Old 07-11-2020, 05:43 PM   #1
WizardOverYonder
Default LH2.4 B230F+T PCV issue with TOO much oil!
G'day,
My +T is taking on a fair bit of oil through the intake via the PCV which I believe is due to a fair bit of blow by.
I've looked into doing a catch can set up, but I'm concerned that will just fill up relatively quickly.. is there another way I can go about this with out sucking oil through my turbo?
Cheers,
Sam
WizardOverYonder is offline   Reply With Quote
Old 07-11-2020, 06:01 PM   #2
rb92673
Why don't you have the catch can drain back into the oil pan?
Here is a pretty standard way of doing it:
https://www.240turbo.com/catchcan.html
Old 07-19-2020, 05:18 PM   #3
90volvo
Yelp do what the link says. I have no problems after doing that mod. Engine had 280000 miles on it and running 20lbs boost. Before I had same problem as you.
90 Volvo 240 19T-3 inch ex-Aw71-Npr-V cam-E85-Megasquirt-650cc inj.-280000 miles.
