Old 09-25-2017, 11:57 AM   #1
Grr baby, grr
Default Are head studs worth it?
I just popped another Elring head gasket yesterday. New bolts last time or maybe the time before that actually. I know what my problem is, it's that I don't have enough fuel for full boost in 3rd gear and not being quick enough letting off the throttle. I plan on rectifying this shortly. But since I'm going to have it apart yet again, are arp studs a worthwhile investment. Plus t'd B21 with k-jet 160 head.
Old 09-25-2017, 12:01 PM   #2
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
In my experience in the EJ20 world ARP studs are worth their weight in gold.
-Stephen
#mclovethesenuts
Old 09-25-2017, 12:07 PM   #3
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
not really, and get an SCP head if yours isn't already.
Megasquirt Tuning!
Old 09-25-2017, 12:12 PM   #4
esmth
dirty swede
esmth's Avatar
subaroots are also known to blow through HGs like no tomorrow
1991 244 +T LH2.4 m46 287k miles with B cam advanced 4*, 962 fuel & 148 ezk, T5 white injectors, 2.5" exhaust w/ magnaflow straight-through & some kaplhenke suspension goodies
Old 09-25-2017, 12:15 PM   #5
KeizerBrickGuy
Sh*t pot stirrer
Haha. It is true on the NA motors for sure....but the biggest known issue is ring-land failure.
Old 09-25-2017, 12:27 PM   #6
Grr baby, grr
It's not, i didn't think it was an issue with a B21 since there's a little more meat on the block. Last time he just kissed it I think he said ,.005"just to clean it up.
Old 09-25-2017, 12:32 PM   #7
eabras
Fancy studs won't help you from blowing gaskets if the afr and timing is wrong..
eabras is offline   Reply With Quote
Old 09-25-2017, 12:38 PM   #8
Grr baby, grr
I'm still working on my tune, and I need about $400 to do what I want with the fuel system, buy my diesel drop front sway bar.
Old 09-25-2017, 12:40 PM   #9
Grr baby, grr
Also I made it home 11 miles without any coolant from from the exhaust after I loosened the coolant cap so fingers crossed it's minor.
Old 09-25-2017, 12:43 PM   #10
John V, outside agitator
Slightly different block and problem. since both block and heads are aluminum there is no harshly different growth rate problems as in iron block/aluminum head cars..
Likewise iron/block/iron heads like the nearest thing to Volvo, the one that has same bore, stroke, bore c-c, head and main bolt sized etc.
That mainly just shows what a piece of crap EJ20 and the whole EJ family is stock.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 09-25-2017, 01:08 PM   #11
cosbySweater
cosbySweater's Avatar
Think of the head gasket as your fuse. Get more fuel in it and use bolts. Better then clobbering a piston imo
Old 09-25-2017, 07:41 PM   #12
shoestring
shoestring's Avatar
Not to be a dick, but if you know what the problem is, fix it. Don't look to some silver bullet to cover it up.
Old 09-25-2017, 07:47 PM   #13
gsellstr
gsellstr's Avatar
Depends on how much you plan to do. For me, it's been worth it since my car has had the head off several times, but I've only bought 1 set of studs, not a couple sets of bolts. Also slightly higher than normal loading at 20psi. lol
For stock, eh, run the bolts and fix your tune.
RIP
74 144 B20
90 745Ti
Old 09-25-2017, 07:54 PM   #14
Jack
junkman
Jack's Avatar
I got a NOS set. I'll sell it to you for 1/2 the going rate of gold
Old 09-25-2017, 09:47 PM   #15
Can play the blues
My suggestion is to lower the boost to a safe fueling level. Put it back together and use the cometic if you want a stronger head gasket and torque the head bolts to the Penta specs. I think it's 120 degrees if I recall correctly.
Old 09-26-2017, 01:24 AM   #16
Grr baby, grr
Thanks for the advice, question was only about head studs, I plan on boosting to 20psi or more, possibly. I will have the fuel supply sorted out before I beat on it again.
Old 09-26-2017, 01:38 AM   #17
ryan242v
ryan242v's Avatar
Yes head studs are worth the money. Whether you need them or not is a different story and doesn't really matter. ARP head studs are far more resistant to stretching, which prevents the head from lifting ever so slightly and blowing out a headgasket. Also, studs allow for a more accurate bolt torque value. A MLS headgasket and head studs are definitely the bees knees, especially if you like removing your cylinder head often.
2009 Schwinn Leguna 50!! Scooter Puff Jr. 5,500 miles!
1998 S70 T5M, 264k miles, needs something
1987 244 DL, 234k miles (Current Daily Driver)
1979 242 DL, 500k miles, B230FT, M45, 3.31 diff
1973 1800ES awaiting restoration, not togethor
1971 Camaro, my highschool car, rusting away
1969 Suzuki T500 Titan II
ryan242v is offline   Reply With Quote
Old 09-26-2017, 01:44 AM   #18
eabras
Stock bolts and the elring gasket on my b21 seems to work fine for 32psi..
Old 09-26-2017, 02:26 AM   #19
Jack
junkman
Jack's Avatar
But no bling dude
Old 09-26-2017, 08:41 AM   #20
ICantDrift
ICantDrift's Avatar
Again, this isn't for a redblock but on BMW M30's, headstuds make the difference between cylinder pressure leaking out between the head and the block and not having that happen
Sam
ICantDrift is offline   Reply With Quote
Old 09-26-2017, 09:03 AM   #21
Grr baby, grr
What head are you using? Also I'm planning on going elring again since I bought it from FCP, I'll try out their lifetime warranty.
Old 09-26-2017, 09:15 AM   #22
linuxman51
linuxman51's Avatar
get new bolts (~$30 or whatever), elring gasket. copper coat the gasket, torque the bolts down, then turn em to 110 degrees instead of 90 (unless they get "gooey" before 110). that's what, like $50 in parts for everything?
Old 09-26-2017, 09:44 AM   #23
Grr baby, grr
I think I went 115 degrees last time but I didn't copper coat the gasket. Also one use bolts but I checked the length on all of them.
Old 09-26-2017, 11:22 AM   #24
eabras
398 from 1984. Had it off a while ago (blew hg due to mishap with crank sensor image). Didn't do anything fancy (well, I measured the bolts and scraped off som residue from the old hg) before it went back on the engine
Old 09-26-2017, 05:22 PM   #25
swedefiend
This.
