Old 09-29-2017, 12:14 PM   #1
Tfrasca
Tfrasca's Avatar
Default Yoshifab plenum: Noisy?
Has anyone else noticed a lot of engine noise coming through their Yoshi plenum? Mine seems to resonate and almost makes the B23 motor sound like a diesel. If I put my hand on the plenum, all that noise stops.
I'm wondering if it's just the thin sheet metal not insulating sound, or if it's some kind of weird resonance in the way I designed the manifold.
Old 09-29-2017, 01:17 PM   #2
Benjam83
Moar Volvos than Queen B
Thin sheet metal, in addition to free flowing design, which won't restrict noise coming out of the intake.
Ben
12 WRX Hatchback
10 Subaru Outback
93 245 m47
Benjam83 is offline   Reply With Quote
Old 09-29-2017, 01:20 PM   #3
Tfrasca
Tfrasca's Avatar
Does it bother anyone else enough to do something about it?
I had a panel of sound deadening material on it, but that looked terrible and was only marginally effective. I thought about welding a big sheet of 1/4" aluminum to it to dampen some of the sound. Wondering if anyone has tried anything similar.
Old 09-29-2017, 01:33 PM   #4
Janspeed
how about fixing some alu U-profile on the long flat surfaces ?
Old 09-29-2017, 01:47 PM   #5
culberro
culberro's Avatar
No such noise on the 16v
Old 09-29-2017, 01:55 PM   #6
Tfrasca
Tfrasca's Avatar
Interesting. It could be that my velocity stacks are about an inch or so away from the back wall of the plenum. So maybe whatever Helmholtz stuff is going on is causing the noise.
I'll try to get a video of it. It's pretty weird.
Old 09-29-2017, 02:06 PM   #7
PCH
May be add a weight to in? Done on exhausts all the time.
Old 09-29-2017, 02:15 PM   #8
Tfrasca
Tfrasca's Avatar
Yeah, that's my thought with adding a sheet of 1/4" to it.
Old 09-29-2017, 11:09 PM   #9
quillc
yv1a.com
quillc's Avatar
If it's resonating (vibrating) you may only need to tweak the housing to get it to stop. Sounds crude, but you may only need to dimple it in a couple places to get it to stop.
Chris
www.yv1a.com
Old 09-30-2017, 08:54 AM   #10
DET17
Reformed SAABaholic
Exactly. The natural frequency is a function of (among other things) the mass and stiffness. Bending/buckling/reinforcing a thin "flat panel" gives it more section, and will move the harmonic to a higher frequency.
Old 09-30-2017, 09:44 AM   #11
Grr baby, grr
Remove most of the exhaust system, you'll no longer hear your intake noise.
Old 10-03-2017, 08:34 PM   #12
740atl
educator monkey
740atl's Avatar
Earplugs?
Old 10-03-2017, 08:40 PM   #13
BillyMaysHere
BillyMaysHere's Avatar
Plasti dip it? or bed liner it. to dampen the metal... IDk
Old 10-04-2017, 10:10 PM   #14
rom
rom's Avatar
Side exit, no muffler. Zero intake noise issues. Side benefit of putting your infant directly to sleep as soon as you start the car (assuming you have an infant of course)
Religious people scare me.
rom is offline   Reply With Quote
