#626 |
![]() If I remember right when I did the conversion I just went into the local NAPA and told them what I was looking for and the temp ranges and that's where I got these P/N's. I might just call them to see if they do have a listing for the 82/77 if so I will post that up.
#627 |
![]() Autozone and Advance were both a bust. I had them looking up sensors for late 80's audi's and saabs but we couldn't find the 82/77. They had no idea how to search by temperature range...
#628 |
Back from the DEAD
![]() I'll see if I have an extra 77/82 laying around when I get home. Pretty sure I do.
My Blue 1986 245DL Pdx240 feedback http://forums.turbobricks.com/showth...ghlight=Pdx240 ------------------------------------------------------- |
#629 | |
![]() Quote:
Attributes: # Switch Terminals : 2 Coolant Fan Switch Temp Rating : On At 174-186 Deg. F., Off at148-160 Deg. F. Coolant Fan Switch Thread Size : M22 x 1.5" Terminal Type : Male Blade Part Number: ECH FS194 |
#630 |
#631 |
junkman
![]() This has got to be the most overthunk thread on TB
#632 |
![]() Took all of 20 minutes to put the e-fan on and wire it up with the Saab T and a sensor from FCP.
#633 |
Is always busy
![]() This^^
#634 |
Turbo, what?
![]() Which part #s and did you put it in the upper hose? How steady are your temps and what thermostat do you have in the car?
Kyle - NLMGG: '91 244 NA DD/Track - General Leif: '71 142 Endurance Racecar - The General's FB page - Oregon Volvo Tuners - Died ![]() |
#635 |
![]() Put it in the lower hose and temps are stable, they match what the sensor says 92/87 (Wahler 201-0809). I originally tried the Wahler 82395948182 (82/77 IIRC) and it was too cool in my opinion.
Can't remember exactly what thermostat is in there due to it being years since it has been replaced. If I had to guess based on what I see in Tunerstudio when the temp climbs and then drops when it opens, I would say it is the 87 in there. Last edited by J_Jones; 04-21-2014 at 04:56 PM.. Reason: corrected to 82/77 |
#636 |
Turbo, what?
![]() Very cool, thank you for the part numbers and info!
#637 | ||
F*ck Edgar
![]() If you have a radiator with the thread-in sensor, you could use one of these:
![]() Since it's two-post, you could use it with the factory 850 fan and dual speed relay...low speed comes on at 189*F, high speed comes on at 198*F. http://shop.advanceautoparts.com/p/w...50/10283131-P#
K-Jet to Megasquirt Article The Departed: 1981 245, 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo, 1989 244, 1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855, 2004 V70R |
#638 | |
![]() Quote:
#639 |
F*ck Edgar
![]() Why would you want a low speed fan on below 189*F/87*C?
#640 |
![]() Would not. Got the Saab t and 82/77 in tHe lower hose and it work good with the stock thermostat. Lower hose has coolest antifreeze going back to motor. Now I want to change locations of switch to radiator and don't want to waste money getting the wrong switch.the ac has now worked in years but will this year. I use the. Low speed only and that has been fine but I'm not taking advantage of the 2 speed Volvo fan. Still plan to wire the high speed to come on with the ac.
#641 | |
junkman
![]() Quote:
what male connector fits? |
#642 |
![]() Turbo heat soak?
#643 | |
![]() Quote:
#644 |
VolvoRacr
#645 |
Turbo, what?
![]() Same here, and I'm perfectly ok with it. It's been like that for years and I appreciate that it is keeping underhood temperatures in check at all times. A decent battery will have no problem with it. My fan actually turned on 3 or 4 times a couple of days ago while it was sitting in a hot garage after I drove it home from work(nothing special). Still fired up plenty fine in the morning and I've had the battery installed for more than 3 years. The fan's been installed exactly as it is for probably closer to 4 or 5 years.
#646 | |
![]() Quote:
#647 | |
Will eat for food
![]() Found a cheaper dual switch with m22 threads:
http://www.amazon.com/Beck-Arnley-20.../dp/B000CB3EEQ From the supplier: Quote:
#648 | |
Boost Addict
![]() I don't know if I posted this in here, but this is what I found a long time ago:
![]() - 84 242 - 92 740 - 72 240z - 78 280z - |
#649 |
![]() I use the 85-74/93-82 switch on my car with an 82 t-stat. Car stays as cool as it did with just low speed as it used to be when I had high speed going on the old rad switch. The fan only runs once, on low after I shut the car off. Haven't gotten it hot enough for high speed switch to kick in yet
![]() 1988 760 Turbo - garage queen, everlasting project also 2016 Ford Fiesta ST - size small daily 1995 Ford F150 - size large daily |
#650 |
Upsetti Spaghetti
![]() I was doing some work today and learned something very important I want to pass on.
If you have a 940/850 e fan on either your 240 or 740 and never had a pusher e fan to begin with, then here is the way to wire it up so it works when the compressor turns on. ![]() This is how you do it, high speed either is spliced or goes to 87, splice a wire from the compressor and put it on terminal 86. Then from there put 85 and 30 to ground. The only issue I have found so far is that when the car is in the on but not running and the compressor engages, the fan will turn on when the car is off, but that can be solved by a second relay.
1989 240 Turbo 1988 745 Turbo - SOLD 1991 940SE - SOLD 1995 850 T5-R - SOLD 1991 740 Turbo - SOLD 1987 240 - Crushed 1989 740 "Satan" 1987 760 Turbo Leave Me Feedback ![]() |
