Old 03-26-2017, 03:43 PM   #1
Sander
Good news everyone!
Sander's Avatar
Default Sander's 6.0 V12 745 project
I got far enough along now with it to make a new thread. Old thread (16V Turbo) here: http://forums.turbobricks.com/showth...165886&page=23
Short recap, I got the car in 2008 with the purpose of putting a V12 engine in it, but due to lack of working space or even a garage I decided to turbocharge it. It's a 745 GLT so it had a 16V engine already. After years the itch to put a V12 in there was still there and now I have a garage and enough space to do it. Then this showed up:
It's a Mercedes M120 engine. 6.0 Liter 48 valve V12 out of a 1992 S600. It's good for 408hp and about 600Nm of torque. I wanted to put a manual transmission behind it initially, but that would complicate things so much that I decided to go for a 722.6 automatic trans out of a late CL600 with the same engine. It is an electronically controlled 5 speed automatic that fits behind the engine. A guy in Denmark makes a stand alone controller for it, complete with paddle shifters etc. which I'll be using now (https://ofgear.dk/).
The engine is absolutely gigantic, 84cm long, 65 wide and about 60cm high. First problem is the oil sump is in the way. It's exactly where the Volvo crossmember with the steering rack is. I cut off the original sump and the oil pickup tube (the pump is all the way at the front) and am converting it to a front sump. Just need to find a drop down sway bar out of a V6 now somewhere.
Even the flat 16V brake booster is in the way, so I got a hydroboost unit out of a Ford Mustang Cobra. The master cylinder on there is also nicely sized for the Porsche Cayenne brakes I'm planning to use. Today me and some friends got around to dropping it in and positioning it. Next up is making the engine mounts and trans mount.
It's about as far back as I can put it. It'll need a pusher setup for the radiator as there is not enough space for the fan anymore. I'll also have to move the throttle bodies more forward as they are right between the strut towers. Originally, it has electronic TB's, but I'm converting it to manual ones as I plan to run MS3Pro on it (also no more distributors). I won't be finished anytime soon as there is still a lot to do, but to be continued.
Old 03-26-2017, 04:27 PM   #2
JPS
looks good! quick job getting that engine in there. i wish you the best of luck for this build!
JPS is offline   Reply With Quote
Old 03-26-2017, 04:32 PM   #3
okoye
okoye's Avatar
Nice! Do you happen to have any of the 16v stuff for spares ?
Old 03-26-2017, 11:41 PM   #4
FreeEMSFred
FreeEMSFred's Avatar
Ha! I just bought a different V12 with Volvo intentions. You're a bit ahead of me, though. Good luck! :-)
Old 03-27-2017, 12:11 AM   #5
HiSPL
HiSPL's Avatar
There are so many easier ways to get 400 hp.
But none of them sound like a V12, so good luck with it!
Beets taste like buttfeet.
Old 03-27-2017, 12:13 AM   #6
Gnomestur
Gnomestur's Avatar
That mr2 looks clean!
Gnomestur is offline   Reply With Quote
Old 03-27-2017, 12:30 PM   #7
Sander
Good news everyone!
Sander's Avatar
Thanks!
I don't have much left besides the engine itself, most things I've sold already. Are you looking for something specific?
Cool, what V12 did you get and what is it going in? We need more V12 powered cars in the world
Very true, the goal of this project is definitely not to get the most bang for the buck. Nothing sounds like a howling V12
Thanks I have a thread for that thing too here on TB.
Old 03-27-2017, 12:56 PM   #8
Mesoam
Mesoam's Avatar
08 XC90 R-Sport
Mesoam is offline   Reply With Quote
Old 03-27-2017, 01:04 PM   #9
tjek
tjek's Avatar
sander, please make it sound like this ^
1977 245 M50B25 "Sasha Orange"
http://forums.turbobricks.com/showthread.php?t=329198
sloppy craftsmanship
tjek is offline   Reply With Quote
Old 03-27-2017, 02:19 PM   #10
GTJordan
Been here for too long
GTJordan's Avatar
Ridiculous (In a good way)
Old 03-27-2017, 02:42 PM   #11
Sander
Good news everyone!
Sander's Avatar
Originally Posted by Mesoam View Post
That is the plan, yes I'll be making my own headers and full exhaust system. This one is good too (skip to the tunnel part):
Old 03-28-2017, 09:46 AM   #12
Sander
Good news everyone!
Sander's Avatar
Test fitting the Ford Hydroboost unit, it fits like a glove. Even the slight upward angle of it like it is mounted in the mustang is dead on. The TB's will be moved towards the front for easier access and hoses etc.
Plenty of space on both sides for the engine mounts and nice headers. I'm a bit surprised at how much space there is. Of course the 60 degree V angle of a V12 helps with that. I might end up modifying the oil filter housing and moving the filter to get more space for the header for cylinder 7.
Old 03-28-2017, 10:35 AM   #13
tjek
tjek's Avatar
is it possible to swap the intake manifolds left/right? that would fix the throttle body problem.
and that tunnelshot is great, we need more tunnels
Old 03-28-2017, 11:08 AM   #14
Thor
Thor's Avatar
You sir are my hero. Subscribed. Keep it coming!
1991 240 M-47 daily driver
Build thread: 91 240
Feed back: Here
Thor is offline   Reply With Quote
Old 03-28-2017, 01:39 PM   #15
Sander
Good news everyone!
Sander's Avatar
No that won't work, it's 1 big intake manifold and it slopes down at the front a bit for hood clearance.
Thank you sir, always good to have the god of hammers on my side
Old 03-28-2017, 02:32 PM   #16
M.H. Yount
M.H. Yount's Avatar
With plenty of V12 torque on tap, seems like you might be able to cut the runners shorter - and re-attach a plenum that has the throttle positioned where you can deal with it.
Old 03-28-2017, 05:18 PM   #17
Do work, Sander!
Old 03-28-2017, 06:01 PM   #18
M.H. Yount
M.H. Yount's Avatar
Come to think of it, ditch the mani --- 12 stack of ITB's....between the intake and the exhaust sound....well, you win. 2 starters?
Old 03-28-2017, 09:08 PM   #19
soclosenotnear
Purple 7/9 are awesome.
check my feedback here
Old 03-28-2017, 10:05 PM   #20
volvo?
That One Guy
Originally Posted by M.H. Yount View Post
2 starters?
I noticed that too. Seems crazy.
volvo? is offline   Reply With Quote
Old 03-29-2017, 04:35 AM   #21
mocambique-amazone
Think about Great Britain, Japan, India, Pakistan, Australia and ca. 46 other countries compared to the rest of the world.
And now....
you know why this engine is equipped with two places to mount a starter
Great project! subcribed!
regards Kay
Old 03-29-2017, 04:35 AM   #22
mocambique-amazone
doubled
Old 03-29-2017, 05:00 AM   #23
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Yeah.. it's 2 Starters, because Hybrid...
Old 03-29-2017, 07:21 AM   #24
Sander
Good news everyone!
Sander's Avatar
As mentioned, the starter is on the other side on rhd cars.
Initially I'll just cut off the mountings for the TB's and weld them on further forward. I do want to make a custom manifold somewhere in the future, maybe itb's indeed, but first I just want to get it running. The space above the engine is a bit limited too, especially at the front.
Do work, Sander!
I'm working as fast as I can!
Old 03-29-2017, 07:29 AM   #25
shaved240
shaved240's Avatar
How much does that motor weigh?
1979 242 Turbo: b230f+16v, Holset HX40, Getrag
1990 745 Turbo: Ipd Bars, Bilsteins, BBS Wheels
2001.5 S4 Avant: Stock for now.
1988 244: b230f+t, M46:PARTED
1995 960: SOLD
1994 945: SOLD
on the hunt for the elusive zf diff.
Originally Posted by jungledorifuto View Post
ship me that m46 for 40 bucks and im game
shaved240 is offline   Reply With Quote
