Old 09-22-2017, 11:18 AM   #1
free244dl
free244dl's Avatar
Default Microsquirt woes
I have just finished installing all the hardware and making an engine harness for microsquirt. It boots up, I have loaded firmware, and all I have figured out how to do is calibrate the TPS and CTS. It is currently not reading anything from the CAS. I know for a fact that the hall sensor is good (it switches properly), and I even tried hooking it up to a spare distributor I had lying around to no avail. I am using a 10k pull-up resistor.
my specs:
'78 244 b21f+t
lh 2.2 distributor
brand new battery
microsquirt v3.0
The documentary is contradictory on which wire to use. The hardware manual says to wire the signal to VR- but another part of the manual describes the vr in as being for an analog signal, and to use OPTO- for a hall sensor. Which do I use? I wires it solid to VR when I made the harness and got no signal. I snipped the wire and used a jumper to connect it to OPTO and it made no difference.
It is possible that I have the wrong settings in tunerstudio. What are the ignition settings for the speed sensor I should be using? I will try to figure out how to post a log file when I get home.
project 1: 1978 244 DL, B21 f+t, doing μS, "custom" bodywork aka rust
project 2: 2006 Jeep Rubicon, lift/tires done, building bumpers, with +10hp "turbo" badge
project 3: 1968/71 Baja Bug combining two Beetles to make one good one, to turbocharge
1985 Honda Magna vf1100c: DD
free244dl is offline   Reply With Quote
Old 09-22-2017, 11:46 AM   #2
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
1k pullup for a hall input. not 10k
normally on the micro you wire it into vr1 and vr2 (or whatever). I think the opto in on the microsquirt is more for neg coil implementations.
Megasquirt Tuning!
Old 09-22-2017, 12:04 PM   #3
free244dl
free244dl's Avatar
I will reattach the vr- and install a 1k tonight. I selected a 10k because I am powering it with 12v instead of 5v.
Old 09-22-2017, 12:06 PM   #4
linuxman51
linuxman51's Avatar
still 1k. if it's a dsm cas, it'll only throw out 5v even with a 12v feed (I think...)
Old 09-22-2017, 12:19 PM   #5
Grr baby, grr
I didn't find the documentation clear on how to hook up the hall sensor. You only use one of the twisted pair on VR + I believe and the ground from the Hall has to go to the MS sensor ground wire. After reading this , it looks like you use vr+ and vr- with the hall but I'm pretty sure mine is wired Hall signal to vr+, the 1k resistor pullup and the ground to the sensor ground.
http://www.microsquirt.info/uswiring.htm
Old 09-22-2017, 12:44 PM   #6
tryingbe
Boosting along.
tryingbe's Avatar
Originally Posted by VB242 View Post
You should be using this.
http://www.msextra.com/doc/pdf/Micro...rdware-3.4.pdf
85 GLH 367whp
00 Insight 72 mpg
Old 09-22-2017, 12:45 PM   #7
turbotankshane
If you wire up everything per instructions and its not correct, you'll still show a signal in the composite logger, it will just show the cam and crank signals swapped from where they are supposed to be.
If you're getting no signal whatsoever in the composite logger then check your settings. I don't have my tuning laptop with me or I would give you my settings, but there are plenty of examples floating around here.
Edit: Oops, sorry, didn't read everything. Can't speak on the dizzy, thought you were using a mitsu CAS
Old 09-22-2017, 12:47 PM   #8
linuxman51
linuxman51's Avatar
so if it's an lh 2.2 distro, it's going to simply be trigger return single coil. vr1 input, 1k pullup, profit
Old 09-22-2017, 12:48 PM   #9
linuxman51
linuxman51's Avatar
err not trigger return, wtf. distributor mode, non trigger wheel. Crossed my signals up that time lol
Old 09-22-2017, 12:49 PM   #10
tryingbe
Boosting along.
tryingbe's Avatar
Opto+/- are the inputs for coil-negative triggering on a fuel only install, do not use them if you are controlling
ignition.
VR+/- are the inputs from the crank sensor (VR, Hall, Opto, etc.)
VR2+/- are the inputs from the cam sensor (VR, Hall, Opto, etc.)
From the manual I posted.
Old 09-22-2017, 02:37 PM   #11
free244dl
free244dl's Avatar
Alright. I think the one I saw that was contradicting applied to older versions of microsquirt. Ill reattach it to vr- tonight.
I still suspect that the problem is a missed or incorrect setting in tunerstudio though, because my multimeter easily reads a voltage signal off the circuit with the 10k. More info to come.
Forgot to mention earlier, I am using +spark to control a golf mk3 coil.
Old 09-22-2017, 02:48 PM   #12
Grr baby, grr
I think that should be IGN A and the same setting in TS
Edit: I forgot I can check my settings in MSDroid.
Trigger return
Trigger angle. 53.4
Falling edge
Going high
Single coil
IGN A
Cam input - cam input
This is on a block mount lh2.2 dizzy.
Old 09-24-2017, 11:53 PM   #13
free244dl
free244dl's Avatar
Thanks for the input. I changed the settings in tunerstudio and replaced the 10K with a 1K resistor and it had no effect unfortunately. I pulled the vr- pin out of the ampseal connector and tested for signal directly on the pin while cranking and it stayed signal high, it did not switch on/off like it did previously at the splice I made to the hall sensor connector. At that point I had to leave the project, I will continue my diag and keep you updated.
Old 10-03-2017, 01:18 PM   #14
free244dl
free244dl's Avatar
Last night I reattached the hall signal wire back to the VR1(-). Long story short I modified the grounding scheme and it dramatically improved the signal strength. I now get strong, distinct pulses at the ampseal connector with the microsquirt box plugged in.
There is still no signal being read in tunerstudio though. The data log shows nothing for RPM, it reads "not cranking" in TS, and the signal is still good into the microsquirt box. I am lost as to what to do. Would uploading screencaps help?
Old 10-06-2017, 10:15 AM   #15
free244dl
free244dl's Avatar
Shameless self-bump
TL;DR hall sensor circuit working fine, no RPM signal read in microsquirt. Suggestions?
Old 10-06-2017, 11:02 AM   #16
tryingbe
Boosting along.
tryingbe's Avatar
Shameless self-bump
Something is wrong. Where did you get the Microsquirt?
I suggest you sign up and post it here. Always include MSQ, MSL, and pictures of your setup.
http://www.msextra.com/forums/viewforum.php?f=101
Old 10-06-2017, 11:08 AM   #17
Pro Sneaker Peddler
Where are the screencaps?
Old 10-06-2017, 11:09 AM   #18
free244dl
free244dl's Avatar
I bought it from DIYautotune. I thought it would be something stupid like a setting I missed, but I will go post on msextra.
I wasn't sure what to screencap. I will post a few when I get home from class.
Old 10-06-2017, 11:35 AM   #19
tryingbe
Boosting along.
tryingbe's Avatar
I bought mine there too, are you using a shield?
Page 51
Old 10-06-2017, 12:00 PM   #20
free244dl
free244dl's Avatar
I am using the 8' pre-assembled harness that has shielded VR wires. I am using a high-impedance LED test light to watch the signal from the hall sensor on a backprobe in the ampseal connector. It flashes as I crank, indicating a voltage signal.
Old 10-06-2017, 12:06 PM   #21
culberro
culberro's Avatar
Have you updated the firmware? I had an issue where the uS was firing 180deg out randomly. Updated the firmware and it was all good. Nothing else changed.
Old 10-06-2017, 12:12 PM   #22
Grr baby, grr
I had the same problem with the same fix, make sure you use the command line updater not the one in tuner studio.
Old 10-06-2017, 12:44 PM   #23
free244dl
free244dl's Avatar
Good to know. I did use the command line updater to load the firmware, but it has been a while and I'm not sure if it has the latest software.
Old 10-06-2017, 02:31 PM   #24
turbotankshane
whats wrong with the updater in ts?
Old 10-06-2017, 02:49 PM   #25
Grr baby, grr
It didn't work for me, had me chasing my tail for about 2 weeks until I used the command line loader
