t8fanning
8v are still cool, right?
- Oct 10, 2010
- Vancouver, WA
The MS3Pro manual says the following in regards to crank and cam sensors:
If the output voltage stays at zero the whole time, you'll need a pull up resistor... If it is at zero volts in one stat and bounces up to at least 5 volts in the other state, it doesn't need a pull up resistor.
I just tested a spare DSM CAS. The cam position output varied from 0 to 5V, but the crank position output stayed at 0 the whole time. Why would it not vary between 0 and 5V without a pull up for both outputs? Is this a function of the sensor, or my poor measurements/or high resolution of the crank trigger? With microsquirt, I used pull ups on both crank and cam signal and it worked. Should I do the same with MS3, despite the cam output not necessarily needing it?
