Old 09-26-2017, 06:29 PM   #26
ryan242v
ryan242v's Avatar
Originally Posted by VB242 View Post
I think I went 115 degrees last time but I didn't copper coat the gasket. Also one use bolts but I checked the length on all of them.
Dude head bolts are dirt cheap! Why even would you reuse them? It's hard to tell if the bolts are still good until they break. The bolts stretch and twist during initial torque and stretch more during heat cycles. The next use you're having to put even more strain on the bolt to achieve the same torque value as before. Plus, your final torque value will be lower after angle torque on a used bolt. Bolts are cheap, replace them. Or go big and head stud that jammer.
2009 Schwinn Leguna 50!! Scooter Puff Jr. 5,500 miles!
1998 S70 T5M, 264k miles, needs something
1987 244 DL, 234k miles (Current Daily Driver)
1979 242 DL, 500k miles, B230FT, M45, 3.31 diff
1973 1800ES awaiting restoration, not togethor
1971 Camaro, my highschool car, rusting away
1969 Suzuki T500 Titan II
ryan242v is offline   Reply With Quote
Old 09-26-2017, 10:25 PM   #27
cosbySweater
cosbySweater's Avatar
If the don't snap they are fine. If they do snap you replace them
1979 Volvo 244DL 6.0/4l80e,8.8,Ms3x goldbox ecu and Mircrosquirt tcu, s366 clone.
1982 Ford Fairmont Futura, 4.8/th400, 8.8, mircrosquirt, 7665 turbo, Project Cheap Thrills
Old 09-27-2017, 08:48 AM   #28
turbotankshane
Its pretty easy to tell if TTY bolts stretch. The last b230ft I put together I picked through two used sets of head bolts, 20psi and a small pill later everything is still just fine.
Old 09-27-2017, 08:53 AM   #29
One hundred gift baskets
They're torque to angle anyway.
1980 primer Franken-242DL, 1989 silver 780 bone stock.
Old 09-27-2017, 12:49 PM   #30
quillc
yv1a.com
quillc's Avatar
I've never liked the TTY bolts.
I've had good luck with the head stud kits. Last two HG jobs I've done I've gone ahead and thrown a set of head studs on the car. At $250+ its not Tbricks cheap, but its not terribly expensive. One was on my wife's 91 with a 94 B230FD motor running an A cam. Studs was terribly overkill, but I'll be able to reuse them forever and I torqued the HG down just a little bit more than stock. The other was my DD high compression B23 with an H cam. Again, I torqued to just a little bit more than stock.
If you have a highly boosted car and want to use a Cometic HG torqued to 100 ft/lbs? Use head studs. If you have a DD low compression B230 that you just want to drive to the store? You can very likely reuse your stock bolts.
In the end, the debate will rage on. Realistically, either will work fine for most of us at our performance levels. In many ways I'm a fan of overkill when it comes to things like fasteners. That way you eliminate one source of potential failure.
Chris
www.yv1a.com
Old 09-27-2017, 01:24 PM   #31
Lord_Athlon
Sf1k Kryptonite
Lord_Athlon's Avatar
Theyre not TTY bolts. TTY bolts wouldnt be reuseable.
Originally Posted by rvolvor
Lord_Athlon is online now   Reply With Quote
Old 09-27-2017, 02:17 PM   #32
swedefiend
They're called TTY... even by automotive professionals (it's just one of those things... Most people know it is wrong. They keep using the name anyway.)
But, you are right. The strain induced upon the fastener while torqueing often pushes the lattice of the fasteners constituent metal past the 'yield' point.
This is a good article to become familiar with the practical aspects of the underlying technology:
http://www.enginebuildermag.com/2001...rque-to-angle/
Old 09-27-2017, 02:18 PM   #33
turbotankshane
I'll admit that I'm not an expert on the subject, but I was under the impression that torque-to-yield was the same as angular torque
The first thing I found on the subject would seem to suggest the same:
http://wbtools.com.au/how-to-underst...rque-to-yield/
Just ignore the bold text that says to never re-use them.
Per alldata, Volvo's spec was to not use more than 5 times, don't use if the threaded section shows signs of expansion, don't use if in doubt.
Old 10-05-2017, 08:28 PM   #34
Well here's my new fcp purchased ajusa bolts made in esthpana as Conner for real would say. I followed the qr tag to this video for installing them. Interestingly they call for 180° total but the head bolts in the video aren't B2xx head bolts. Also what kind of lube do you think they're using some moly stuff looks like. I've been using motor oil.
http://www.ajusa.es/ficha_multimedia...encia=81003900
Old 10-05-2017, 10:22 PM   #35
If they were torque to yield they would be longer when they were removed instead of being able to be reused. They're skinny in the neck to keep an even clamping force between iron and aluminum as they expand at different rates. The final torquing instruction says to turn them 90° = torque to angle
Old 10-08-2017, 12:45 AM   #36
So I found a split in my map sensor hose, I also found evidence of my first detonation event on #2 but the Wiseco didn't break.
