Old 10-14-2021, 09:32 AM   #1
VolvoLatAm
Default question about dual b23 oil pressure sender/warning
for the b23, the sendor/warning 1/8 NPT, right? and I am relocating the steering pump to that side, so I need 1/8NPT 45*? (sometimes depending on the room, some have adapters, some don't)
I know 1 psi is .06 bar, 30 psi = 2.06 bar
I am guessing I need like a 100 psi sender/warning combo if I have a 5 bar gauge?
VolvoLatAm is online now   Reply With Quote
Old 10-14-2021, 10:34 AM   #2
white855T
1/8 npt thread. Get a steel 45 deg elbow. The sender will go up to 80 psi for a 5 bar gauge.
Old 10-14-2021, 11:26 AM   #3
VolvoLatAm
is the sender/warning combo even possible to find? I have found lots of pressure senders but no warning combos
also, what psi for warning, I found one that is 80 psi and 7psi or .48 bar warning
found this: VDO Pressure Sender, Part #360-009 - 0-80 PSI/5 Bar, 1/8-27NPT Thread, 7 psi Warning Contact
Old 10-14-2021, 12:16 PM   #4
white855T
That is correct. One side is for stock output and the other is for your gauge.
Old 10-14-2021, 12:51 PM   #5
VolvoLatAm
is there any difference in between brass and steel for the seal on the 45 degree male female adapters?
https://www.ebay.com/itm/25460850323...Cclp%3A2334524
https://www.amazon.com/FasParts-Fema...ustomerReviews
https://www.ebay.com/itm/12249695411...QAAOSw3V1ex9PV
Old 10-14-2021, 01:04 PM   #6
white855T
I just recommend a steel fitting because if it ever has to be removed. The brass is soft and can be damaged easily. Third option would be the best bet. First option is good too.
Old 10-14-2021, 01:10 PM   #7
VolvoLatAm
ok, thank you for your recommendations, the brass stuff on the brake line connections tend to be too soft, so I think steel is a good option, just wanted to make sure it was hermetic--copper crush washers might be needed I think? or are the threads tapered including the joint?
Old 10-14-2021, 01:33 PM   #8
The Librarian
The threads are tapered, no crush washer needed. Use a liquid or paste thread sealer. Thread tape can prevent the sender from getting a ground signal.
Old 10-14-2021, 02:59 PM   #9
VolvoLatAm
good to know, thanks
