![]() A couple years ago I worked with Cometic to make a head gasket suitable for up to 93mm bore for my B30.
Finished the engine early this year and ended up with a 92mm bore and 6mm stroked motor which yielded approx 3.5l. Cometic Part numbers are: 0.043" Thickness - PN H3270SP1043F 0.059" THickness - PN H3270SP1059F Used an off the shelf Wiseco forged piston and Nascar Carrillo rods. Had to have crank welded, narrowed rod journals and reground to smaller diameter journal to accomplish but was happy with results. https://www.youtube.com/watch?v=cV-Q1NaQOZk Neil |
![]() Sounds great! Looks like it's going to be a lot of fun in a car that barely weighs more than the engine.
#3 | |
The Librarian
![]() Sounds awesome! It revs quick for a B30. What's the compression ratio?
What kind of car is it in, a Marcos? NVM, I just saw your user profile: Quote:
#4 |
![]() SOUNDS AMAZING!!! What is that gauge that's just floating there above the manifold?
#5 |
![]() Join Date: May 2004
![]() Awesome!
#6 |
![]() That's pretty damn rowdy
'93 944 T - #TrophyVo '00 XC70 SE - Slow '11 XC90 V8 - Torque Monster |
#7 |
#8 |
![]() Compression ratio is 11:1.
It picks up revs so quick mainly due to the lightweight flywheel and clutch. Turns out that a tilton 153T nascar flywheel for small ford will bolt to B30 with a few mods. Rods and pistons are a fair bit lighter than stock also. The extra gauge was just oil pressure temporarily zip tied to intake during break in. |
#9 |
![]() Awesome result, thanks for posting both the info and the video.
#10 |
Stößelstange über alles!
![]() Wow.
Just wow. |
#11 |
![]() Hopefully you dyno it at some point. It always seems like the B30 doesn't 'scale' as you'd expect from a B20, but then people rarely go all out on a B30 build.
#12 |
![]() I got something like 185 hp out from my B30E with K-cam style camshaft, but it is not fully sorted out. Max torque comes in quite high rpm, so I might be cam timing issue or exhaust tuning thingy. I got std B30 E moose horns as exhaust manifolds
Before dyno, GT power simulation was made, giving quite close same performance results as dyno. |
#13 |
![]() That is bad ass. What kind of power does it make?
#14 |
![]() I’ll post after it runs on dyno. Right now I’m gettin break-in miles on it before putting the second valve spring in. Also working on an FI setup. Weber’s are great but think I can do better.
If someone can tell me how to post pics here I can show some more detail. Also running a quaife sequential gearbox that’s pretty fun. Neil |
#15 |
Turbo, what?
![]() Beautiful! Looking forward to hearing and seeing more.
Kyle - NLMGG: '91 244 NA DD/Track - General Leif: '71 142 Endurance Racecar - The General's FB page - Oregon Volvo Tuners - Died ![]() |
