studmuffed
- Nov 16, 2017
- Va
Hey volvo enthusiasts,
I'm helping my buddy out with his car, it's a 1991 240 automatic but it's having a few odd problems. To start off it doesn't run, and we figured out that the fuel pumps don't run or prime, so we replaced both the relay and the main in-line pump, but it didn't help. We found out that the pumps aren't getting 12v, but their fuses are. The pumps will run when I jump fuse 4 to fuse 6. When we jump fuse 4 to 6 and crank the engine, it still won't start. We later found out that the fuel rail is getting fuel, but the injectors aren't getting power. We tried jumping 12v to one of the injectors but it still wouldn't fire. We know that it gets spark at least part of the time because it ran on starting spray. We also pulled a plug and it looked normal, but when we tested for spark on the spot with the plug out of the engine, we were getting nothing. None of the plugs had spark. What could cause it to have spark only part of the time??
We were thinking it could be the ECU since it has the notoriously problematic "pink label" ecu, the one ending in 651 I believe. Does anyone think that this is a problem or does anyone have any other ideas? Thanks!
Also if it is the ECU, can I swap in an ecu from a 92 or 93 240?
