Old 08-11-2017, 11:01 PM   #1
roflcopter
Default Daily Driven Drag Wagon vs The Dyno
I finally had some time to play with the 245 on the dyno a bit and see what it could do. Keep in mind this is on a stock N/A head and cam, 90+ manifold, etc. If I end up keeping the car(no serious bites yet), what would you suggest as the next step? If I want to make 300 then obviously a cam is in order, peak torque is happening as soon as boost comes on fully(~4100), but if I do a cam how aggressive should I go and is porting/big valves really a necessity?
Either way, I'm proud of this thing for what it is. 279hp/305tq @ 24psi. Better than a stock WRX for WAY cheaper.
1985 244GL --- Resurrected, Slammed, Broken, Fixed, Broken, Scrapped
1989 245DL --- B230F+T, MS2v3, T04E, modded AW71, the "Daily Driven Drag Wagon"
roflcopter is offline   Reply With Quote
Old 08-12-2017, 12:19 AM   #2
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
ipd cam at the very least. stg3 rsi if you're more srs. bigger valves and port work get lost with stock manifolds, so thats the slippery slope part
Megasquirt Tuning!
Old 08-12-2017, 05:56 AM   #3
mck1117
279 on an M cam? Quite respectable. An IPD or RSI cam should do you well.
Side note: You willing to share your Megasquirt tune? I'm interested in your ignition timing. I have a similar b230f+t, 90+ manifold, etc.
mck1117 is offline   Reply With Quote
Old 08-12-2017, 11:29 AM   #4
nomad1221
Awesome! What turbo?
nomad1221 is offline   Reply With Quote
Old 08-12-2017, 06:50 PM   #5
roflcopter
That's actually a good thing... I wasn't looking forward to forking over for valves and all just to make the 300 mark. Hopefully someone buys this thing before I have to worry about it anyways. haha
Thanks! And sure, although a lot of it is whack, and the only part that has really been tuned on the timing side is under full boost and once it spools, I will say that at 250kpa my ignition timing is ~10.5btdc at 4000rpm, tapers to 12.5btdc at 6000rpm. I'll post the full file if you want when I get home.
This is on a $120 ebay T04E.
Old 08-13-2017, 05:20 AM   #6
OkeyDan
Could you share the trim and A/R? Learned myself to understand flow maps only to find out ebay turbos don't have them:P.
OkeyDan is offline   Reply With Quote
Old 08-13-2017, 08:00 AM   #7
roflcopter
50 trim, I think it's quoted at a .60 A/R cold side. Running the .63 A/R hot side. My rule of rheum has always just been to use the compressor map from whatever turbo it's a knock off of but assume a bit less efficiency.
Old 08-13-2017, 08:15 AM   #8
tryingbe
Boosting along.
tryingbe's Avatar
Start saving up for a transmission.
85 GLH 367whp
00 Insight 72 mpg
tryingbe is online now   Reply With Quote
Old 08-13-2017, 08:40 AM   #9
roflcopter
I'm already running a modded AW71, blew the original AW70 up pretty early on. With all the abuse this 71 has seen over the last 20k miles and multiple trips to the strip I'm fairly confident in it.
Old 08-13-2017, 09:05 AM   #10
tryingbe
Boosting along.
tryingbe's Avatar
Don't be. Thelostartof has gone thru 6-8 AW71, then he got a 200r4
http://forums.turbobricks.com/showth...t=transmission
Old 08-13-2017, 09:16 AM   #11
roflcopter
Since this is still a full everything daily driver I'm trying to avoid doing any chassis modifications. The car is currently for sale and I hope someone scoops it up, but if not then maybe in a year or two I'll try to make real power and beef up the driveline too.
Old 08-13-2017, 07:50 PM   #12
roflcopter
So.... I guess I'm going to buy a cam or something. I'm going to put together a fresh 530 head for this car(if you have one for cheap let me know) and put some upgraded cam in it. I've spent the better part of today reading arguments dating from mid 2003 on which cam I should go with...
What do you guys think these days? What cams will work on a stock spring/valve head? If I go with a slightly milder one will it help spool times a bit since I'll be increasing flow before 3500 or so? (I don't hit full boost until 4100 right now) I know I'm somewhat RPM limited with this AW71, so would getting a cam that flows much past 6000 really be worth it?
Old 08-16-2017, 02:28 PM   #13
OkeyDan
I Just looked at your dyno graph again and I didn't notice before, you're actually making peak power at 6 grand, i'd say that's not bad. Seeing how much the torgue dips in after 5k I would expect that indeed putting a cam in it would tip you over the 300 hp mark. You only need a little bit more torque at 6k to get there.
I don't feel experienced enough with these cars to give you advice on which cam to get, so hopefully someone else can answer that.
Old 08-16-2017, 03:04 PM   #14
EivlEvo
I went with the IPD turbo cam. It's a solid balance of usability and performance, but it is decidedly NOT a hot cam. You'll barely get any loping at idle and with an auto... every now and again you might even get a stall. I'd wager that's because I'm only on TLAO and LH2.4.
With RSI going out though... cam options seem a bit more limited.
