Old 05-15-2014, 11:26 AM   #1
calvintibia001
Bench-Race Fanatic
calvintibia001's Avatar
Default NA+T Problems AGAIN ! Oil Return without dropping the sump ? Flame Trap ?
I have used the search function already, but either my asian eyes are too small or I am search the wrong thing
So, I was wonder is it possible to use a Christmas drill bit and drill into the sump, tap the hole and put a brass fitting with tapered thread on there ? So I don't have to take the sump and crossmember off. Like this: MCM MX5 +T
Another problem is, where does these two pipe goes, I only see 1 pipe fitting from the intercooler to throttle body on the intake pipe. Is one for the PCV valve and one for the flame trap ?
Thanks so much
Originally Posted by Disco Inferno View Post
mooooooooooooooooooBRBRRRAAAAAAAPAPAPAAPAAPAAAAPAPAPVTAK
calvintibia001 is offline   Reply With Quote
Old 05-15-2014, 11:34 AM   #2
Its possible to drill the block for a return without dropping the pan but its risky and requires a good deal of caution.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 05-15-2014, 11:45 AM   #3
calvintibia001
Bench-Race Fanatic
I mean drilling the sump, coz using a Christmas drill bit, should not be able to damage the oil pump or whatever, and if i leave oil in there and then drain the oil afterwards, it should be fine ?
Old 05-15-2014, 12:36 PM   #4
Canadan
Canadan's Avatar
Thats what I did. I used oil to flush it too along with acetone. Also the hose on the left is for iac and the right one is pcv I deleted the flame trap and ran the old hose to a catch can with a breather cause I didn't want to plumb it back into the intake
Canadan is offline   Reply With Quote
Old 05-15-2014, 12:53 PM   #5
740atl
educator monkey
740atl's Avatar
Hey let's drill a hole and put millions of iron filings into the block. Sounds like turbobricks.
Old 05-15-2014, 12:53 PM   #6
Stiggy Pop
Stiggy Pop's Avatar
I opened up my stock FT drain plug with the pan in place. I greased the drill and tap which caught most of the chip, the rest got flushed out with kerosene and a magnetic drain plug.
hey let's discount the fact that plenty of people have done this without a problem. If you're creating "millions" of chips your drill bit sucks.
'79 242
943 pickup
Old 05-15-2014, 12:58 PM   #7
740atl
educator monkey
740atl's Avatar
Old 05-15-2014, 01:05 PM   #8
740atl
educator monkey
740atl's Avatar
Mm mm mm iron filings...
Drop the pan and weld in a bung.
Old 05-15-2014, 05:37 PM   #9
Canadan
Canadan's Avatar
Grease your bits gentlemen.
Old 05-15-2014, 07:08 PM   #10
SlowBrick
SlowBrick's Avatar
Calvin my man. Don't be such a lazy kent and just weld the pan. Get yourself another pan and go see someone at an exhaust shop to weld you a nice piece of tube. Then lift your motor and pop it on. If you come by in September I can show you how they did mine. Been leak free for 2 and a half years now.
The turbos dont have a flame trap. Your PCV gets recycled into the turbo intake or a catch can your choice. The other fitting you see there is for your idle air valve.
Ryan
Originally Posted by YLD244 View Post
thanks mate, now i have to explain to the CEO why on my internet usage there was a popup titled "amateur Webcam sex"
Originally Posted by Volvo244GLE View Post
im pretty confident shes a squirter.
Originally Posted by coonmanx View Post
Broccoli but not nececelery.
SlowBrick is offline   Reply With Quote
Old 05-15-2014, 08:39 PM   #11
Mogly
280WHP Regina
Mogly's Avatar
Scavenge pump? Like they use on rear mount turbo kits. If you dont want to drill anything or take anything off.
403whp, profile picture
Ford Colonge V6 in the works.
Mogly is offline   Reply With Quote
Old 05-15-2014, 09:13 PM   #12
volvoboy90
sanna kärlek är svensk
volvoboy90's Avatar
I will say this, as far as the drilling thing, I had my +T done by a professional, and he drilled the block where the bung would be on a B230FT. He washed it out with gasoline, and I have not had a SINGLE Problem.
YMMV
Originally Posted by TrickMick View Post
HEY...we're all in this "Volvo stuff" together here @ Camp TBrix...
keeping the "oldies but goodies rockin' down the road"...
*PICK YER POISON*...either put a raw egg under your gas pedal
and tip-toe around town - *OR* learn to live with the GREAT FUN of
sucking unsuspecting "other brand drivers" into the educational benefits
of NEVER underestimating a "grandpa car" again....hee, hee....
RIP TrickMick You'll be missed
volvoboy90 is offline   Reply With Quote
Old 05-16-2014, 03:16 AM   #13
calvintibia001
Bench-Race Fanatic
So, the left hose plum back into where the pipe have the bung, and then the right hose into a catch can ? I thought catch can suppose to be in serial of the PCV, so, do u just plug one side of the catch can up and put the flame trap hose (the right one) into the catch can ?
EDIT:
So the left side hose is the Idle control valve ? So is that the hose that goes onto the bung for the intercooler to TB piping ?
And the right side is the PCV valve ?, so that plums into the oil catch can, block off the other hole for the oil catch can and done ?
Old 05-16-2014, 03:17 PM   #14
jacob822
just for giggles, I drilled my pan installed in the car, using grease on the bit, and a big powerful magnet, and slow drill speed I made my hole. I then pulled the motor for a swap, pulled the pan and checked and saw absolutely 0 metal shavings anywhere but on the portion where the magnet was. However I do not recommend doing this, but it is possible to keep the shavings down to a nearly somehow acceptable level if you feel the need to.
jacob822 is offline   Reply With Quote
Old 05-16-2014, 03:54 PM   #15
I also drilled the block on my +T with the pan on I drilled a series of shallow holes to not break through and get rid of most of the filings. Then at the end i drilled through. Also used a shop vac to provide suction while i was drilling.
After, flushed w/ mineral spirits through the drill hole. Then felt around with a mag stick and got a little bit. Filled pan with CHEAP oil . Used oil works great. Then drained. then filled with cheap oil. ran it with an old filter for 30 minutes. changed the oil and the filter.
Never had a problem. It was a risk and a gamble that I was willing to take.
If you do it, its not a bad idea to put one of those magnetic blocks on your filter and on the drain plug. You have an oil filter so it should catch most of the crap that you dont get from fluid flushing.
Looking back on it. Its probably not much more work to drop the pan and put a fresh oil pan gasket on.
If you have a b230 drill the block not the pan. it gives you a superior oil drain path
Old 05-17-2014, 10:31 PM   #16
calvintibia001
Bench-Race Fanatic
I got a B230 block, so I think I might drill the block instead and tap the hole, so I got use braided line all the way, instead of using Rubber / Silicone Hose, and the sump i got that got a fitting welded on, doesn't look that nice, I might find someone to drill the block and swap the sump and gasket at the same time.
Old 10-08-2017, 05:51 PM   #17
thismachine13
This is what I plan to do as well. Does anyone know the thickness of the block at the oil drain "pad". Be nice to be able to mark my bits and drill just shy of breaking through to get rid of most of the shavings. blkaplan's mailbox is full or I would just PM him.
Old 10-08-2017, 09:38 PM   #18
740atl
educator monkey
740atl's Avatar
Just take the pan off and weld a bung to the pan.
Old 10-09-2017, 12:57 AM   #19
cosbySweater
cosbySweater's Avatar
Just drill it and hammer in a 5/8 dual sided barb fitting and silicone it. It will be fine
Old 10-09-2017, 05:35 AM   #20
K9 240
K9 240's Avatar
Hi thismachine
I have a turbo block in the garage which I have just measured for you.
I have the engine straight up on the stand so the pad looks angled on the outside but flat (vertical) on the inside.
The top measurement through the return hole is 19mm & the bottom is 35mm.
Tim
K9 240 is offline   Reply With Quote
Old 10-09-2017, 07:02 AM   #21
thismachine13
Originally Posted by K9 240 View Post
Hi thismachine
Tim
Thank you, Tim!!
Old 10-12-2017, 10:54 AM   #22
thismachine13
I've decided not to tap for the to minimize shavings and do the above with the Yoshifab oil return conversion kit.
https://yoshifab.com/store/turbo-red...rsion-kit.html
What is the stock hole size in the block for the turbo drain? Thinking its a metric size but maybe SAE?
Old 10-13-2017, 12:25 AM   #23
thismachine13
Josh says I wouldn't be able to drill it close enough to get a press fit. Back to drill and tap because I don't want to have a fitting welded to the pan.
Old 10-13-2017, 04:27 AM   #24
K9 240
K9 240's Avatar
You can get fittings that bolt through a hole in the pan. Come in a variety of different angles & seal well - I've used one for a couple of years on my +T.
Or are you saying you don't want to route the oil return to the pan?
Tim
Old 10-13-2017, 06:42 AM   #25
thismachine13
Correct, Tim. Hate reopening this Hatfield and McCoy debate of pan or block but I'd rather have the return in the block. Just a personal preference.
Thanks again everyone for the help.
Cheers!
