Old 10-05-2017, 04:30 PM   #1
Fumomike
Fumomike's Avatar
Default Crushing cbv
Quick question. I have a 90 760 turbo with 19t/ 15g hot side at 15psi. How do I crush my cbv? Do I just take a hammer and smack that or should I be shimming the inside? I prefer to use the hammer.
Thanks I had a old crushed cbv that went whoosh and want to recreate that. Once I replaced it with a new one no more whoosh ;(. A search comes with threads mentioning it but not explaining it perfectly.
Fumomike is offline   Reply With Quote
Old 10-05-2017, 04:59 PM   #2
PromiseRing
We don't even like Volvos
Wat
Current
-93' 244 m47-iPd sways, 13c, iPd cam, 2.5”
straight pipe
-93' 245 m47-iPd sways, B-cam
-90' 744 AW70:( stock as a rock
Past
-80' 242gt m46-
-88' 245 m47-Welded diff, gutted, 13g
spill it MClovin and WTF happens to your glasses you piece of ****..
Ps how nice of you to browse my thread history. Next time you want to see up my skirt just message me and I’ll send you a Polish Sausage shots
Feedback Thread
PromiseRing is online now   Reply With Quote
Old 10-05-2017, 05:49 PM   #3
Quin
ಠ_ಠ
i thought the only point of that was if it's not holding whatever boost it's currently seeing.
Old 10-05-2017, 05:58 PM   #4
cwdodson88
If you want whoosh, short open intake tract and unrestricted filter, then remove sound deadening from the hood and remove passenger side headlight.
The Build Thread
SVEA - PUSHROD TURBO!
Old 10-05-2017, 06:40 PM   #5
Fumomike
Fumomike's Avatar
Default Cbv crush
No all the removal of sound dedeaning material and stuff like that increases sound of turbo spool and air noise but no psssh noise from a bov or modified cbv. Crushing the cbv should seal air leakage at boost pressure and also increase tension on the spring causing it to open at higher boost pressure and making a psssh noise.
So how do I Do this? I had an old cbv on there and it was bent up crushed and had a torn seal so I replaced it but lost the noise. I believe taking a hammer and smashing it in again will bring back the desired effect.
Old 10-05-2017, 06:45 PM   #6
white855T
Do it and report back.
Buyer/Seller Feedback
Old 10-05-2017, 06:49 PM   #7
PromiseRing
My stock CBV does that.
Old 10-05-2017, 08:28 PM   #8
cwdodson88
Idk, my 15g at 7psi with an untouched cbv and 3"x12" intake and cone is pretty loud
https://youtu.be/eaXvxHgJmFI
Old 10-05-2017, 10:56 PM   #9
PromiseRing
I hear my spool really well through my vatozone filter.
And my CBV just makes a really loud exhale sound. Think of it like the noise you make when someone starts talking about politics/religion.
Old 10-06-2017, 02:38 AM   #10
cosbySweater
cosbySweater's Avatar
Some one has been on the DSM forums too much back in 2003
1979 Volvo 244DL 6.0/4l80e,8.8,Ms3x goldbox ecu and Mircrosquirt tcu, s366 clone.
1982 Ford Fairmont Futura, 4.8/th400, 8.8, mircrosquirt, 7665 turbo, Project Cheap Thrills
Old 10-06-2017, 09:30 AM   #11
J_Jones
J_Jones's Avatar
I've done the crush and drill mods to a 1g dsm bov and it worked well, but never heard of it for the volvo mitsubishi turbos. I have the IPD bov upgrade on my 15g, springs and diaphragm, and it works well.
J_Jones is offline   Reply With Quote
Old 10-06-2017, 10:15 AM   #12
TurboDenny
Why am I here?
'90 245 Daily
Instagram: @itstotesdenny
I want all your nostalgic Volvo stuffs.
Old 10-06-2017, 11:04 AM   #13
tryingbe
Boosting along.
tryingbe's Avatar
Never crush a 1st gen DSM CBV/BOV, always modify it by plugging a hole and drilling another hole.
The reason behind crushing/modifying DSM CBV/BOV is that in stock form the 1st gen DSM CBV/BOV will open starting at around 17psi. To stop it from opening, crushing the cap slightly will get the CBV/BOV to open up at later psi. Modifying by plugging the small hole in the bottom and drill a small hole on the side will make sure the CBV/BOV never open due to pressure.
I didn't bother making a tube for the hole.
http://www.thedodgegarage.com/turbo_bov_mod.html
This is the first time I heard someone say crushing a stock CBV on a Volvo turbo though... usually people put block off plate on it or plate that vent it to atmosphere.
85 GLH 367whp
00 Insight 72 mpg
94 855 in hibernation
Old 10-06-2017, 12:00 PM   #14
lummert
lummert's Avatar
My car makes enough noises already to worry about hearing a whoosh of air.
Old 10-07-2017, 08:10 AM   #15
doucheNozzle
doucheNozzle's Avatar
No.
'95 850 T-5R - FailSedan
'04 V70 T5A - FailFamily
