Old 06-03-2020, 05:09 PM   #1
stayathomedad
Default Tips for anchor points on Camshaft pulley torque down
Anyone out there have any tips on how to torque down the camshaft pulley, aux shaft pulley and crankshaft pulley with the motor out and with no special tools?
stayathomedad is offline   Reply With Quote
Old 06-03-2020, 05:40 PM   #2
kyote
Living The Dream
kyote's Avatar
The Rope Trick my dude.
https://www.brickboard.com/RWD/volvo...unterhold.html
Old 06-03-2020, 07:08 PM   #3
For the cam sprocket and aux shaft sprocket. You can use an old timing belt. Wrap around the sprocket then wrap old belt around the large tensioner stud. Clamp the belt down onto the wrapped part on the stud with a vise grip plier. Tighten bolts to 36ft lb.
1982 242 turbo. 340k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration.
Old 06-03-2020, 09:09 PM   #4
F*ck 12
I've used a small pipe wrench between the lobes on the cam shaft. I have some HF oil filter vise grips that I use on the auxillary shaft and I use the rope trick for the crank sprocket and flywheel bolts.
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 06-03-2020, 11:38 PM   #5
stayathomedad
Nice, I'll give all of these a try just to see them work. Thx guys!
Old 06-03-2020, 11:55 PM   #6
hessam69
https://www.sparesbox.com.au/part/to...SABEgKu9PD_BwE
Old 06-04-2020, 07:03 AM   #7
DET17
Reformed SAABaholic
This, exactly. Pics are in my build thread.... for the cam pulley at least. I use 2 pair of vice grips; one at the pulley, the other at the stud. It works brilliantly......
Old 06-04-2020, 10:56 AM   #8
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
Hit it with a couple ugga duggas
Hello My Glorious!
CAPT_BLOTTO is offline   Reply With Quote
Old 06-04-2020, 02:47 PM   #9
Sjeng
Sjeng's Avatar
I assume you have one of these:
Crank pulley: Put car in 4th gear and have your friend press the brakes.
Old 06-04-2020, 03:40 PM   #10
F*ck 12
I used to do this until I broke a cam shaft pulley bolt off inside on the first ugga.
Old 06-04-2020, 07:24 PM   #11
hessam69
There is a special tool available as I have shown
Old 06-04-2020, 11:26 PM   #12
white855T
Old 06-05-2020, 11:50 PM   #13
stayathomedad
Used the old timing belt with the vise grips trick for the cam and aux sprockets and it worked great!!!
Now I'm just waiting to get my hands on a woodruff key for the crank sprocket since I lost mine somewhere. Having a hard time finding one for this motor....
Old 06-06-2020, 01:40 AM   #14
sbabbs
sbabbs's Avatar
Ha, I did the ugga ugga today myself with air wench. Gonna start up the 88 240 white slicktop race wagoon tomorrow! Motar is in, just gotta tidy it up and run it!
