![]() Who's got the best one (preferably in Europe) and what are the differences? Prices are all over the place..
KL Racing - ABS plastic - around 100 EUR: https://shop.klracing.se/sv/artiklar...p-a-vinge.html VParts - composite plastic (=ABS?) - 178 EUR: https://vparts.se/row/volvo-240-260/...volvo-240.html Redblocksociety - fiberglass - 270 USD: https://redblocksociety.com/collecti...ng-ratedrsport |
![]() Just in case you haven't kept up on this, redblocksociety is a scammer. Buyer beware.
http://forums.turbobricks.com/showthread.php?t=345112 |
What, me worry?
![]() Join Date: May 2003
![]() I bought one from redblocksociety and it was fine and delivered promptly.
I coulda had a V8! |
#4 |
![]() Thanks for the heads up! I had read that thread - should have mentioned that I just added it for comparisons sake.
#5 |
![]() You might get lucky like MikeSr. and actually get your spoiler if you buy from redblocksociety. I just wanted to make sure you made an informed decision.
#6 |
Stage 1
![]() Instead of giving that guy money, you can buy the last wing directly from the ones who make them (Carbonlat in Latvia): http://carbonlat.com/gb/karbon-auto-1/volvo-241
#7 |
Astro Zombie
![]() A friend of mine has an unused OEM Volvo one, with the mounting wedges. It has never been painted. Been stored for over 20 years. Pretty sure it will cost more than the above options though.
Feedback thread https://forums.tbforums.com/showthread.php?t=144924 1978 242, 5.3 L33 1979 242, MS, R brakes 2006 V50 T5 AWD @ 17 PSI |
#8 |
![]() What material were the OEM spoilers?
#9 |
Astro Zombie
![]() I'm not sure what it is. It is fiberglass or plastic or something, possibly layers of both. I can't tell by looking at it.
#10 |
![]() It has been about 12 years since I have seen/held one. IIRC, it was plastic. Possibly, polystyrene. The same material the front air dam of a 780 is made out of.
#11 | |
Stage 1
![]() Quote:
Haven't seen one myself, it's probably either ABS but more likely PA (probably with 30% fibreglass, which is one of the more commonly used PA variatons for automotive components). |
#12 |
The Librarian
![]() I'm pretty sure the one I bought from the dealer in '86 was made of fiberglass. It was pretty heavy.
I sold it to TracksideTurbos a few years ago. ![]() |
#13 |
![]() Polystyrene is used for all kinds of automotive components. The 780 air dams are definitely not glass reinforced and are much too rigid to be PA, PVC, PUR or PP. They snap like glass when struck. There are many different formulas for PS, depending on their intended use. Including high impact PS.
https://www.modernplasticsglobal.com...ts-advantages/ |
#14 |
Stage 1
![]() Yes I know HIPS, we use it for some of the cups we make. I should've added "exterior" to components.
I work in a plastics packaging company (that also makes technical and automotive components and a lot of stuff for the company that's most famous for their tiny plastic bricks ![]() Although the ones used for automotive aren't really commonly used for other applications, especially not for food packaging which is the majority we do, so my knowledge is limited I have to admit. Anyway, let's not turn this into a discussion here, just wanted to take a guess ![]() |
#15 |
![]() I used to do the same sort of thing. New Products design engineer and was responsible for the design of quite a few plastic components while doing that gig. I'm guessing myself based on what I've seen Volvo do with other parts. PS isn't that commonly used for exterior components, as you said. It is very rigid though, and sometimes is used for it's ability to maintain its shape. Also, as you said, it is very prone to UV damage. After Ian's post I think I remember the spoiler being very heavy for its size. That would lead me to believe he's closer to the truth. Probably, glass mat and resin. Most of the Volvo small run specialty parts were made in cottage industry shops.
