Old 07-14-2020, 07:54 PM   #1
F*ck 12
Default China turbo- too much preload?
I'm getting some boost spikes up to 20psi. I reclocked it and set the preload at about 3/4 of the length of the hole on the waste gate actuator rod. I took my mbc apart and didn't see anything unusual. 2 balls and a spring, I have it set so that it opens when I blow in it so it's not 20psi. Pretty sure it's hooked up right, hose on the bottom goes to the turbo outlet and the one on the side goes to WG actuator. Anyway any ideas?
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 07-14-2020, 08:14 PM   #2
culberro
culberro's Avatar
What does it do when the actuator is hooked up directly to the compressor housing?
Old 07-14-2020, 08:30 PM   #3
F*ck 12
That's a good question, I'll try that next.
Old 07-14-2020, 09:04 PM   #4
TurboDutch
Chinabai charger with internal wastegate? Could be boost creep.
Try porting wastegate hole?
TurboDutch is offline   Reply With Quote
Old 07-16-2020, 02:43 PM   #5
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Originally Posted by TurboDutch View Post
Chinabai charger with internal wastegate? Could be boos creep.
this!
Old 07-16-2020, 02:49 PM   #6
F*ck 12
I just adjusted the ve map, 20psi is fun.
Old 07-19-2020, 01:17 PM   #7
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
the turbobricks way ;)
Old 07-19-2020, 05:10 PM   #8
F*ck 12
Best run today, I have an appointment with the dyno on the 29th to finish sorting it out.
Old 07-19-2020, 08:42 PM   #9
Alan29
Alan29's Avatar
Nice run...car sounds great.
Signature.
Alan29 is offline   Reply With Quote
Old 07-19-2020, 09:48 PM   #10
F*ck 12
Thanks!!
Old 07-29-2020, 12:21 PM   #11
F*ck 12
So I took the heap to the dyno, apparently I need to port the wastegate. Will keep all apprised of further developments. I wish I’d listened to Culberro.
Old 07-29-2020, 12:23 PM   #12
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
lol! so what'd it throw down?
Megasquirt Tuning!
Old 07-29-2020, 12:23 PM   #13
culberro
culberro's Avatar
Dyno plots and boost spikes or
Old 07-29-2020, 12:33 PM   #14
TurboDutch
Creep!
Old 07-29-2020, 02:11 PM   #15
F*ck 12
234 -240 before he let up around 5500rpm in 3)3rd gear pulls. Explains why none of my boost controllers are working.
Old 07-29-2020, 11:20 PM   #16
linuxman51
linuxman51's Avatar
DATA MAN, DATA!
seriously. n00ds or gtfo, you know the rules.
Old 07-30-2020, 08:54 AM   #17
F*ck 12
The knock sense is going off quite a bit, we were going to look at the that too. I think I have it turned all the way down but it seems to go off as soon as boost kicks in. The knock sensor is torqued to 10ft.lbs. in the spot at the center top of the left side of the block where the factory sensor was installed
Old 07-30-2020, 10:08 AM   #18
TurboDutch
Looks not bad... only a bit lean.... needs more fuel :D
Old 08-06-2020, 07:40 AM   #19
F*ck 12
I ported the waste gate hole, seems to have fixed the problem. It must have a 13psi spring cause that's what it's holding. Now I have one more issue to sort out.
Old 08-06-2020, 10:23 PM   #20
TurboDutch
Ur welcome :P
Old 08-07-2020, 05:42 AM   #21
F*ck 12
Ur welcome :P
Thanks!
Old 08-08-2020, 03:25 PM   #22
F*ck 12
So it seems under control most of the time unless I give it the beans in 2nd then it goes up to 22psi. I guess I need to do more porting??
Old 08-08-2020, 04:57 PM   #23
TurboDutch
Hmmm yeah or go external gater...
Are you using manual boost controller? And stock wastegate actuator? You could try to play with pre-load tension of actuator a bit...
Old 09-05-2020, 02:05 AM   #24
F*ck 12
This car hates to race apparently, I have an autocross on Sunday and I believe the seals in my bargain turbo have gone out. It smokes like crazy at idle but clears up under load. There's a few newer turbo Volvo's at the boneyards, maybe I'll go see if there's anything I can use. Can you use a lpt turbo with a mbc?
Old 09-12-2020, 04:28 AM   #25
TurboDutch
Yes it can!
But try to find K24 thats nice
