AndrewNance
Amateur hour!
- Oct 24, 2011
- Winston-Salem, NC
Just finished putting together my 142 with a B20F and HIF6s. Basically stock '71 stuff aside from the head. I cannot seem to get spark past the distributor. The coil wire arcs while cranking when disconnected but I'm not getting anything to the plugs. I've run through what seems like every test in the Haynes manual with no success. I was originally using a Pertronix conversion and swapped back to points/condenser with no change. Resistance across the coil terminals is 4 ohms, and 9k ohms from one terminal to the center. Not sure if that checks out as I searched and found several values to be "correct". I have one engine ground which is a 4ga cable from the bellhousing to frame rail plus the battery ground.
Kind of at a loss here but I know it's going to be something stupid.
