#676 |
( ͡° ͜ʖ ͡°)
![]() When I had my 240, my fan would cycle 2-3 times for 5-10 minutes after it was shut off. Didn't hurt the battery or anything.
2009 Volkswagen Rabbit 2.5 "Snowbunny" |
#677 |
![]() Found a 940 with e-fan at the JY. About to leave town, but for $35 I want to grab it.
It has a fan controlled mounted behind the right headlight. 2-speed ..... Does anyone run a 2-speed fan, or does everyone just use the low-only? |
#678 |
![]() I use the low only, works fine in Southern California. Needle never moves passed the 12 O'Clock position.
Silver '89 780 Bertone Turbo: Bilsteins HD in the front, polly bushings, IPD 25mm sways in the front and 19mm in the rear, IPD lower and upper brace. |
#679 |
![]() Yeah low speed has kept mine plenty cool, but high speed is set up on a dash switch just in case.
#680 |
Ignoramus Bigotus
![]() ... you mean 9 o' clock?
'90 244 - Too many memories to crush '92 944T - Need any 940 parts? '96 854 GLT - Not mine any more but still in the family '92 245 - For Sale? '97 854R - Waiting to get fixed '06 XC90 V8 - Family Hauler - Wifemobile '04 XC70 - Impulse buy of the year Feedback:http://forums.turbobricks.com/showth...ght=dmfwallace |
#681 |
#682 |
( ͡° ͜ʖ ͡°)
#683 |
#684 |
![]() I will use the new radiators port rather than the ecu. I think having the switch on the passenger side of the radiator will be most effective because it'll show when the radiator no longer has the ability to cool the coolant down to the given temperature WITHOUT a the help of a fan. /babling. Last edited by iHateVolvoPeople; 04-17-2015 at 02:17 AM.. |
#685 | |
![]() Quote:
#686 | |
![]() Quote:
http://www.amazon.com/Flex-lite-3114.../dp/B00029J3ZW |
#687 | |
![]() Quote:
#688 | |
![]() Quote:
#689 |
![]() Someone posted this switch a while ago. Supposed to have the same threading as our screw-in rad switches (M14x1.5, I believe), but has a dual-range switch.
Great. But here's the thing. Low speed is on at 85, off at 80. High speed is on at 93, off at 88. If it hits 93, does it ground both pins and run both high and low circuits simultaneously? Is there a way around this? You could do fancy wiring so the high speed switch runs a 5-pin relay and the input 30 pin feeds say 87a and then the relay for the low-speed relay and switches the power to 87 when the high speed switch trips. I think I just answered my own question, but it's past my bedtime. Here's the switch: http://www.germanautoparts.com/productdisplay/19404 |
#690 | |
![]() Quote:
#691 |
![]() People say to use a 740 turbo shroud (still a mechanical fan shroud) but some have also used the 940 e fan shroud trimmed down. I don't think it would be a good idea to get rid of the 'flaps' in the shroud, so how is it shortened?
#692 | |
![]() Quote:
Yep. What I'm saying is what happens if both switches are grounded and both relays are on and both hi/low circuits are running. Is that going to burn out the fan? I drew up a diagram last night of it. Should work, but the low-speed fan relay trigger feed will always be hot. So Low-speed fan will run with car off, but the relay shouldn't be drawing power while it's in its NC position. |
#693 |
#694 |
![]() I picked up a turbo shroud that fit my radiator then took the 940,850 fan out and mounted it in the turbo shroud. Looks factory except I had the first two nuts to the outside. Noticed it and put the last two to the inside. Still have not gone back and fixed that.
#695 | |
![]() Quote:
#696 |
#697 |
#698 |
#699 |
![]() I hacked the 940 shroud and left 1 inch open on one side so air could get through. At first I left no airways and it got warm on the highway. Cutting that 1 inch off brought it back to normal temperatures. It also stays cool with the fan on even with that gaping 1" hole
#700 |
![]() I had a 940 fan and modified it and now that I think on it a little if was a 740 turbo that had the shoe shroud. I have a couple of the 240 off set turbo shrouds that will work but more bulk. Plan to take a look and see i Like it with a electric fan. I could mount a electric fan in the same way.
