iHateVolvoPeople
- Feb 1, 2014
- Midwest
I'd like to get an idea of the general quality and longevity of different brands of various engine seals/gaskets for redblock cars. I've installed an elring cam seal and had it immediately leak. That's not to say elring makes a bad seal, perhaps the one for our cars is just not the correct size. I picked up about 5 Beck and Arnley camshaft seals for $2 a piece and was wondering if any of you have run these and with what results. Obviously a Volvo OEM seal will always work but they are quite expensive.
Aside from cam/aux/front and rear main seals, there's intake manifold, throttle body, valve cover, oil pan, and head gaskets. I've never had to replace any of these but did a little bit of research on them. A valve cover is simple enough that any should suffice with some RTV, same with the oil pan gasket. However, I think I read that the Felpro head gaskets are awful. They are 'guaranteed' to fail. Have any of you had this issue? Also, the elring head gasket is supposed to be of great quality.
This thread isn't really a question but I'd like to know some of your experiences with the different brands of seals and gaskets. Thanks.
