Old 06-13-2018, 10:07 PM   #1
89_740Turbo
89_740Turbo's Avatar
Default Dave Barton's custom boost gauge face install/MBC installation on 5spd 740Ti
While looking to install a new MBC on my 740Ti, I was looking for a Boost Gauge. Obviously there are the pods which a lot of people use but I want to eliminate as much clutter as I can and keep things neat.
dl242gt told me that Dave sells custom 740 boost gauges to replace the stock on on the dash cluster. After taking a look, they are amazing. So here's my install documentation of Daves custom Boost Gauge face and how it looks plus my new MBC.
First dl242gt and I removed the dash cluster and removed all connectors. The battery was disconnected from the car at this point.
Here it is totally removed. The rear side of it
Here is Daves custom Boost Gauge face to replace the stock one. He offers 3 different kinds but this one was the most visually appealing and useful one. Its also a matter of preference. Its very clean and neatly made.
Following Daves instructions, we removed what should be removed. Here is everything that you will need to take off.
You can peel off the stock boost gauge face with your finger nails or a flat head screw driver.
dl242gt taking it off.
Here is everything being screwed back in. The things that we removed of course hahaha
Here is the new boost gauge face in. Thanks Dave for making it look so amazing!
Here is what the whole thing looks like with it on
Now onto the boost controller. Here is my current setup.
Removal of the tubing. This was pretty straight forward.
After the new tubing is set up. Separate hoses for the MBC
Here is the new MBC to go with Daves new boost gauge face. Nice and red like the car
Old 06-13-2018, 10:16 PM   #2
89_740Turbo
I dont know why the pictures are so big but yea. I was running stock PSI before. After installation, we set the boost to zero. Took it to the highway and floored it in 3rd and floored it in 4th to max RPM in order to see the current boost PSI. We got about 6. Nothing crazy.
Once we knew the stock PSI, we turned the knob 2 turns. One turn was about 1.5PSI. AFter 2 turns, we went back onto the road, floored it in 3rd and 4th. Holy **** was the power difference huge. The car is a lot faster now. After flooring it we noticed it was at 10 PSI where it currently sits. I dont plan on changing it. I might go to 10.5 but Im not itching for it yet until I get a new NPR.
Old 06-13-2018, 10:20 PM   #3
oldschoolvolvo
oldschoolvolvo's Avatar
When posting from imgur, choose “Large Thumbnail” before copying the img code. That will resize the pics to be more manageable when posted.
Glad you got the MBC hooked up and dialed in.
-Mike
1998 V70 T5
|Feedback|
Old 06-13-2018, 10:41 PM   #4
89_740Turbo
Duly noted. I'll come back and edit the pictures. I'm happy too. The car is about 190HP now and a lot faster. Once I get the new intercooler I'll up the boost to twelve.
Old 06-14-2018, 10:34 AM   #5
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
https://i.imgur.com/gpxmqsOl.jpg
Good mod, get an AFR gauge and turn it up! 10 is good, 13 is more better
1980 242 Turbo
2004 V70R
Uncleknucklez is online now   Reply With Quote
Old 06-14-2018, 12:38 PM   #6
Can play the blues
That was a fun day. A very nice well cared for car. We are thinking an exhaust, intercooler and simons ecu. Probably leave it at that and enjoy.
Old 06-14-2018, 03:58 PM   #7
89_740Turbo
Definitely exhaust, NPR and IPD cam. After that it's pretty much good
Old 06-14-2018, 04:03 PM   #8
sbabbs
sbabbs's Avatar
I did that years ago and now it's all turned black or fuzz has grown over it. I'll post a pic.
Might have something to do with me being near the river or the constant rain of water over the years.
Old 06-14-2018, 04:06 PM   #9
240wagonguy
Very cool. I should do this since my turbo gauge is sitting on my desk currently.
Old 06-14-2018, 07:30 PM   #10
89_740Turbo
Why would the river or rain affect it. Its inside the car lol
Old 06-14-2018, 08:29 PM   #11
89_740Turbo
I'll be able to run 13psi with an AFR? I thought I would need a newer intercooler before upping the boost.
Its only a TD04-12b right now as I'm keeping the stock turbo in and upgrading everything else first before I throw in a bigger turbo
Old 06-14-2018, 08:43 PM   #12
oldschoolvolvo
IMO a bigger intercooler isn't a "requirement" to run 13psi, but it is certainly a good improvement and will help keep you away from detonation. However, without a wideband AFR gauge it is just a guess on how your setup will handle increasing the boost. I agree with your method of upgrading the supporting items before changing the turbo, but even with all the right "supporting mods" it is still a good idea to monitor the AFRs and a wideband will give you direct feedback / warning if things aren't right under boost.
Some good reading material: http://brickspeed.net/forum/showthread.php?tid=903
Re: sbabbs turbo gauge...
My opinion is that since the Dave Barton gauge faces are a printed item (paper & ink), prolonged exposure in a very humid/damp environment will make the ink bleed as shown. I have a DB prancing moose magnet on the back of my car and after a few years of living through normal outdoor conditions (rain, snow, etc), the ink started to bleed around the edges...not a knock on the items just the nature of the beast.
Old 06-14-2018, 08:50 PM   #13
89_740Turbo
A bigger intercooler isn't a "requirement" to run 13psi, but it will certainly help keep you away from detonation. However, without a wideband AFR gauge it is just a guess on how your setup will handle increasing the boost. I agree with your method of upgrading the supporting items before changing the turbo, but even with all the right "supporting mods" it is still a good idea to monitor the AFRs and a wideband will give you direct feedback / warning if things aren't right under boost.
I'm at work for another 7 hours so I'm going to read that link you shared. With that said, new order of operations:
1. AFR
2. Intercooler
3. IPD Cam
4. Exhaust (preferably the same time as the IPD cam)
5. Simons ECU/EZK
After that, I'll have achieved what my current goals are for the car. Then Ill be saving up for a T5 swap. Then a larger turbo.
Old 06-14-2018, 08:56 PM   #14
Can play the blues
A wide band is a good idea and was on the agenda in our discussions. To that end and to help cover any fuel he already has a chipped LH2.2 ecu. We just didn't put it in yet. I also didn't want to put the clutch to it's limit since there are more changes ahead and it's the daily driver. So we put the boost at a safe level for a stock clutch.
Old 06-15-2018, 04:05 AM   #15
89_740Turbo
Whats the stock clutch limit again?
Old 06-15-2018, 09:06 AM   #16
Uncleknucklez
bruspeed
13? 15? It's very dependent on the health of the clutch and flywheel.
My b21 clutch slipped at 13 psi
Old 06-15-2018, 02:40 PM   #17
Can play the blues
My B21FT flat flywheel clutch slipped at about 12psi. So we weren't going to risk it with this car which is original at 138k miles.
Old 06-18-2018, 06:22 PM   #18
dbarton
Bored Member
dbarton's Avatar
That face is not laminated, because I found an unlaminated finished matched the matte finish of the other gauges better. It certainly could be and that would protect it, but I'm just not sure if the finish would look right. Those were developed a lot of years ago. It's the only printed thing I remember ever making without some sort of lamination.
Simon. Email me. I'll gladly send you another. I've never heard of such a thing happening til I saw that pick.
Also, I have and always will happily replace a sticker if the weather kills it. Just email me.
Dave
Old 06-21-2018, 06:45 PM   #19
Can play the blues
That was the first time I installed a gauge face and it was a pleasure and looked great in there. Such a nice upgrade.
