Old 02-02-2018, 04:27 PM   #1
GeneralBurrito
GeneralBurrito's Avatar
Default What metal are Virgo wheels made of?
I got a decently clean set with tires about a week ago for $100, but they do have some caked-on brake dust my dad and I are trying to clean up. We went to O'Reilly Auto Parts to get wheel cleaner and they had different cleaners for different metals. They're made in Germany if that helps.
Old 02-02-2018, 04:50 PM   #2
Can play the blues
They are painted forged aluminum wheels. there are some threads about wheel cleaning here.
Old 02-02-2018, 05:01 PM   #3
GeneralBurrito
They're painted? They felt a little rough and pitted. And I'll make sure to look up those guides.
Old 02-02-2018, 05:42 PM   #4
Yea they're ~30 years old and not perfect, go figure?
Old 02-02-2018, 05:43 PM   #5
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
If they have tires on, get them dismounted, yank the old stems, pull the old weights and have them media blasted. Then you can go about repairing the surface as you see fit and paint/powder coat/polish as you see fit. Gonna have to do that to my Wife's Virgos next winter.
-Stephen
#mclovethesenuts
Old 02-02-2018, 06:03 PM   #6
propav8r
F*ck Edgar
propav8r's Avatar
I've had a few Virgos I swear were made from pot metal.
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo, 1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 02-02-2018, 06:03 PM   #7
2manyturbos
Cast aluminum. Complex shapes like a Virgo wheel would be near impossible to forge. The grain structure when they break tells the story. Very large grains.
Old 02-02-2018, 06:06 PM   #8
Old 02-02-2018, 08:30 PM   #9
nel621
[IMG] photo virgosbeforeandafter.jpg[/IMG]
Old 02-02-2018, 08:31 PM   #10
nel621
Detergent 600 works the best.
Old 02-02-2018, 08:34 PM   #11
milanomike
All are cast aluminum. The only way to forge would be simple pancake or complex die (but you'd still have mucho machine work to do). Oh and the cost of forged wheel, like real real high. Also, once the paint is scuffed or eaten by brake dust the aluminum is very happy to corrode (pit).
milanomike is offline   Reply With Quote
Old 02-02-2018, 09:47 PM   #12
GeneralBurrito
Would any acidic cleaner work?
Old 02-02-2018, 10:38 PM   #13
centason
Knipex=welfare queen
centason's Avatar
They used to be made out of round cast aluminum. Now, they are not round, but still cast aluminum.
Member: TBCCS
"The kind of man who wants the government to adopt and enforce his ideas is always the kind of man whose ideas are idiotic." -H. L. Mencken
Old 02-02-2018, 10:56 PM   #14
nel621
Not sure, maybe. Just dilute it a bit. I tried all types of wheel cleaners to remove baked on brake dust and none worked. This stuff did the trick even on the Volvo plastic hub caps. Spray it on, let it sit for a few minutes, scrub lightly with a mild ScotchBrite pad and rinse. Remember to dilute, maybe 1 part cleaner to 3 parts water.[IMG] photo upcloserust_zps1b029ccf.jpg[/IMG]
Old 02-02-2018, 10:57 PM   #15
nel621
[IMG] photo aftercleaning_zps44e08e25.jpg[/IMG]
Old 02-02-2018, 11:03 PM   #16
culberro
culberro's Avatar
This. I had a few that have completely crushed lips on them.
Old 02-03-2018, 06:12 PM   #17
lverhagen
negahrevl
lverhagen's Avatar
As some other people have mentioned, Detergent 600 (concrete etching acid - active ingredient: muriatic acid) diluted with water works great for cleaning painted wheels caked with brake dust, but will eat bare aluminum and steel given time.
You should be able to find muriatic acid in some form at your local hardware store, often among paint, cleaning, or masonry supplies.
When diluting with water, add the acid to the water, slowly.
Work with gloves and in a very well ventilated area (preferably outdoors).
I mixed the solution in a bucket and applied it to the wheels with a chip brush, being careful not to splash or aerate it.
I fashioned scrapers out of wood to aid in removing the brake dust.
I hope that helps.
Feedback Thread
7/900 Parts for Sale
Originally Posted by SquareD View Post
Restore this thread to stock.
"Towards thee I roll, thou all-destroying but unconquering whale..."
Current Cars:
1987 Volvo 740 Sedan ~180k - awaiting complete disassembly and scrapping
1989 Volvo 740 Turbo Intercooler Wagon ~155k - hardware store mbc + 4.10 final drive + horrible fuel economy + dead blower motor = favorite daily
1995 Volvo 940 Sedan ~183k - undecided fate (too nice to scrap, too boring to keep, too archaic to sell)
lverhagen is offline   Reply With Quote
Old 02-03-2018, 07:26 PM   #18
Can play the blues
Ok I learned something. Virgos are cast. Thanks for correcting me.
Old 02-05-2018, 12:34 AM   #19
Wren
Porkchop Sandwiches
Wren's Avatar
I know that if you had 9 of them, 10 would be bent.
Old 02-05-2018, 02:25 AM   #20
nordmaschine
forced instruction
nordmaschine's Avatar
Come on, stop pulling OP's leg. Virgos are made of Nitrogen-Carbide fiber, that's why they're black. Best way to clean them is to gently dip them in a bath (old tub works great) of sulphuric acid.
Jetronic is romantic.
Whiteblocks
Old 02-05-2018, 07:25 PM   #21
swedefiend
swedefiend's Avatar
I was told by a friend that tried to have a set of Volvo wheels chrome plated that they were aluminum-magnesium alloys (or that is what the plating company told him).
Old 02-05-2018, 08:41 PM   #22
Jack
Banned
Jack's Avatar
^ right thats why they weigh 18lbs each
lots of people think they are magnesium. Had one dude locally selling a set for $900 because magnesium ... I told him they are aluminum and he said I was trying to scam him
Old 02-05-2018, 08:59 PM   #23
swedefiend
swedefiend's Avatar
You do know there are at least three grades of al-mg alloys suitable for automotive wheel casting, right?
And... Pure aluminum wheels would corode like a mofo
Edit:// A "materials engineering" book would likely have information relevant to aluminum alloy structures.
Old 02-06-2018, 12:17 AM   #24
Jack
Banned
Jack's Avatar
leaf this party and be gone with the wind
