Old 07-29-2020, 11:11 AM   #1
thatcher.hubbard
thatcher.hubbard's Avatar
Default Early 850 flywheel
I did a couple of searches and couldn't find anything conclusive, hopefully somebody here knows for sure.
I want to put a T5 behind my B6304, which means I need to replace the flexplate with a whiteblock flywheel. An early 850 flywheel is available, but it seems the design was different. How different (and in what ways) is what I'm wondering about. The car is using the OEM Motronic 4.4, so the crank position sensor needs to be compatible (or made compatible some way) and I'm also wondering if the dimensions and bolt pattern are the same. I was also planning on using the starter from my S90 donor car, and my desire was to use and 850R pressure plate (240mm) and then get an 850R clutch plate with the T5 center from southbend/spec/whoever.
thatcher.hubbard is offline   Reply With Quote
Old 07-29-2020, 12:37 PM   #2
TurboDutch
What kind of engine was the flywheel attached to?
Normally asprirated to turbocharged?
TurboDutch is offline   Reply With Quote
Old 07-29-2020, 04:36 PM   #3
classicswede
Volvo upgrades
There are two types of pattern on these flywheels but you can switch by crossing over the wires on the sensor
What you will need to know is if it had the 228mm or 240mm clutch, you need the 240mm type flywheel for the 850R clutch.
I do have new lightweight flywheel for just this job
Old 07-30-2020, 12:31 AM   #4
TurboDutch
The NA flywheels are the smaller diameter and cast.
Old 07-30-2020, 12:40 AM   #5
swedishiron.com
I sell Volvo parts!
And we never got 850 turbo flywheels in the USA.
Here's my feedback thread:
http://forums.turbobricks.com/showthread.php?t=25568
I ship small packages/purchases on Fridays, and larger ticket items via FedEx in the middle of the week.
swedishiron.com is offline   Reply With Quote
