more dealerships. Yet what is available with OEM Volvo parts and what is *actually* available are not the same. At least we have some support for RWD models.
Thank you.
Old 06-24-2022, 01:07 PM   #11
kittysgreyvolvo
Default CAD model / drawing please, sir!?!?
Like to keep the components and not to cut up the second EGR pipe to make a sealed flange for the EGR intake port. If I had my parts collection here, I'd be able to preserve EGR with not so rusty EGR pipes and a newer or unused EGR valve. Well, maybe.
Old 06-24-2022, 02:27 PM   #12
It's not a precision fit part, so you can make one if you have a hacksaw and a vice. Start with a suitable small metal plate, such as: https://www.homedepot.com/p/Steel-Ci...-50R/205124442, or look for nailing plates in hardware if you want something thicker.
Smear the EGR mount on the intake manifold with some exhaust soot, press a clean sheet of white paper against it, and rub to create a template. Center-punch and drill the metal plate to match, then cut to rough size and smooth with a metal file.
Old 06-26-2022, 07:23 PM   #13
kittysgreyvolvo
Thumbs up
Thank you. I do not have all my tools here so fabrication is a problem.
Thanks.
