- Aug 7, 2003
- San Francisco
Curious if you've pulled the springs and put the suspension all the way down? Make sure the lip is rolled out of the way near the dogleg part of the quarter panel because that's a spot I've seen it grab the tire on hard compression when low and w/tall tires. Happened on Rob's car once and actually bent the straight lip out where it had caught on the tire.
I did. It barely touches the plastic trim that wraps around there. (I assume that's what you're talking about). I might have to cut that plastic and hammer the fender forwards.
